Computer suggestions for a Tandem
Bikes: Peugeot UO-10, Schwinn Caliente, Miyata 610, Miyata 914, Burley Zydeco
I'm looking for a computer that will work for the stroker of a tandem. We have a burley zydeco, and I would like computers for the captain and stroker. We picked up a pair of Sigma My Speedy's at a swap meet for cheap, and this wireless sensor will work fine for the captain, but no luck with the stroker's handlebars. The handlebars are about 80-85cm from the front and rear wheel, so I don't know if there is any benefit of choosing one over the other. Has anyone had any luck with a particular brand or model?
Bikes: Ibis Mojo HDR, Devinci Atlas, Walt Works 29er, Cannondale EVO, Co-Motion Supremo
We use the Garmin 500's, they are fairly reasonable and can be found for around $150.
They are GPS so no need for a wheel speed pickup, the Mrs. has a heart rate monitor paired to hers, and we both are paired to a cadence sensor.
Bikes: 2001 Cannondale RT3000, Santana Cilantro, 2004 Ed Litton BreakAway travel bike, Bianchi Volpe, 1972 Atala Competizione
We used to use Cateye Mity8 because they're inexpensive and you could buy the tandem length pickup/mount units from Cateye.
We switched to the Garmin 500. Now the only issue is making sure the stoker brought her reading glasses. I need to get her some stick-on bifocal lens for her sunglasses.
Bikes: Fandango DC-9 Mtb Tandem,Co-Motion Supremo,Trek T-1000 tandem, Specialized Allez Elite, Dolce,
I use a Cateye Padrone for me up front because of large screen.
The only Cateye wireless that will cover the distance from rear wheel to stoker bars is the Strada. We just rode Saturday and every time I asked her speed she was spot on compared to mine. The Strada also does cadence for us as the Padrone does not.
just another gosling
Liked 2,098 Times
Stoker has a Garmin 800 and navigates for us. We use a Garmin GSC 10 Speed and Cadence Sensor on the left chainstay. Captain uses a Cateye Stealth 50 unit. Both units receive signals from the GSC 10. Captain's heart rate is displayed on both the Garmin and Cateye units. Stoker uses an inexpensive Polar unit for her heart rate, which she matches to Captain's HR. This has worked very well for us for several years.
Results matter
Results matter
The Cateye Strada Digital should work. It uses the 2.4 GHz sensor with 5 meter range not the same sensor as the Strada wireless. I have Cateye V2c (no longer made but uses the same sensor as the Stada Digital) computers on one of my tandems and on my triplet. One sensor on the rear wheel/crank has the range for all computers on the bike including the captain's computer on the triplet.
Liked 2,098 Times
Results matter
Results matter
Stoker on our tandem has a Cateye Padrone wireless mounted on the top tube. The big display can easily be seen from there and it works perfect with the magnet on the rear wheel. It did not work when mounted on the stoker bars.
Super Modest
Bikes: Trek Domane+, Trek Emonda, Giant Propel, Colnago V3, ICE VTX WC
Liked 5,129 Times
I use an 810 on my single and my wife uses a 500 on hers. On the tandem, my wife uses my 810 for mapping and directing us and I use her 500. The HR belts record on our own computers regardless of position on the bike so downloading is fine and I don't have to re-sync when we switch computers back on our singles.
Also, both units pick up cadence from the captain's crank.
Keep the chain tight!
Bikes: Franco Kanan, Santana Arriva and Beyond Tandems
I use to use a Garmin 500 but it died and now I upgraded to a 520, the 520 does a lot more mapping but is still smaller than the 820 or 1000. I have not used the mapping on the 520 yet but the two nice features are that it shows text alerts when paired to your phone (Bluetooth) and it has a simple user replaceable battery. Technically the 500s battery needs to be replace at the factory, you can replace it yourself but it takes fairly major surgery. The wife (stoker) uses a 810 and runs the maps since she is the navigator.
Cheaper options might be to use your phone with a phone mount on the bars or something like the Wahoo RFKT that mirrors the ap running on the phone. I elected not to go in this direction over concerns that the phone battery would be an issue on longer 6+ hour days.
Half Fast
My wife uses a Sigma Sport BC 1009 STS wireless on her stoker bars. It was a fairly inexpensive wireless unit that I bought after consulting with a support rep at Sigma (1-630-761-1106). He told me that all of the STS units (such as the current BC 12.12 STS) and all of the ROX units should have enough range to cover the distance from the chain stay to the stoker bars, and we haven't had any trouble.
Bikes: Burley Samba tandem, Kona Coco
Me three -- I am the stoker and have an Edge 520 with the wireless sensor bundle that I am very happy with. Captain doesn't get distracted by the screen, and I have all the data I want. Now I just need to get him to wear the heart monitor so I can see how much he is slacking off.
Bikes: Co-Motion Speedster Tandem, S-works 29r, Specialized Tarmac SL4
We use Polar Mi450's on all the bikes with Heart rate monitors. We run separate sensors front and rear - but you don't really need them since it's GPS based.
Bikes: Burley Duet
I use a cheap Cateye for the stoker with long wire sensor so she can see the MPH and basic stats. I use strava on my iphone with a "Proper" Iphone bicycle mount as my dashboard. also use a Buckshot bluetooth speaker and pandora as the sound system.
Bikes: Co-Motion Primera Co-Pilot, Trek Madone 3.1
Ran a pair of Sigma for a while... upgraded to a pair of Garmin 510's and could not be happier. Both units share a single speed/cadence sensor in the rear. Each rider has their own heart rate monitor and readout. And the second speed/cadence sensor found a home on my half bike. The Garmins are very configurable and using different profiles on mine allows seamless operation on either bike. IMHO this is just the way to go with a tandem.
I'm also looking for a solution, but hoping for one with less cost than the Garmin route. I want speed, cadence and heart rate for me on my handlebar, and same for my wife on her handlebar. I thought that we could go the Cateye route, with their wireless unit that we could sync both my and her head unit with one speed/cadence sensor on the bike. But according to Cateye tech support, can't sync two head units to one set of sensors. Any other suggestions?
If you go with Cateye make sure to get a model that has "Digital 2.4G" sensors. The Cateye computers that use the standard "wireless" sensor doesn't have the range for a tandem.
That's exactly what I'm after! My wife has the cc-RD430DW on her single bike. I'm thinking get another for me, put it on the tandem. Then we both wear and sync to our own individual heart rate monitors. We both would sync to the new speed/cadence sensor. We would mount our head units to our own bars. And the wife could move her head unit between her single bike and the tandem.
But, Cateye said it won't work (one cadence sensor won't sync to the two head units on the tandem). I don't want to buy it if it won't. Sorry to question you, but are you sure?
The only problem I've ever seen is that the sensor has a long range. I think Cateye says 5 meters but I've found it to be farther. When you sync the sensor make sure all other sensors are a long ways away and or have the battery removed. That way it won't sync to A different sensor then the one you want.
You have 1 computer now. Do you have a LBS that would let you try syncing it and one of their computers?
Bikes: Raleigh Companion, Nashbar Touring, Novara DiVano, Trek FX 7.1, Giant Upland
I don't see why a pair of Cateye Stealth 50s and a single Garmin Cadence Sensor (on the captain's crank) wouldn't work together. Since the head unit includes GPS, a speed sensor isn't strictly needed and the cadence sensor is actually closer to the stoker than it would be in a typical single.
