Help MTB frame 1989 identification ?
Quoted: 12 Post(s)
I buy a frame set of bikes. I just want to know what type and brand
For my bike. I just know tube ovesize and fork cromoly.
Can u help identification my frame bike thanks. @T-Mar
Quoted: 12 Post(s)
Frame bike mtb identification?
Can u help identification my frame bike thanks. @T-Mar;
Forum Moderator
Bikes: Fuji SL2.1 Carbon Di2 Cannondale Synapse Alloy 4 Trek Checkpoint ALR-5 Viscount Aerospace Pro Raleigh C50 Cromoly Hybrid Legnano Tipo Roma Pista
Quoted: 3130 Post(s)
Liked 6,805 Times
Duplicate threads merged.
Please do not Cross Post.
Quoted: 12 Post(s)
Quoted: 4722 Post(s)
Liked 3,048 Times
I don't know the identity but the serial number may indicate 1989 manufacture. The presence of a kickstand plate is typically an indicator of a entry level model and this one is crooked. Installing a kickstand could interfere with the rear derailleur cable. If you remove the fork, there may be the fork manufacturer's name, a date code and an alloy designation. Another good indicator of frame level is the diameter of seat post required.
Quoted: 12 Post(s)
Quoted: 12 Post(s)
Whatever it is, I see no value here. Low end, as TMar pointed out with the cheap kickstand plate. Missing original paint and decals, poorly rattle canned. From that era, even pristine MTB frames don't have much value, except for a handful of top of the line models. This one is neither pristine nor top end.
If you have a donor bike, it would make a great college bike!
RD frame mount hanger puts this one above the box store models for sure.
thank you for identification my bike wrk
Thrifty Bill
Quoted: 1247 Post(s)
Liked 1,002 Times
The markings are very generic. Then you have the fact that a lot of name brands that made some of their bikes, had bikes made by others. So is a Schwinn made by Giant a Giant or a Schwinn? Then you have all the private label bikes from that era, sold by chain stores like REI and others, that never made a single bicycle.
At best, your serial number MAY give a glimpse into who made it. It will not tell you model or brand that it was sold under. I have many, many bikes made by others, like Panasonic built Schwinns, Miki built Sakai, goes on and on. So the serial numbers on those bikes all represent the actual maker, and not the brand or model that the bike was sold under.
If its a private label bike, no one is following those brands, and you will not find repop decals for them.
Quoted: 12 Post(s)
, i become a little understand what is serial number. do you know something about my frame maker? I hope to get help from you and all. thank you
Quoted: 113 Post(s)
Liked 16 Times
Given you've exposed original paint on the bottom bracket, I suggest you use some aircraft stripper to peel the white paint, you may find logos or shadows of old decals underneath.
1 Super Record bike, 1 Nuovo Record bike, 1 Pista, 1 Road, 1 Cyclocross/Allrounder, 1 MTB, 1 Touring, 1 Fixed gear
Thrifty Bill
Liked 1,002 Times
Compare your serial number to TMar's database. Thats your best shot. Still won't tell you the model. And there are only limited catalogs on line. You are going to have to invest some time into this process and even then, you may never know. Generally, if you want to know brand and model, you are better off finding a frame that has not been repainted.
Please don't confuse ebay "asking" prices with "selling" prices. Many sellers never get their ask price. some are far from it. Value is determined once an item actually SELLS. Its easy enough to check SOLD prices.
Quoted: 12 Post(s)
i need help @T-Mar;
Le Crocodile
Quoted: 370 Post(s)
Liked 793 Times
90% sure that is a Giant made bicycle. As posted above, who knows what brand it sold as.
I am tuning up my girlfriends bike right now that she purchased brand new in 1991(?), and besides the kickstand plate, it's identical. Even the stem and headset.
It is labeled as "Main Tubes Cro-Moly".
Her bike is a Giant Rincon SN GVO 522XX
Quoted: 12 Post(s)
Quoted: 12 Post(s)
how to use manual method. in order for this white paint to peel? Thanks for ur recomended cycloto
I have had good luck with using Lacquer Thinner and scrubbing at the down tube and top tube to get the top layer of paint off to see what brand frame it was.
Quoted: 113 Post(s)
Liked 16 Times
However, using thinner and steel wool might be a bit easier and less risky, so you could try that first.
Quoted: 12 Post(s)
You can buy it at your local auto parts store. It's nasty and will take everything off, but if you do a short duration application as described on the can I am sure you can just pull the white paint an see what is underneath.
Quoted: 12 Post(s)
Liked 3,048 Times
Quoted: 12 Post(s)
Liked 3,048 Times
Quoted: 12 Post(s)
