Anyone experienced this?
First, this time last year I was at 268 lbs. Then, got back into cycling heavily, and now I'm down to 188 at 53 years old. But here's the problem... This winter I have been absolutely freezing! And not just outside in the elements, but sitting around the house in a 72° to 75° environment! My wife is wearing me out because I'm constantly turning up the heat. And she's the one that's always complained it's "too cold."
Everyone suggests that it's because I've lost a lot of body fat, but I'm not so sure that's it. I'm a bit concerned it could quite possibly be a medical issue maybe. I've never been one to get cold easily, even back when I was skinny as a rail, when I was young.
Anyone else ever been through this??
Quoted: 660 Post(s)
Liked 601 Times
My guess is your metab is quite adjusted to warmer weather and when it turns damp/chilly even 72 is cold. Up here we sweat in 72. Most of us set the thermostat at 68-70 which will give a swing of 66-72.
If your caloric intake is adequate and you arent running around in your underwear, everything else sounds about normal. If you are still cutting weight, that will be a core temp gamechanger. It surely is to me.
Being chilled is a sign of low thyroid. I was put on synthroid and my deer hunting was once again joyfully tolerant of cold weather.
trooper2899
Get your thyroid gland function checked (blood test) might need some adjustment - thyroid is like a thermostat
Quoted: 523 Post(s)
Liked 231 Times
Have you tried wearing heavier clothes? If I am sitting at the computer not moving with the house at 68 degrees I don't do it wearing a t-shirt and light pair of pants. If I were moving around the house those clothes might be adequate since movement equates to burning calories and naturally you would feel warmer. If you all bundled up and still feeling cold, then follow the advice to see a doctor with your complaint.
alpine cross trainer
Bikes: Specialized Roubaix, Quintara Roo Sendoza, DaVici In-2-Ition Tandem,
Quoted: 21 Post(s)
Liked 20 Times
I'm 67 and lost over 50 lbs about 6 years ago. I've stayed at about 140 since than. Like you, I'm always cold! I've learned to routinely wear more layers of clothing that I can shed as needed. In the wintertime when I'm working in my shop I always wear long johns under my work clothes. The extra layers make a big difference.
In the house I have a flannel shirt that I put on as needed.
PS: radiant floor heat is wonderful, allowing for a much more comfortable house !
Veteran, Pacifist
Quoted: 3919 Post(s)
Liked 4,886 Times
I went from 205 to about 180 over the past Summer, and was chilly when Fall temps arrived = below 60f.
But check with your Doc.
I've lost 116 lbs. and I am cold more often. I dress in layers. I've had thyroid checked as part of a physical & all is normal.
Bikes: 2015 Ridley Fenix, 1983 Team Fuji, 2019 Marin Nail Trail 6
Quoted: 344 Post(s)
Liked 245 Times
Yeah.
I lost 50ish lbs a few yrs ago, and have managed to keep it off. The first winter I noticed I got cold more often than I used to. The flips side is that I handle the heat a lot better than I did 50 lbs ago.
This year I'm going after the last 25 or 30.
Quoted: 1366 Post(s)
Liked 1,688 Times
Congrats on your weight loss and improved fitness!
Quoted: 1593 Post(s)
Liked 1,026 Times
I've always preferred it pretty warm, but I do think cold bothers me even more as I age so that could be a contributing factor. Fortunately, my wife is pretty similarly programmed. We keep the house at about 77 in the winter and about 82 in the summer. We feel almost guilty when we're outside and complaining about the cold when we realize it's in the 50s.
Semper Fi
Quoted: 1173 Post(s)
Liked 358 Times
My weight loss is very close to the same numbers as the OP, felt cold for nearly 3 years now. Recently I found out that some of my being cold natured now, after always loving the colder weather, is the Parkinson's Disease. Seems that some PD folks have problems with this, never thought about it being the cause. Wife and I have swapped places, she has the hot sensations, from menopause, and now I am freezing. Used to be the exact opposite. Strange times we are living in now.
Bill
Bill
Semper Fi, USMC, 1975-1977
Bikes: Bridgestone RB-1. Nicely restored
Quoted: 13 Post(s)
Liked 9 Times
one4smoke, all the advice here is good. I'm afraid though, that as you age, the cold will simply bother you more, and
there is not a heck of a lot you can do about it. I used to ride regularly in temps as low as the 20s, but now, at 59,
40s is my low limit. And yes, I have all the cold weather gear.
In the colder weather, I think in terms of time outside, not miles. I try to ride enough to keep the kinks out, and from
putting on too much poundage in the winter.
Quoted: 258 Post(s)
First, wow...80 pounds is a lot and congratulations! Next bit...I'm now 73. I dropped 42 pounds pounds Jan-Nov 2014. 242 to a just gotta get there 199 and have kept it off. I'd never been cold susceptible and am still not. Nor dry heat for that matter. If you're getting regular doc checkups I'd just live with and keep an eye on the issue....if not get a physical/checked out soonest.
Old Fart In Training
Quoted: 12 Post(s)
Liked 22 Times
Dress warmer,, wool maybe, wear long underwear, workout tights are comfy for me, like a second skin.
Hydrate correctly,
Get a humidifier, The dry heat indoors can zap you.
Get an Indoor trainer set up, or a fat bike,
Ride !
Hydrate correctly,
Ride !
Bikes: Trek 970, Bianchi Volpe,Casati
Quoted: 359 Post(s)
Liked 122 Times
congrats on you getting back in shape . good inspiration , I had always been cut up but got a little belly now. spring is around the corner.
Bikes: Giant Propel, Cannondale SuperX, Univega Alpina Ultima
Quoted: 678 Post(s)
Liked 431 Times
I went from 325 to 165. I was FREEZING from 225 or so on down. I'm fine in the cold as long as I'm active, but still get cold if I stand still. My wife assures me this is just life for people of normal size and weight.
Formerly fastest rider in the grupetto, currently slowest guy in the peloton
Standard Member
Bikes: 1948 P. Barnard & Son, 1962 Rudge Sports, 1963 Freddie Grubb Routier, 1980 Manufrance Hirondelle, 1983 F. Moser Sprint, 1989 Raleigh Technium Pre, 2001 Raleigh M80
Quoted: 1302 Post(s)
Liked 944 Times
How much physical endurance exercise have you been (or are you) involved in?
I went into a period of over-training (in running) when I was 51, and en-
countered adrenal fatigue as my body's temperature-regulation apparatus
(the hypothalamus-pituitary-adrenal axis) basically shut down.
Do you sweat under slight exertion? Are you monitoring your core temp?
Even regardless of the exercise factor, the stresses you put on your adrenals by 1.) eliminating that much weight and 2.) the detoxification and elimination of toxins that were previously stored in the fat, could be considerable. Also, the body may have interpreted the accelerated and somewhat sudden weight loss as an emergency situation (running out of food, preparation for armed conflict, etc), therefore engaging the fight-or-flight response of the adrenals. When the adrenals are hit in one extreme blow or repeatedly by chronic stress of any kind, they can be subject to depletion, which is when the chills, low core temp starts.
"In every job that must be done, there is an element of fun. You find the fun, and - SNAP - the job's a game!"
Standard Member
Liked 944 Times
Make sure your provider not only tests for TSH, but for Free T4, Free T3,thyroid antibodies and ferretin and iron. This will help present a more-complete picture.
https://www.functionalmedicine.org/p...ch.aspx?id=117
I did not say what type of MD checked my labs and Indid say everything is normal. Was simply trying to relate my own experience to what was initially asked. Thanks.
Quoted: 1514 Post(s)
Liked 735 Times
Strictly as a layman, I'd say it's possible that your metabolism is low, which is why you were 268 in the first place. Losing weight (insulation) would just make it more obvious to you. A trip to the doc might be in order, although the diagnosis might be that you need to be more active in order to raise it to where it belongs.
It is not that cold Here in the winter , the clear skies do let it cool off faster than Overcast ones
