Action cam on a Brompton.
Bikes: Brompton and Dahon Curve D3
Quoted: 23 Post(s)
I just ordered the Olympus TG-Tracker action cam. I bought it for use underwater and to mount on the car, but I would also like to mount it on my Brompton. Problem is, all the real estate on the handle bars is used up. Not much there to begin with anyway. The cam can use all the GoPro accessory mounts. I'm wondering what I could use on the Brompton and where can I mount it? Anyone use an action cam on their Brompton?
Cheers
Wayne
Cheers
Wayne
Not me. But How about top of your helmet?
For the Old M Bars they made a brace to span between the uprights..
That may be adaptable. another option to try.
Quoted: 23 Post(s)
Yes, I thought about doing that. I'm heading out to best Buy later and check out some of the accessories. Still like to mount it on the bike though.If not, it will have to go on the brain bucket.
Quoted: 151 Post(s)
Liked 10 Times
Cheers
Wayne
Cheers
Wayne
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
Quoted: 840 Post(s)
Liked 337 Times
That's my situation a while ago. I am still tweaking.
If You have a Dynamo Hub then It has a QR bolt thru a Hollow axle
and You Can substitute the threaded end cap for a piece that is threaded but has a Tube
to mount a Camera Using a Bar Mount down there . Standard Brompton 8mm Nut axle
and that is not so simple.
Quoted: 9 Post(s)
I'm sure bikegang has a solution for you. I have an older bottle mount with gopro adapter on top. There is probably a simpler, updated version that could meet your needs.
Raleigh20 PugFixie, Merc
I would find a way to mount it to the front bag mounting boss
My Raleigh Twenty site | foldr : A flickr pool | #6460, #5632 & #3407 on the fixedgeargallery
Quoted: 23 Post(s)
Cheers
Wayne
Quoted: 23 Post(s)
Cheers
Wayne
Quoted: 151 Post(s)
Liked 10 Times
I think I figured out how to mount the cam on the handlebars by using a small GoPro type adapter that will fit on the bottom of my Quad Lock out front mount. But I also like the idea of mounting the cam like what is shown in the video clip. I'm not sure how that is achieved and what part I would need and where to actually place the mount. Could you advise me on that Please?
Cheers
Wayne
Cheers
Wayne
21 DIY Bike Camera Mounts - BikeHacks
Camera Would stay pointed straight ahead rather than swinging with the steering .
For pro looking video, Make a steadicam like rig so image won't appear to Bounce, either.
https://en.wikipedia.org/wiki/Steadicam
Quoted: 23 Post(s)
Quoted: 23 Post(s)
LET'S ROLL
Polaroid CUBE mounted on the fork facing backwards:
ContourGPS mounted by the rear triangle:
ContourGPS mounted by the seatpost and fork(facing forward):
One day: www.youtube.com/watch?v=20X43026ukY&list=UUHyRS8bRu6zPoymgKaIoDLA&index=1
Bikes: 2011 Origin 8 Bully, 2010 Dahon Silvertip, 2016 Respect Mini Velo
Quoted: 20 Post(s)
Quoted: 23 Post(s)
An update on my action cam used on my Brompton. I received the Olympus TG-Tracker, but I'm so very disappointed with it. The IQ is not good at all, and on top of that there was an issue with some sort of ticking/static noise when I played back a video I did while riding.
I'm in the process of sending it back. Any ideas as to what is causing this unusual noise?
Cheers
Wayne
Cheers
Wayne
