Small hairpin clip, where to get?
Bikes: Soma Double Cross Disc (2017), red Hardrock FS (circa 1996)
Quoted: 219 Post(s)
Liked 155 Times
Hi
Very stupid quesion: I have lost the hairpin safety clip which prevents pad retaining bolt from unscrewing on TRP Spyre. TRP has bolt/clip assembly for >$10 here: https://www.trpcycling.com/product/pad-retaining-pins/ (It has the picture of the pin and the clip.) In addition, Spyre one is out of stock, so one can only buy a HY/RD pin/clip for the sake of the clip. That is a bit expensive
I thought it would be possible to get such generic part elsewhere. I asked at a hardware store and auto shop, they did not have it. The length of the clip is 11mm, inner size at the point which contacts the groove in the bolt is 2mm.
I understand that an alternative solution would be to loctite the threads.
Thanks for any help.
Quoted: 263 Post(s)
Liked 10 Times
Pickup a some piano wire at a hobby shop and make one with needle nose pliers. A R/C hobby shop may have a clip close enough to use.
Quoted: 863 Post(s)
Liked 1,113 Times
Try a motorcycle shop. Many MC's use that type of clip for brake pad retention as well. If the parts counter doesn't stock them go around to the service department.
Quoted: 219 Post(s)
Liked 155 Times
Thanks for all the help!
Very helpful search, grainger.com has some similar clips, they have a shop nearby.
Sorry, is R/C for "remote control"? Not sure about the piano wire, can it be bent so that it keeps its shape under stress? The pin I have does not have a hole but rather groove. I actually thought about getting a piece of some soft wire, wrapping it around the groove and twisting the lose ends together. Not reusable but who cares
Will ask them.
Will ask them.
You can definitely get them here:
https://www.mcmaster.com/#hairpin-clips/=1abhf5i
Though at that size the minimum quantity is 100!
About $10.
About $10.
aka: Dr. Cannondale
Quoted: 2175 Post(s)
Liked 3,532 Times
I have a bunch of radio control car body clips; one of them should work for you. E-mail me your address at rccardr@cox.net and I'll send some to you in an envelope.
Quoted: 716 Post(s)
Liked 807 Times
It looks like an E-clip would be a more appropriate retainer for that type of pin. https://www.mcmaster.com/?error_redi...clips/=1abmcy3
Quoted: 2027 Post(s)
Liked 1,099 Times
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
They might have them in the fastener drawers at Lowes.
Quoted: 863 Post(s)
Liked 1,113 Times
It just dawned on me that no one has mentioned just going to a bike shop. There's a good chance they may have some of these in stock. Should also add that as the OP mentioned just some locktite on the threads will be fine. I run these type of retainer bolts w/clips on my motorcycles and have never had one start to back out even without the locktite and that includes racing which puts them through massive stresses.
Found this multi-pack/assortment at Napa Auto, $3.75 (US). I also own the TRP Spyre post-mount mechanical disk brakes. These will fit, but I can't speak to corrosion resistance (yet).
There are two in the package, in addition to some very small r-shaped ones that would work in a pinch (temporarily).
I am new, so I am not allowed to post a link for you yet, by policy. Just go to Napaonline and search for part: NOE 7352657
Droid on a mission
Quoted: 320 Post(s)
Liked 288 Times
Check with an Ace Hardware better selection then home Depot or Lowe's for that type of part.
Bikes: 201? Specialized Secteur Triple, 2017 Specialized Diverge A1, 2018 Specialized AWOL
Resurrecting this thread because I lost one of these pins (probably forgot to put it back on, then swept up the work area afterwards). Others have mentioned they're probably not necessary, but I can't help myself.
I went to a bike store (Mike's Bikes) and checked with the service department. They seemed like they've never heard of such a thing. I suppose if I brought a pin with me to show them, they'd maybe know what I'm talking about.
Thanks for this - I just ordered a pack.
Really Old Senior Member
Just Google hairpin hardware
to see how it's a common item.
Likes For Bill Kapaun:
Quoted: 1167 Post(s)
Liked 1,277 Times
Hi
