150 pounder on Campagnolo Zonda?
Quoted: 5 Post(s)
I'm looking for some real world experience here from riders who are around my weight and ride on the Campagnolo Zondas. Been researching a lot and close to pulling the trigger but i cant shake up the comments about it being too stiff for light riders. I know this is subjective and probably ones body is more sensitive to rough roads than others. I ride mostly the same routes and i know some days everything just feels smoother.
So anyway, any thoughts from owners who are around my weight? Will I get "bumped around" with these wheels? I have the stock RS010 wheels and the only other comparison I have is with 2016 Reynolds Assault SLG. I felt the improvement in ride quality and performance but it didn't feel like $2100 better (that's me in denial so i dont blow $2k on wheels).
TIA!
TIA!
Quoted: 1422 Post(s)
Liked 7 Times
TIA!
TIA!
"Too stiff" wheels is code. It really means "over-inflated tires."
Bikes: 99' Torelli Nitro Express, 90' Miyata 414, 09' Guru Evolo, Eigthinch Scrambler
Quoted: 11 Post(s)
Not 150, but at 170 I really like the ride of my zondas, definitely don't feel overly stiff, and like above might be worth running 25's or 28's if you can manage for a more comfortable ride.
I roll them, and I was 150 when I started riding on them, and I'm down to 145 now which is still pretty near. I've ridden on them for two months, put near 1000 miles on them.
I was concerned when buying them because of the low spoke count and how poor the roads are in Los Angeles, but these wheels are SOLID. I've slammed them on pot holes, over large rocks, taken them over curbs, etc. When I brought my bike in for a tune up, they were still perfectly true the shop said. Very well built wheels.
I will say this, the front wheel is flexy, more than I was used to. Since this was a brand new bike with brand new wheels and component, they only left a few millimeters of space between the the brake pads and the wheel. So when I stood up and put more weight on the front to hammer it out, the wheels would start rubbing on the brakes. I just opened them up a little more and everything is fine.
Quoted: 5 Post(s)
From intheknowcycling.com
"And I don’t recommend the Zonda or Racing 3 for lighter riders; they are noticeably heavier, don’t accelerate as well and the ride will feel harsh for riders under 155lbs/70kg and not terribly comfortable for heavier ones either."
I think it speaks of vertical compliance so when riding over rough roads there isn't much give.
blah blah blah
Quoted: 5 Post(s)
I weigh less than 140 pounds, and one of the wheelsets I ride is Fulcrum Racing Zero, basically the twin to Campy Shamal. They are stiff, but as a lighter rider, I can run less pressure in the tires, typically around low 70/80ish front/rear.
