1st pair of cycling shorts- Not so sure I like!!
Went for short spin with new shorts. 5 miles out and no real prob. The cushioning felt nice, albeit a little awkward. Anyway, took short break and did the ride home at a slightly stronger pace... not even halfway into the ride my boys were NUMB, and remained that way! I've been riding already a dozen or so times, usually 12-22 miles total, and felt my butt/sit bones were already used to the seat/ride distance, and have not had any real trouble with numbness. FYI, I have a Giant Defy 1 and have been using the stock saddle, a Selle Royale Seta. Was kinda surprised because last year on my other bike which is Giant Escape 0 with stock Giant saddle I would get numb on longer rides even after my initial 'break-in' period. After just 5 or 6 rides this season on the Defy, and without padding or any saddle changes, I could go 20 mi. with no problem.
So-O, I thought the padded shorts would help keep me in saddle comfortably and for longer?? Do you think:
A. I just need to go for a few more rides?
B. Possibly they're too small?
C. The padding 'up front' is just jamming my junk and the cause of the lack of circulation? Honestly, I had not realized there would be padding 'up front' too, and while I used to wear 'snug' workout shorts, no where near this.
D. New saddle with cut-out??? (Related to C above) I had been considering this anyway, and have the Selle SMP Extra in my shopping cart already...
Any advice greatly appreciated-
Thanks all, and Happy Trails!
Old fart
Liked 3,675 Times
Could be too much padding. It's somewhat counter-intuitive, but more padding does not necessarily mean more comfort. Padding can move the pressure points from the ischial tuberosities (aka "sitz bones") to more sensitive areas in the perineum. What saddle are you using? Some people find a saddle with a cut-out helps with perineal numbness.
Old fart
Liked 3,675 Times
Perhaps try shorts with thinner chamois? Modern bike shorts are much thicker than traditional bike shorts, but relatively thin chamois are still available.
They do. The cheap ones will have big padding like I'm assuming your current shorts have, which causes issues as you already found out. Quality ones will have much thinner padding, which will work better.
Just joking a bit on the bibs stuff, but the padding thing is true: Less padding works best, or at least it does for me and many others. You could go to a store and try the ones they have see which ones you like. Or if you were not having any issues before, you could just continue doing what you were doing, cycling shorts are not mandatory.
Liked 9,462 Times
If you're talking about your junk going numb, thick, dense padding exacerbates that problem for me, too. Bibs/shorts with thin, flexible padding is what works best for me. Unfortunately, the saddle/chamois combo is just one of those things that you have to work through on your own.
Bikes: Trek 4.0 Domane
Went through this same battle last summer. Bought bontrager mtb padded shorts. Fine for a mile or two then numbness. Happen to get on my bike with cargo shorts to ride into town for coffee. No problem whatsoever. Rode for a hour with just gym shorts and no problem. The second hour my butt was sore. Did some searching on here and bought a good pair of bibs. No more problems since. Have ridden around three thousand miles since February and loving my bibs.
Liked 58 Times
C'mon Pepe. That is just confusing. There is no inherent difference between the padding in bibs and the same brand/model of standard shorts or the way they will affect your 'nads.
OP isn't experienced enough to get the joke if you were pulling his leg...either with regard to riding or posting.
Methinks padded shorts are often used as a "fix" for non-optimal (usually padded) saddle and saddle fit. I've never found them necessary/used them and have never, in 36 years, had an issue/problem.
I have had great luck with Performance Elite for half that price:
Performance Elite Bib Shorts
I also have some Primal Wear that retail for $75 and I got for 50% on one of their sales. Both are comfortable and durable. I have tried some cheap $20-30 bib shorts from China that were also fine in the comfort department but fell apart after 3-6 months so I wouldn't go that cheap. I don't think most people need Rapha or Castelli or what have you
Maybe riding without padded shorts caused your nuts to make two indentations in the saddle for them to rest in, and the padding blocked that off now.
Thanks for all your input guys!!! Went out again today without the padded shorts... honestly, I think the harder/faster I try to go, the worse it gets, and reason being I'm leaned over/stretched out a little more, hence the added pressure. Wondering if I need to either shorten my reach a little or move the saddle forward a pinch more. I noticed when bent over a little more my sit bones were actually off the back of the saddle a bit, and more pressure directly on the 'nether' if that makes any sense.
Bikes: Cannondale CX3, Canondale Synapse Specialized Transition Expert
I'm having fits with the same problem on a Cannondale Synapse. Strange thing is that the seat was the same as the one on my C'dale CX3. I bought the Selle with the cut out, hoping to solve the problem. No help. I'm not wearing bibs or shorts. I'm wearing the cargo shorts with the Chamois. I've adjusted seats until I'm blue in the face and can't catch a break in the "cavity" area. I'm squashing my nads, and after a few minutes I feel like I'm riding a porcupine, in the cavity (sorry, can't remember the medical name for it). I'm going to try to see if I can take it to another bike shop and have them fit it, and see if their fitting makes any difference. I'm a bit to heavy for Bibs, and I really don't see how they are going to save my 'nads. Since I don't have the same problem with the CX3, which seats you mostly upright, I almost have to believe it's the angle of the seat, but I don't know in relation to what. Level, or a bit below level, no difference. I'm losing riding time daily because my nads feeling squashed and burning. Any suggestions would be greatly appreciated.
J.
J.
