Can't keep leg warmers from sliding down....
Bikes: '09 Trek 2.1 * '75 Sekine * 2010 Raleigh Talus 8.0 * '90 Giant Mtb * Raleigh M20 * Fuji Nevada mtb
I cannot keep my Pearl Izumi leg warmers from sliding down when I walk more than 10 feet, or stand when riding. Just barely stay up when in the saddle. Seems the rubber no-slide band still doesn't grip the shorts very well. Do I need to add some really thick silicon rubber dots? Or maybe I should have bought smaller that don't ride way up on my thigh?
FB4K - Every October we wrench on donated bikes. Every December, a few thousand kids get bikes for Christmas. For many, it is their first bike, ever. Every bike, new and used, was donated, built, cleaned and repaired. Check us out on FaceBook: FB4K.
Disclaimer: 99% of what I know about cycling I learned on BF. That would make, ummm, 1% experience. And a lot of posts.
Life Is Good
Bikes: Zipp2001 Carbon Belt Drive SS, Kestrel RT900SL, Kestrel KM40 Airfoil 1x10, Orbea Occam H30, Trek Stache 5 29 Plus, Giant Yukon 2 Fat Bike
Quoted: 277 Post(s)
Liked 871 Times
I've had the same Pearl Izumi leg warmers for 10 years now and never have a problem with them slipping down. You are wearing them under your shorts ?
Super Moderator
Quoted: 1174 Post(s)
Liked 935 Times
Tights
Yep, wearing them under my shorts. I bought these because they are compact enough for a jersey pocket, and work well for that. Last season I did pick up tights that work well, but of course not as "modular."
Quoted: 2631 Post(s)
Liked 1,983 Times
I've had the same problem with warmers. I plan my morning route to allow for a quiet place to pull over after half a mile, yank them way up, reseat the bibs, and ride on. Sometimes it works, sometimes it doesn't.
Fortunately (for me), I go to tights when it's about 5 degrees colder.
Quoted: 18555 Post(s)
Liked 15,955 Times
Why would you think shorter leg warmers would cause less of a problem? The further under the shorts they are, the more likely they are to stay up.
Bikes: Felt TK2, Felt Z5
Quoted: 943 Post(s)
Liked 20 Times
Was told by my buddy at the LBS that leg warmers are the work of Satan and to not waste my money. Either go shorts or tights depending on the weather.
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
Duct tape works, just make sure you shave first.
Thread Killer
Quoted: 3216 Post(s)
Liked 1,756 Times
Quoted: 4867 Post(s)
Liked 4,019 Times
The answer is two words, really simple and works. Safety pins.
Ben
Ben
So no irritation from the safety pins holding the warmers to the shorts, as opposed to pinning through my thigh?
Maybe put dots of silicone rubber on the inside of the warmers....
Bikes: '00 Koga Miyata Full Pro Oval Road bike.
Quoted: 475 Post(s)
Liked 8 Times
Do leg warmers work pretty well? I was thinking of getting a pair for next fall/winter..
Bikes: Litespeed M3, Trek Fuel EX7, Giant Defy 1
I've never had this issue? Get a size smaller maybe? I've been using the same Pearl Izumi arm and leg warmers for years and they haven't stretched and never fall down. And they don't even have a gripper.
I had same problem with Pearl Izumi leg warmers. Don't have the problem with Ibex leg warmers (and they're more effective, being wool.)
Liked 4,019 Times
Oh, I ride fix gears. Going down a 45 mph hill on a 42-17 will drop any warmers not pinned. Don't believe me? Try it.
Ben
Bikes: 2014 Trek Allant drop bar conversion, modified Schwinn MTN commuter, 2015 Trek 520, Soma ES, Salsa Journeyman, 1980 Trek 414
Quoted: 178 Post(s)
Liked 355 Times
In my experience, if I am with riders who feel it is "leg warmer" weather, it is, in actuality, shorts weather......so take off the leg warmers and enjoy the ride in comfort!
Quoted: 57 Post(s)
I find with knee and leg warmers that I have to pull them up up from the bottom cuff a little after putting them on. Otherwise, they have just stretched up the leg from the bottom, and the tendency is for them to work their way down again so there is no pull from the stretch.
The alternative is, rather than just pull them on from the top, grab a bunch to the bottom cuff, and work up the leg letting go a bit of the fabric every couple of inches until you get to the top.
Of course, if you bought the warmers and have lost weight since then, you might need to go a size lower, or find a seamstress to bring in the tops half an inch or so.
