BB386EVO crankset compatible with CK ThreadFit 30 BB?
Old 05-13-18, 09:09 AM
aggiegrads
Quoted: 336 Post(s)
Liked 309 Times in 180 Posts
I have a frame with a 68mm BSA BB shell. I ordered an FSA Adventure crankset with a BB386EVO spindle designation.
Is the Chris King ThreadFit30 BB compatible with the crankset? As far as I can tell, the 30mm spindle diameter Is the same, but I can't find a width designation for the CK BB and there is no conversion kit.
has anyone installed a similar combination?
aggiegrads is offline
Old 05-13-18, 09:20 AM
Marcus_Ti
FLIR Kitten to 0.05C
Marcus_Ti's Avatar
Quoted: 2349 Post(s)
Liked 406 Times in 254 Posts
Why spend $200USD on a BB...when the FSA BB386 BB is available in BSA for $50USD on Amazon Prime?
I have no clue if the 30mm BB from CK can be shimmed to work or no...I suppose it could perhaps. CK does a (terrible) job telling consumers what their system works with.
Marcus_Ti is offline
Old 05-13-18, 09:22 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Liked 1,358 Times in 864 Posts
You could ask CK themselves, you can almost walk in there , but try the Phone on Monday.
fietsbob is offline
Old 05-13-18, 09:42 AM
aggiegrads
Quoted: 336 Post(s)
Because the overall cost is cheaper if I have to replace the less expensive one every season. I have two cross bikes - one with about 5000 miles that is on the fourth or fifth set of 6806 bottom bracket bearings - I have lost count. The other has about 12,000 miles and is on the original CK BB. I have not done a thing to the BB other than hose or brush it off when it gets dirty. I have put well over $200 into the "inexpensive" BB, and the CK is only $150 for me.
I trust CK, they are made in the USA, I am from Portland, this is a "dream build", I can afford it, and I don't have to listen to your opinion about by BB when I am riding.
My post was looking for facts, not opinions.
Old 05-13-18, 09:54 AM
fietsbob
Bikes: 8
As I said Being so close, you can almost walk there ,, Tri Met Bus can get you to their door.
Chris King Precision Components / Cielo Cycles
2801 NW Nela St.
Portland, OR 97210 USA
1-800-523-6008
fietsbob is offline
Old 05-13-18, 10:17 AM
aggiegrads
Quoted: 336 Post(s)
2801 NW Nela St.
1-800-523-6008
Thanks. I have been there before; they have a pretty impressive operation. Not exactly close to where I live, but I will call them tomorrow.
Old 05-13-18, 11:53 AM
Marcus_Ti
Marcus_Ti's Avatar
LOL. Obviously.
I could point out you're not the only one to use thopse bearings...I could point out that you're not the only one who builds dream bikes...and I could point out I have that exact bearing in my Di2 gravel bike and it is has 4,900 miles on it as of this weekend...But obviously you're in a snit and want to spend money. So have a nice day.
Old 05-13-18, 06:57 PM
aggiegrads
Quoted: 336 Post(s)
LOL. Obviously.
So we all have our own unique values, and different opinions on reliability and what components that we would spend money on. I wouldn't put Di2 on a gravel bike (and especially not a 'cross bike) due to the cost, but it is good to know that it works for you and that the technology has evolved to the point that it is so trustworthy. My bikes are steel, have steel forks, wheels made of metal, and no batteries outside of GPS. I don't spend money on carbon rims, electronic shifting, ceramic bearings, or top-end groupsets, but I will spend money on things that are difficult to manufacture like headsets, hubs, and BBs (think: Phil, CK, White Industries). An expensive bike (to me) is anything North of $4k. $10k for a bike is crazy talk.
My initial response crossed the line, and for that, I apologize. I appreciate you taking the time to respond.
Old 02-23-19, 08:03 PM
lynch.cr
lynch.cr's Avatar
Bikes: 2014 Trek Domane 5.2c, 2015 Niner BSB 9 RDO, 2006 Scott Speedster S30
Just to provide the answer, I contacted Chris King and they said no. The spindle is just a little too short to make this work. I have the same crankset and had to end up using the FSA BB. I had one from Real World Cycling and the spindle was too short so it confirms what the Chris King rep said.
lynch.cr is offline
Old 02-24-19, 08:09 AM
aggiegrads
Quoted: 336 Post(s)
Agree. I took a ck bb off of another bike and used the FSA crank and it wouldn’t get close to recommended torque before binding the bearings.
It it is a shame. I have all the tools for the CK already. So I had to buy a special tool for the FSA BB along with the brackets themselves.
Old 03-21-19, 09:58 PM
tranqwill_80
aggiegrads, do you know if your crank was the FSA SL-K modular crankset? The modular system is claiming to help fit a wide variety of bb frames.
tranqwill_80 is offline
Old 03-22-19, 01:17 PM
aggiegrads
Quoted: 336 Post(s)
No, mine was the Energy (aluminum, not Carbon). The dimensions should be the same however.
I do not dispute the claims that they can be used on a wide variety of frames, My only complaint is that you have to use the crank with their BB due to the length of the spindle, which makes it effectively proprietary.
Old 03-22-19, 01:31 PM
HillRider
Quoted: 2026 Post(s)
Liked 1,096 Times in 742 Posts
Given your good experience with CK's bottom brackets, is there another suitable crank that would work with it? Might be cheaper to change the crank than to replace bottom brackets that frequently.
HillRider is offline
Old 03-22-19, 01:53 PM
aggiegrads
Quoted: 336 Post(s)
I put a White Industries crank on my 30mm CK BB, but certainly not as a money-saving decision.
I am happy enough with the Shimano crank offerings in 24mm, I would use their cranks unless they didn't offer the gearing I wanted. There is a gap where the smallest inner ring goes from 34 (road compact) to 28 (Mtn double) and the smallest outer foes from 46 (Cyclocross) to 38 (Mtn), where my ideal would be something like a 30 inner-42 outer. This was what led me to White Industries, which allows just about any gearing combo on a double.
raria
Bicycle Mechanics
15
10-06-17 09:41 AM
e30jean
Singlespeed & Fixed Gear
9
04-04-16 08:02 PM
Tavish
Bicycle Mechanics
1
04-09-12 03:04 PM
Sevalecan
Bicycle Mechanics
3
09-15-11 02:04 PM
Mac2131
Bicycle Mechanics
2
02-06-10 01:43 PM
