Reducing wind noise
Reducing wind noise
Anyone use the Cat-Ears product? They have a bunch of different versions, any suggestions on which ones are better or worse for not only noise reduction or comfort or anything else? Or maybe some other product altogether?
Cat-Ears, LLC - Reduce Cycling Wind Noise
For The Fun of It
Bikes: Lynskey GR300, Lynskey Backroad, Litespeed T6, Lynskey MT29, Burley Duet
Quoted: 2139 Post(s)
Liked 1,653 Times
I just ride slow and that takes care of it.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
I use them. They work great.
Think I got the Classics II. Makes it far more pleasant, as well as easier to hear communication in a pace line
Thread Killer
Quoted: 3218 Post(s)
Liked 1,763 Times
I have Slipstreamz Spoilers on one helmet. Slipstreamz - Products - The Spoiler
Kinda fussy to install, and reduce noise a bit, but I never bothered to outfit any of my other helmets.
It is neat to realize how much wind noise is part of the ride by eliminating it. I tended to ride harder with the Slipstreamz-- if I recall rightly; it was many years ago-- because it felt slower.
Thread Killer
Liked 1,763 Times
One thing I forgot to mention is that strap mounted quieting devices like Slipstreamz and Cat Ears only work when they're aligned in front of the ear and into the wind, so for example, if you ride in a low position that angles the helmet straps more acutely in relation to the wind direction (e.g. in the drops), the devices won't be as square to the wind as if your head was more upright, and so the wind will come in over the top of the device onto the ear, making noise.
More upright positions, then, see the quieting devices perform better.
It's not a big deal, but being aware that they cannot work all the time (because of head movement and position changes) may recommend a different type of device if eliminating as much wind noise as possible is the imperative.
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
Next I'm going to get a muffler for my freehub...
Today, I believe my jurisdiction ends here...
I got 99 problems....
Location: Does anyone know where the love of God goes, when the waves turn the minutes to hours?
I use two earbuds and music to block wind noise. Works well
Quoted: 18560 Post(s)
Liked 15,975 Times
Uses the Advance Search function and search for "wind noise" in thread titles. There are several threads discussing the issue, albeit some are dated.
E.g.: https://www.bikeforums.net/road-cycli...d-noise-2.html
Optically Corrected
Foam ear plugs work great. They cut the wind noise but you can still hear traffic.
FlashBazbo
5
09-14-16 06:32 PM
qwert566
Adaptive Cycling: Handcycles, Amputee Adaptation, Visual Impairment, and Other Needs
8
04-10-14 03:22 PM
