Carbon bike finally asploded...
Quoted: 1186 Post(s)
Liked 289 Times
Well the inevitable finally happened. My carbon fork shattered. May have had something to do with a head-on collision with an e-bike but I'm sure a steel fork would have come out unscathed...
Got complacent on a blind corner I've gone around 800+ times in the last few years. It's rare to see another cyclist but this time was the perfect storm and no time to react. Broken fork and sore shin.
Ow. Sorry about that, and glad you're not hurt.
You know, you're lucky: usually when crabon asplodes, it bursts into flame, igniting the rest of the frame and any other crabon bikes in a 50-yard radius.
Quoted: 18431 Post(s)
Liked 4,548 Times
Time to get out the superglue
As far as steel forks, there are plenty of examples of bent steel forks, as well as bent steel frames. In fact, breaking the fork might have saved your frame from more expensive catastrophic damage (assuming it hasn't happened, and you just don't know the frame is also toast).
Quoted: 551 Post(s)
Liked 278 Times
That'll buff right out!
Advocatus Diaboli
Quoted: 4781 Post(s)
Liked 1,545 Times
Calfee will fix that right up!
A bit misleading on the title. Anyway, carbon fiber is generally much stronger than comparable steal but it all depend on the angle of impact.
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
Seriously, I too am glad the OP is not hurt, having gone down hard myself Tuesday night.
-Tim-
Should Be More Popular
Quoted: 22715 Post(s)
Liked 9,076 Times
Liked 289 Times
Registered User
That'll Nashbar right out: https://www.bikenashbar.com/cycling/...ce:&pageSize:&
Bikes: 2013 Cannondale Synapse 6 Tiagra + 2016 Cannondale CAAD 12 Dura Ace
Quoted: 231 Post(s)
Based on videos I've seen testing carbon forks, I doubt a steel fork would have been perfect after that accident.
Liked 4,548 Times
Perhaps you can convert it to a "Lefty" Fork.
Administrator
Quoted: 12014 Post(s)
Liked 6,782 Times
Why should we change it? It's what he wanted.
Quoted: 551 Post(s)
Liked 278 Times
"Head-on collision" Dang, that must have been some crash! Did you get checked out?
Liked 289 Times
I just went around the corner too fast. It's a relatively narrow path so doesn't have designated lanes. We were on the same line and met at the apex. I was going fast enough I didn't have time to adjust my line or brake. I guess I went to the left a little but not enough as my right leg bore the brunt of the collision.
Bikes: 2018 Roubaix Expert Di2, 2016 Diverge Expert X1
Quoted: 482 Post(s)
Liked 151 Times
Quoted: 212 Post(s)
Liked 83 Times
What happened to the eBike? Did its Li-Ion battery burst into an unquenchable blowtorch of sparks and flames?
If your fork looks like that, the eBike can't be unscathed, can it?
Liked 289 Times
