ksyrium sl front hub play
Old 06-04-16, 11:31 AM
Wested
post-ironic
Wested's Avatar
Bikes: CAAD 12, Lemond Maillot Jaune
Quoted: 75 Post(s)
I have an older (~2010) set of Ksyrium SLs. I noticed some lateral play in the front wheel that contributed to a slight rattle when going over bumps. I tightened the bearing preload adjustment with the special mavic tool such that the play was eliminated, but now there is drag, i.e. the wheel does not spin for more than 20 seconds. I can't seem to find that sweet spot in which there is zero drag and zero play.
Are my cartridge bearings shot? I cleaned them out and re-greased them, but I suspect this could be the problem. In the meantime, I'd rather have a little drag than lateral play, but will this drag actually affect my performance on the road?
Wested is offline
Old 06-04-16, 12:24 PM
Spinz
TCR Advanced SL
Spinz's Avatar
back off your preload adjustment until there is no drag and the wheel is turning without resistance. if there is still play you should replace the bearings. Lp
Spinz is offline
Old 06-04-16, 12:31 PM
Luis G.
Quoted: 23 Post(s)
Sounds like bearings are worn out.
If you have already adjusted to eliminate play and back off a wee bit, and the only way to reduce the play creates drag that means the bearings are off.
Luis G. is offline
Old 06-04-16, 12:47 PM
Wested
post-ironic
Wested's Avatar
Quoted: 75 Post(s)
Yeah... as I suspected. I suppose it's not worth investing in a bearing press, so I'll buy the bearings and have the LBS handle. Thanks guys.
Wested is offline
maartendc
Bicycle Mechanics
16
03-18-19 10:37 AM
spectastic
Bicycle Mechanics
15
04-04-17 10:21 PM
hazben1
Bicycle Mechanics
4
06-29-15 02:00 PM
Ttime
Bicycle Mechanics
3
09-15-12 02:07 PM
flyingKing
Bicycle Mechanics
9
10-24-11 03:26 PM
