700x23c tire users: How many PSI do you fill it to?
Location: "Gosh honey, you pass more like Tony Rominger..."
Bikes: 2005 Scott CR1 Pro - 1992 Panasonix Fixed Conversion 60tx20t
It says 115-125 on mine. I'm 200 lbs. How many PSI do you use for a fast ride?
"How did all those 'Keep Off the Grass' signs get there?"
Feed me your soul!
Bikes: Torelli 20th Anniversary, Trek 2000, Kona NuNu
My vredstein's say 175 (!) I usually go 150 in the rear, 140 in the front. 200lb you probably wanna go to 125. Don't wanna pinch flat...
Feed me your soul!
Originally Posted by DieselDan
To the max dude. Always to the max.
I don't think I have the strength in my body to pump mine to the max... plus that just seems rediculously high... I mean 175psi.. is crazy. Plus it will probably ride like hell.
DEADBEEF
Location: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
Liked 6 Times
To everyone who is pumping up to really high pressures on their clinchers (> 150PSI), you might want to check your rim rating. My rims (Mavic Ksyrium) state 140PSI as max pressure. I think I might be able to safely go to 150PSI or possibly even 160PSI. I'm running Continental GP3000s which are max-rated at 120PSI although I know with most tyres, you can usually exceed that by a bit. I have run them as high as 130PSI. I'm typically running them at 125PSI.
1999 K2 OzM 2001 Aegis Aro Svelte
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
Feed me your soul!
My prob is when the tires say max 175....are they safe to run at like 120? I should've bought different tires..
Industry Maven
Bikes: Thylacines...only Thylacines.
In 20 years I've never pinch flatted a road tire, and I bunnyhop little divots and irregularities.
I weight 200 and rarely go over 110psi.
Edit: khuon beat me to it. Thanks khuon.
By-Tor...or the Snow Dog?
Bikes: Bianchi Cross Concept, Flyte Srs-3
Bontrager Race X Lite Tires (700 x 23c) on DT Swiss RR1.1 rims laced to Campagnolo Record hubs, 3-cross 14/15g DT Comp spokes ...
120 psi both front and rear. Top off before each ride.
I weigh 90 kg.
I'm looking into some higher pressure-rated tires ... anyone try the Tufo Clincher-Tubulars ... maybe I'll make a new forum or search ....
I weigh 90 kg.
Bikes: Modified Trek 5200. Trek Team Issue TT.
bontrager select B's on a Bontrager select wheel (training tires) i fill to 98 or 100. it says 100. depends on how hot it is outside.
race wheels are Zipp on Zipp 404's...i fill those to anywhere from 100 - 140. depends on weather. i am a 172 lb rider...trying to get down to 160-165.
