29er MTB with drop bars/700c road tires
Bikes: S-Works Tarmac, Nashbar CX, Trek 2200 trainer bike, Salsa Casseroll commuter, old school FS MTB
Quoted: 31 Post(s)
Ive got an old 26" set up for banging around.
Been thinking about doing just that to my mtb. I have a Scott Scale 29'er that has only been used for commuting as of late and thought about doing a full Ultegra Di2 drop bar conversion with some smaller tubeless cx tires to make a high end beater. Oh Yeah!!!
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Not exactly what's in the OP but people do CX bikes with MTB wheels/tires or 29'er frames with drop bars and rigid forks all the time for gravel racing.
Tips & Concepts for Gravel Bike Setup | Gravel Cyclist: The Gravel Cycling Experience
-Tim-
-Tim-
On Your Left
Quoted: 3004 Post(s)
Liked 2,434 Times
Voice of the Industry
Quoted: 1188 Post(s)
Liked 8 Times
Almost did it with my 29er below. Geometry just wan't optimal. Bikes designed for flat bars if they fit correctly with flatbar, generally have a 20-40mm longer top tube than a bike designed to fit a given rider with a drop bar. Obvious reason is...hoods protrude forward, drops are lower and farther away from a rider and of course a flat bar is either straight across or has some pull back.
Since I wanted a skinny tire...up to 28c workhorse bike, I decided to build a Spesh Secteur dropbar bike instead and part out the Ti 29er below. Good decision btw. I did like the 29er and road it off road with bigger volume tires and on road with skinnys but all said, I spend way more time on road and prefer a drop bar. Best to choose a frameset designed for a dropbar that fits the wheel size you prefer. Quite a few frames to choose from that are drop bar and can fit a bit larger 700c which btw is the gravel bike genre...basically a drop bar version of a 29er.
Quoted: 2432 Post(s)
Liked 641 Times
Yeah you would have to have a shorter stem but I like short stems. My 17 inch MTB frame has a 22 inch top tube, the effective length is 58 and that's only 1-2cm longer than what I have on my road bikes.
Administrator
Quoted: 12041 Post(s)
Liked 6,833 Times
Excuse me? Why isn't this posted in the mtb forum?
![lol](images/smilies/lol.gif)
Administrator
Liked 6,833 Times
Moved from Road.
Pokemon Master
So... like the new Trek 920 disc?
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 152 Post(s)
Liked 177 Times
I put dropbars on my old 26er MTB to turn it into a commuter. Fine-tuning the fit was kind of arduous, and I wound up using a lot shorter stem than I used with the flat bars. However, once I got it all done and tuned, it's a hoot to ride...I'm really glad I did it. I would think doing the same to a nice rigid 29er frame would work out pretty well, too.
