rustoleum paint and primer all in one for frames
Old 03-06-17, 05:18 PM
TreyWestgate
Bikes: motobecane outcast 29er singlespeed and nashbar singlespeed road bike
Quoted: 96 Post(s)
In my last post I mentioned how my aluminum mountain bike was getting some bubbly white patches and how if that was the end of it or not.
So since everyone believed that it could still last a good while more, I got this in the closest color I could to the original frame color.
https://www.rustoleum.com/product-catalog/consumer-brands/universal/universal-hammered-spray-paint
is this stuff any good on a bike?.
hope it will actually stay on the frame and protect it from more corrosion.
it says it will work on aluminum so that may be the best I can get that is affordable.
the real first question will be when will the horrible smell go away?!.
should I apply another layer later or will one do it?.
from a distance the bike looks better and not like it did before.
TreyWestgate is offline
Old 03-06-17, 05:44 PM
02Giant
Quoted: 1638 Post(s)
Liked 741 Times in 495 Posts
Preparation is the key to a successful paint job. The number of coats is related to how well each coat covers.
nine mile skid on a ten mile ride
02Giant is offline
Old 03-07-17, 12:18 AM
Western Flyer
Western Flyer's Avatar
Bikes: Cannondale Topstone gravel bike Dahon MU folder w/2x8 speed internal drive train
Quoted: 59 Post(s)
Liked 7 Times in 6 Posts
Rustoleum sells a clear coat which will give all your work a glossy finished look and help protect the paint.
On a trip you've got worry as a companion, for you're always concerned about what happens next and sticking to an itinerary. . . . on a journey you never have to worry. Something always happens next.
- Gordon Hempton: One Square inch of Silence
Western Flyer is offline
Old 03-07-17, 01:27 AM
Rollfast
What happened?
Rollfast's Avatar
Quoted: 1835 Post(s)
Liked 292 Times in 255 Posts
I hope you sanded well, and you should have used their rust converting primer where needed first IMO. If that's what it is, fine.
Painting the handlebars and all was a bit cheap.
Rollfast is offline
Old 03-07-17, 07:22 AM
Road Fan
Road Fan's Avatar
Quoted: 1869 Post(s)
Liked 666 Times in 508 Posts
His frame is aluminum. Aluminum oxidizes, but it does not rust. Would the rust converter do any good?
I'm wondering it it was actually bare aluminum, or was there a factory coating of some sort that is actually what the Rustoleum is trying to adhere to?
Road Fan is offline
Old 03-07-17, 08:48 AM
MNBikeCommuter
MNBikeCommuter's Avatar
Bikes: Cannondale '92 T600 '95 H600 '01 RT1000
Quoted: 92 Post(s)
Liked 109 Times in 82 Posts
I've been using Rustoleum on my '95 Cannondale hybrid for years. It's my winter bike and hence sees a lot of salt in Minnesota. When the bubbles appear, I just scrape them off and paint over them without a lot of frame prep. With a gloss black original paint job, Rustoleum's gloss black is a nice match. I apply the primer and black with a brush, not being too concerned about appearance. It's a working bike with 23k hard miles.
MNBikeCommuter is offline
Old 03-07-17, 10:12 AM
2cam16
2cam16's Avatar
Bikes: TRIMMED DOWN THE HERD
Quoted: 1095 Post(s)
Liked 947 Times in 605 Posts
Prep it good and the paint should hold. Take your time, don't rush your coats. Clear coat it at the end.
2cam16 is offline
Old 03-07-17, 11:28 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,357 Times in 863 Posts
Air dried paint is never 'that' durable, a catalyst is part of the more durable stuff.
fietsbob is offline
Old 03-12-17, 08:50 PM
Rollfast
What happened?
Rollfast's Avatar
There you have it, aluminum in my life is for pop cans and light campers and trailers. Maybe the welds oxidize.
Rollfast is offline
Old 03-12-17, 09:16 PM
Gresp15C
Gresp15C's Avatar
Quoted: 1062 Post(s)
Liked 665 Times in 421 Posts
Is there anything that a DIY'er can apply, e.g., from a rattle can?
Gresp15C is offline
Old 03-13-17, 03:50 AM
02Giant
There are 2k aerosol can products available. The can has two chambers one of contains the hardener that is released and mixed prior to use.
As an example; 2K Aero-Spray? Paints ? Aerosol Paints & Coatings - Eastwood
02Giant is offline
Old 03-13-17, 06:02 AM
OldTryGuy
Quoted: 1070 Post(s)
Liked 802 Times in 509 Posts
I switched to Krylon. Spray Paint | DIY, Craft & Professional Spray Paint Products | Krylon
OldTryGuy is offline
Old 03-13-17, 10:18 AM
duane041
Junk Collector
Bikes: 1987 Schwinn Circuit, 2012 Colnago M10, 1990 Schwinn CrissCross
Quoted: 34 Post(s)
These products work great, but if used, please remember to wear a mask and cover all of your skin. Most of the hardeners/catalysts in products like these contain isocyanates, which are attracted to moisture (i.e. YOU). Covering your hands, face and arms is very important, as is wearing a proper respirator.
On the plus side, they do work very well, and the clears can be polished out just like automotive clear coats.
duane041 is offline
Old 03-15-17, 02:33 PM
jfowler85
jfowler85's Avatar
Bikes: '93 911 Turbo 3.6
Quoted: 109 Post(s)
https://www.rustoleum.com/product-ca...ed-spray-paint
Do a proper two or three stage job. Primer, paint, clear coat. The last two steps can be combined. The key is to use remove as much old paint as possible, and use numerous coats of etching primer with plenty of progressively finer sanding in between coats. After painting several old frames with many types of paint, including from a spray can, I can attest that hand painting with a 2/3 stage process is the most cost efficient, less messy, and gives great results.
If you're less concerned with quality then try rattle canning with art-quality cans.
To answer your question, yes the smell will eventually off-gas, and yes it is probably fine for the frame.
jfowler85 is offline
Old 03-15-17, 02:49 PM
EnjoyinTheRide
Its all about the cruise
EnjoyinTheRide's Avatar
Bikes: 2014 Huffy Cranbrook , 2017 Huffy Classic Deluxe, 1972 Raleigh LTD 3
Quoted: 85 Post(s)
Liked 4 Times in 3 Posts
Rustoleum works on everything....
EnjoyinTheRide is offline
CrowSeph
Framebuilders
3
09-20-17 03:56 PM
bfloyd6969
Bicycle Mechanics
3
04-25-12 10:24 PM
ramseykp
Framebuilders
22
01-24-12 02:01 AM
Fred Smith
Bicycle Mechanics
3
11-23-10 12:35 PM
elstepho
General Cycling Discussion
10
09-09-10 10:24 AM
