7 speed/8 speed freewheel/cassette compatibility
Quoted: 1873 Post(s)
Liked 693 Times
Ok try to follow me on this one. I have a nice set of wheels with a tricolor 7 speed cassette freehub. I tried putting an 8 speed cassette on it but it didn't fit, so I took off the smallest cog and made it a 7 speed cassette, it fits fine. I would like to use these wheels on a bike that has 7 speed Suntour alpha components, including a 7 speed freewheel.
If I threw on the tricolor wheels would the Suntour indexing work? (And don't say try it, the bike in question is currently stripped down for an overhaul.)
I guess the only question is.. is the spacing between the 7s freewheel the same as the one-cogless-8s cassette? (I don't know if the spacing between 7 and 8s cassettes is the same or not, my suspicion is yes they are the same.)
2019 Salsa Warbird
2019 Salsa Warbird
Extraordinary Magnitude
Quoted: 2609 Post(s)
Liked 1,709 Times
The trick is partially the spacing.
My understanding is @ Accushift plays by different rules than regular Accushift.
Regular Accushift 7 and 8 speed has non standard spacing between cogs. It's not the same space between all cogs.
Do a search for "mrmw centurion hawk" It contains some really good Accushift info.
FWIW- I have 1 bike running Accushift 6 speed shifters and derailleurs on a 5 speed freewheel, as well as 2 6 speeds using Accushift shifters and derailleurs with a SIS freewheel. And of course, the crowning jewel of SunTour shifters with an SIS indexing ring on a 10 speed setup.
Commence to jigglin’ huh?!?!
Bikes: Bianchi San Mateo and a few others
Quoted: 634 Post(s)
Liked 13 Times
And that's without bringing SunTour into the equation. Like The Golden Boy said, SunTour Accushift indexing used irregular cog spacing -- the cogs were slightly closer together at one end of the cluster. Some people claim to have mixed Shimano and SunTour drivetrains with varying levels of success. Some say it works, some say it kinda works.
If you were going to try this, I'd suggest to make sure you're using a rear derailleur with a floating upper pulley (e.g. Shimano Centeron), which may be more tolerant of the variables in such a mixed system. Even then, I don't know how confident I'd be that you'll wind up with a bike that shifts flawlessly.
Liked 1,709 Times
According to Sheldon Brown, spacing on a Shimano 7-speed freewheel or cassette is 5.0 mm and spacing on a Shimano 8-speed cassette is 4.8 mm. They're close, but not the same. I'd expect shifting to work well in one part of the gear range, but the further you stray from that workable range, the poorer shifting will get as each cog further away is an additional .2 mm off.
I should have been more specific- 6 speed Accushift is spaced the same as SIS 6 speed, the same as 5 speed. But the cable pull is different- you have to match SIS with SIS and Accushift with Accushift. But at 7 sp, it's possibly fudgeable to change the cable pull on an SIS unit by using the alternate cable routing, and then the Centeron pulley does the rest of the fudging.
Liked 693 Times
I'm surprised to hear you say that Accushift uses wonky spacing in the freewheel, I was under the impression that all 7s speed freewheels were essentially standardized and brand independent.
2019 Salsa Warbird
2019 Salsa Warbird
Liked 693 Times
Yes!
2019 Salsa Warbird
2019 Salsa Warbird
Nigel
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Quoted: 384 Post(s)
Liked 6 Times
First: get some calipers so that you can measure yourself. The 6" ones that HF often has on sale for $10- are fine.
Then using Sheldon Brown, and other resources, you can determine how to build a custom cassette that will have the spacing and gearing that you want.
Liked 693 Times
I actually already have digital calipers and will measure tonight. I had no idea that Suntour cog spacing wasn't uniform so I didn't think to measure it last night when I had it all out.
2019 Salsa Warbird
2019 Salsa Warbird
working on my sandal tan
Quoted: 3873 Post(s)
Liked 2,574 Times
I've got some extra 7-speed Shimano spacers if you'd like. Per Sheldon, they should be 3.15mm thick, but I don't have a good way to measure them that accurately.
Liked 693 Times
Ok cool man thanks, I'll let you know once I figure all this out.
2019 Salsa Warbird
2019 Salsa Warbird
Liked 1,709 Times
I didn't see if you actually noticed it (because I used @ instead of "Alpha") but Suntour Alpha Accushift is different than Accushift.
I think it's that Alpha shifters must be paired with Alpha derailleurs, but I don't know if there were special Alpha freewheels.
Freewheel Medic
Quoted: 1465 Post(s)
Liked 2,227 Times
Not certain if this helps, but I have worked on Suntour freewheels which were marked with "Alpha."
Bob
Bob
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
+1. Lots of good points in that post, but this one was near the end so I quote it just in case anyone missed it.
Liked 693 Times
https://bikecatalogs.org/SCHWINN/1989...89_Ltwt_16.jpg
2019 Salsa Warbird
2019 Salsa Warbird
Liked 693 Times
What I'm reading about 7 speed Suntour spacing doesn't seem to jive, I must be missing something.
This is from mrmw:
and this is what I've found elsewhere:
"For 7 speed, the top 2 spacers are
3.3mm (some of them are even labeled "3.3mm 2nd position"), the bottom 4
are 2.8mm, and the cogs are 1.9mm thick, for an average of 4.87mm."
Taken from here: https://groups.google.com/forum/#!to...ch/A-N4DrtpISo
and https://sheldonbrown.com/gloss_sp-ss.html#spacingk7
This is from mrmw:
2019 Salsa Warbird
2019 Salsa Warbird
Bikes: 89 Schwinn 754, 90 Trek 1100, 93 Trek 2300, 94 Trek 1400 (under construction), 94 Trek 930, 97 Trek 1400
Quoted: 29 Post(s)
I don't get what you're trying to do. Why would you try putting an Shimano 8-speed cassette on a Shimano 7-speed freehub, with SunTour 7-speed Edge shifters (and derailleurs?)?
I actually tried this to see what would happen as I was upgrading my Trek 1100 from Suntour Edge 3 X 7 shifting to Shimano 3 X 8 shifting. I got the Suntour Edge Shifters and derailleurs to work with a Shimano 7-speed freehub and cassette, then switched to a Shimano 8-speed freehub with 7-speed cassette and spacer (still working), and then switched to Shimano 3 X 8 downtube shifters, and 8-speed cassette and eliminating the spacer on the freehub.
I'd say that you can get the Suntour Edge 7-speed downtube shifters and derailleurs to work with a Shimano 7-speed freehub and cassette. It will not work as smoothly in Index Mode as Shimano 7-speed Index shifters, because of the difference in the way that Suntour shifts (non-linear) but it will work.
You can also used the Shimano 8-speed cassette on a Shimano 7-speed freehub wheel. BUT YOU WOULD HAVE TO REPLACE THE 7-SPEED FREEHUB BODY WITH AN 8-SPEED FREEHUB BODY (ABOUT $10-$15). Then you would need to get a set of 8-speed shifters, if you use 8-speed Index shifting.
If you are going to go with friction shifting, you can use the Suntour 7-speed Edge Shifters with the Shimano 8-speed cassette and all 8 cogs, but you will still need to change to the 8-speed freehub body. If you don't mind friction shifting, all you need to buy is the 8-speed freehub body.
Quoted: 413 Post(s)
Liked 109 Times
Cody....7s Tri-color is built on a 126mm hub with a shorter freehub body than 8s. 8s cassettes will only slide on if you remove one of the cogs.
Keep this in mind when mix n matching Shimano and Suntour and Campy..... Chevy wheels do NOT fit Fords.
Quoted: 413 Post(s)
Liked 109 Times
For ACCUSHIFT index shifting use only SUNTOUR WINNER, WINNER PRO. or ALPHA freewheels of Regular (standard width) 5 and 6 speed type or Ultra (narrow) 7 speed type.
N.B. Ultra 7 speed WINNER and WINNER PRO will only give index shifting when used with SUNTOUR IPC levers (SL-IPOO) with mode switch set in the 'UL' position
riders can easily mix'n'match throughout the AccuShift range.
The Infractionator
Bikes: Classic road bikes: 1986 Cannondale, 1978 Trek
Quoted: 875 Post(s)
Answers:
I've done 7-sp with 8-sp shifters: What should work is adjusting you derailleur PERFECTLY on the center cog, and let the pulley float take care of the rest.
As far as that graphic goes...larger cogs are thicker down by the splines.
Quoted: 801 Post(s)
Liked 1,816 Times
Based on a couple of bikes I have had I can say the 7 speed edge group is Alpha type and will work fairly well with 7 speed Shimano spaced freewheels cassettes have 5.0mm spacing, the Sachs LY freewheels were a pretty common replacement in the 90's. They won't quit work right with a 7 of 8 setup which gives you 4.8mm spacing leaving you about 1.5mm off at the end of a 7 speed shift range, which is just bit too much for indexing.
Sheldon Brown's Bicycle Frame and Cassette Spacing Crib Sheet
Liked 693 Times
Well I put the bike all back together and put on new cables and housing.
Verdict: The 7s Suntour freewheel indexes ok. I have to massage one of the cogs sometimes but it's not bad.
The 8s-turned-7s shimano cassette shifts awesome! Smooth, quick, and quiet every shift. Like it was made for it.
So with that in mind, if I need to get a new chain which one should I get?
I just had to deal with a accushift problem on a Trek. I solved it with different shifters and a Shimano freewheel, just because those were the parts we had sitting around.
-SP
-SP
bobotech
Bicycle Mechanics
13
03-06-12 01:48 AM
mtnbke
Classic & Vintage
7
02-28-11 04:06 PM
