Rear hub changing, related questions...
Liked 3,157 Times
Rear hub that I'm eyeing up is the Shimano Deore XT FHM756L.
Wheel being fitted with the above hub is the stock Bontrager AT750 double walled 32 hole wheel fitted with the
Shimano HG31 11-32 cassette & 160mm rotor.
Any insight as to what I should be expecting regarding spokes? Has this been done and the spokes needed are already identified for procuring them right the first time?
Thanks Bikeforums!
Thanks Bikeforums!
-Oh Hey!
-Oh Hey!
Quoted: 86 Post(s)
a little research should turn up a number of spoke calc type programs on the web. they run the gamit, IME, from useless to pretty good.
best to get ERD and spoke count of rim and a couple of measurements WRT the hub. spoke hole diameter, number of spokes, flange offset from center of OLD. it will become apparent what is needed when perusing spoke calc websites.
Liked 3,157 Times
What I've found on the hub-
Light alloy QR lever and nut
Model Number: FH-M756
Series: Deore XT
Over Locknut Dimension: 135mm
Spoke Holes: 32H
Spoke Interface: J-Bend
Cassette Compatibility: Shimano/SRAM 8/9-Speed Mountain
Center to Flange: 20mm R / 33.5mm L
Flange Diameter: 61mm R / 61mm L
Brake Compatibility: 6-Bolt Disc
Quick Release (QR): Yes (included)
Wheel info that I have and could find is just the "Bontrager AT750 double walled 32 hole"
Series: Deore XT
Spoke Holes: 32H
-Oh Hey!
-Oh Hey!
Quoted: 454 Post(s)
Liked 104 Times
Why? the Shimano 756 nice as they are, are very heavy hubs, add to that, you will need to rebuild the whole wheel, if you really want to get a wheel with a 756, would keep your Bonty wheel as is/sell it, and get a complete wheel built round the 756/buy a new rim/spokes (you would need these for a rebuild anyway) and build it round a 756..
Really Old Senior Member
There's a good chance your existing hub is similar enough to the new hub that you can use the same length spokes.
Measure the PCD of the spoke holes and compare. You can fabricate a simple 'notch" gauge out of a piece of cardboard.
CTF dimensions won't be that far off. They only affect spoke length in a ratio of about 10:1. 10mm CTF difference = about 1mm spoke length.
Shop around. Often you can buy a complete wheel for less than the cost of individual parts.
Quoted: 86 Post(s)
Series: Deore XT
Spoke Holes: 32H
Series: Deore XT
Spoke Holes: 32H
Liked 3,157 Times
A new wheel assembly would cost at minimum 150, and it might be no better in reliability then the Formula brand that it is now.
-Oh Hey!
-Oh Hey!
Expired Member
Quoted: 3805 Post(s)
Liked 5,808 Times
Sounds as if you are committed to a plan and are good to go. Let us know how it turns out.
Liked 3,157 Times
Not fully committed, have yet to pick up the hub and then set aside funds for lbs services. Until that is able to be justified, I'd need to ensure these parts all will marry together without any issues.
-Oh Hey!
-Oh Hey!
