Need a small, cheap computer that will auto-sync Strava.
Any ideas?
All I need is cadence and distance. Must work with Ant+ sensors.
Just need something to show me the time as I commute so that I know when its time to make the turn and head to the office in the morning.
Quoted: 7359 Post(s)
Liked 2,497 Times
You can run the strava app on your phone. You'll need a good mount if you want to see it as you ride. Don't skimp on a mount.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
I was going to suggest "Ride Report" android app, because it automatically detects when you're riding and syncs it to Strava. You don't have to start the app, touch a button on the app or anything else, it just runs hidden and does it.
But that doesn't provide cadence distance and speed. I think if you want all that plus auto syncing to strava, you won't find it in a cheap bike computer. Plus, it's going to need network connectivity of some sort to talk to Strava, and if you have to take it off and plug it into a USB cable every ride, that's not very automatic. Maybe there's a Garmin model, but not cheap. My suggestion is to use a cheap wired computer for candence and speed, and use the phone for Strava.
Disco Infiltrator
Quoted: 3130 Post(s)
Liked 2,111 Times
ELEMNT Mini looks likely, it has all the functions you want, but you’d want to look up just how much of its data syncs to Strava.
EDIT: Here’s a thoughtful and thorough review on a site with lots of them
https://www.dcrainmaker.com/2017/08/...th-review.html
Liked 2,497 Times
I've had a lot of mounts. Most seem to be crappy. One even dropped my phone! Quad Lock is the way to go. I totally trust it, and it's worth the relatively high price. Ridewithgps will display your cadence if you have a cadence sensor that sends to your phone.
You can always use a cheap phone that has ant support - just use it a bike computer exclusively. Some of the older models are getting very cheap now - example my Motorola E was $30 new from Ebay. No need for a mount - just sand the back of the phone and glue on a garmin mount (under $5 on Ebay ) to you favorite garmin mount (eg stem or "out-front" and on ebay for under $5). My whole setup was under $50 and has ant support, maps, the works.
