Skinsuit vs Aero Bibs/Jersey
I've been watching the track world championships this week on TV.
What difference will a full aero skinsuit make to my race times versus a high end pair of aero bib shorts and jersey combo?
Bikes: Cervelo Prodigy
Quoted: 479 Post(s)
Liked 88 Times
Wind tunnel test with you riding. Biggest difference would be your position on the bike and your body profile itself. That way you're testing what matters.
Maybe add a naked test. Shoes but no socks.
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,203 Times
Probably not much assuming you don't have hairy arms and legs.
Bikes: 1979 Raleigh Team 753
Quoted: 3377 Post(s)
Liked 371 Times
Seems about 1/10 mph @ 30mph. Maybe more when you bring in the mental part. Certainly a requirement for a TT.
I'd add going long sleeve makes a difference / or shaving your arms.
This is a stretch my son has done several hundred times (15 min from our house). He mixes it up with skin suit and bibs and jersey. ~29-30mph in skin suit.
There are plenty of surveys online that will give you the scientific answer.
You'll also need to adjust your riding style in to a more aerodynamic position. The skinsuit will help in this regard, but take a look at videos online like the one Doge posted above to give you an idea.
It sounds obvious, but if you're going to buy a skinsuit, then make sure the fit is absolutely skin tight. Otherwise, it's not worth bothering.
Also, go for a high end one that isn't going to stretch after you've worn it a few times. Speaking from experience, some have a tendency to crease around the shoulders and thigh areas.
Looks like good technique and minimal upper body movement.
Liked 371 Times
I posted this somewhere in the last few weeks but we are working for him to unlearn smoothness in TTs and stomp on the pedals. Seems it makes the rider go faster. A video below taken over a year ago you will see he is much less smooth now. Just faster.
Smooth <> fastest TT
I still like drafting races, but this reminds my why I prefer competing in non-drafting races and triathlons.
As athletes, we should have to do all of our own work, instead of the pack dictating results through drafting.
Liked 371 Times
Anyway, the point, other than showing off my kid, was...
-do your own tests.
-It does matter when you need to get max speed.
-do your own tests.
Bikes: Fuji Sportif 1.3 C - 2014
Quoted: 5 Post(s)
Non-Drafting races are called time trials.
While there is some strategy tactics in time trials, there's a lot more in races. And you're actually competing against other cyclists in races, as opposed to competing against yourself in a time trial.
GH
Vain, But Lacking Talent
I've wanted the SanRemo speed suit since it first came out, but I've always been too fat to let myself waste money on one. Maybe if I hit my target weight by my birthday in September, I can treat myself. It seems like the best of both worlds and would be awesome for Texas summers when you can remove the extra layer of bibs between you and the jersey, but still have full bib-style support and pockets in the rear.
Quoted: 63 Post(s)
Quoted: 5 Post(s)
So you're really racing yourself, and then when you're done, you compare your time to others' times.
GH
Liked 371 Times
Of course is is not the same as a Crit. But times vary by who shows up and position starting and taking advantage of wind (passing cars, riders). When we are discussing seconds the little stuff matters - like a skin suit (this thread). On some TT courses you may see your competitors on turns and adjust your speed for strategy reasons - then there is chasing the rabbit, esp on TTs with 30 sec start differences where you might pace a rider up a hill and do something different on the decent. As mentioned it all matters more in stage races, but TTs may not be just go against yourself.
It's "tactical cycle racing" versus "cycle racing".
When passing a struggling competitor, you've got 15 seconds (or whatever the rules say) in their drafting zone to overtake. Once past, the onus is on them to immediately drop back 7 metres (or whatever) out of your zone before they can then attempt to come back at you.
The problem with drafting is once you are past, they can tactically hang on to your rear wheel, recover, make you do all the work, then pass you again near the finish.
It's good for Television with close racing, etc. but I find that unfair from a sporting perspective.
Quoted: 63 Post(s)
Quoted: 2953 Post(s)
Liked 3,106 Times
Quoted: 5 Post(s)
Part of it is so that the team can protect one of their riders, so they can sprint to the finish. Cavendish talks all the time about his leadout rider.
If you don't want somebody wheelsucking, then either slow down or drop them. Let them know that you're perfectly willing to go back to the pack and draft if they're not willing to help on the breakaway.
Who said that anything in sports was supposed to be fair?
Now, it may not be very sporting. But often in sports, the best tactical/strategic decision may not be very sporting.
And I still think that "chasing the rabbit" or doing other things when you see another cyclist in a time trial is more strategic than tactical. The rules of a time trial are set up that you are racing against yourself to get your best possible time. And then afterwards, you compare it to the other riders. Now granted, the first cyclist out is at a disadvantage, because they don't know the times of the other cyclists, and the last rider may have the benefit of knowing how hard they have to go, which may be of benefit in a multi-stage race. But for the most part, you're trying for your best time, and other cyclists shouldn't be influencing that time.
GH
