Ceramicspeed's new shaft drive concept
Quoted: 1533 Post(s)
Liked 725 Times
What do you guys make of this?
https://cyclingtips.com/2018/07/cera...en-drivetrain/
Seems pretty clever... Shifting seems like quite the hurdle though.
Any thoughts?
Any thoughts?
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4380 Post(s)
Liked 3,041 Times
It didn't catch on 100 years ago the first time someone came up with this groundbreaking invention. I predict a repeat.
Bikes: yes
Quoted: 1281 Post(s)
Liked 644 Times
A bike share in a nearby town uses shaft drive bikes. I can see how that might be preferable for a fleet of low-performance rental bikes, a shaft might require a bit less maintenance and be a little less susceptible to wear and tear in that environment than a chain -- but I can't imagine it being a viable option for any kind of performance.
Although, as I'm typing this I'm wondering if it could be a solution to the gravel bikes in the mud problem...
Quoted: 2026 Post(s)
Liked 1,097 Times
As a single speed it might be viable but as a multi-speed, I think the mechanical complexity will be dreadful.
Bikes: yes
Liked 644 Times
Otherwise you'd have to settle for a IGH... which has its own drawbacks for performance applications.
a proprietary consumable cassette, still subject to wear,
as it is still exposed to environmental grit ..
Bevel gears on both ends can be kept in an oil bath..
such as BMW motorcycles have done for decades..
Quoted: 590 Post(s)
Liked 445 Times
If they could couple that shaft drive with a CVT style gearing mechanism instead, I think they could offer more than just eliminating drivetrain friction, which no one really gives a hoot about anyway.
It's MY mountain
Liked 3,041 Times
I saw this bike at the Marin Museum of Bicycling Joe Breeze told me that the company that made it used to pay Major Taylor and other racers to ride them in races for publicity... not so different from today's pro's and sponsorship deals I guess.
Quoted: 4592 Post(s)
Liked 1,745 Times
90° bevel gear boxes are pretty inefficient. They are fine for motorcycles with power to spare, but for bikes it is like having your brakes lightly rubbing. Despite their claims of low friction, I think there is a power loss here from the way the parts interact that they aren't factoring. The roller is only momentarily in full gearing contact with the hub, so the output is not going to be continuous, for instance.
Bikes: 80's Schwinn High Plains, Motobecane Ti Cyclocross
Quoted: 108 Post(s)
Liked 30 Times
Having those little bolts that hold the bearings on the ring in double shear like on their single speed isn't much different than the forces on the pins in a chain (double shear)
Cantilevered on the multiple speed? a whole different problem!
Those little bearings will need seals and shields to last for more than a few hundred miles and what happens when you hammer it and snap off one of those tiny bolts?
Liked 1,745 Times
BTW, in WWII the US Army insisted that the Harley's have a shaft drive.
Quoted: 3422 Post(s)
Liked 5,624 Times
Quoted: 4880 Post(s)
Liked 4,044 Times
A couple of thoughts of the "what if" variety: I wonder if a cassette could be made with radial tracks the teeth for the rollers slide in, making for infinitely variable gearing. Obviously the current setup with rollers or teeth wouldn't work as the tooth spacing would change as the gear ratio was changed, For cleanliness, covers for both the cassette and bearings and the crankset and bearing could be made easily and could be quite aerodynamic. In fact, with well done covers, I could see the shaft drive being light, efficient and very long lasting (and clean!)
A shaft drive bike of 100+ years ago was shown on an earlier post and mention made of Major Taylor riding one of the bikes. He set at least one record using shaft drives. It's biggest drawback wasn't the additional friction, it was the difficulty in changing gear ratios.
Ben
Ben
Ben
Ben
On a side note, the BMW our relatives encountered in WWII wasn't even a BMW(really), it was based on a Zündapp KS 750.
Darwin would have had a good laugh.
Liked 725 Times
It looks like 70% of the respondents didn't RTFA.
The whole point here is to eliminate sliding friction and be more efficient - I would've thought Ceramicspeed's name would alert folks to that...
I like the idea of continuous ridges on the 'cassette' - hard to imagine exactly how that would look though... Obviously there would need to be discrete locations for the driver where new ridges appear and they're evenly spaced, and with some of the ridges being continuous, power could be maintained during a shift - but the shifting would need to be electronic, very rapid, and controlled extremely precisely...
Perhaps some sort of constant-engagement system like a car's gearbox? But then there's a weight and efficiency cost...
Liked 5,624 Times
I did read it.
I like the out-of-the-box thinking.
A big plus here is that adding more speeds does not make the "cassette"-like piece wider.
i.e. you could add all the speeds you want w/o the DS spoke angle getting worse.
Now if they can figure out how to shift across the concentric rows of teeth while they are turning, it will be very interesting.
Liked 1,745 Times
Old fart
Quoted: 3617 Post(s)
Liked 3,454 Times
No neutral support wheel replacements for you!
Liked 1,097 Times
For motorcycles, shaft drive's main advantage is low maintenance requirements. Otherwise, compared to chain and sprockets, it is heavy, expensive, has lower efficiency and is nearly impossible to change overall gearing. It's use is limited to expensive touring bikes where the cost, weight and efficiency considerations aren't as important.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
I did read it.
Bikes: yes
Liked 644 Times
Catch being...they still are using standard highly-dished wheels. Since the "cassette" (if you will) is only a fraction the stack-width of a regular cassette....there's no need for a dished wheel, certainly not a dished 11s standard wheel. Makes me wonder why if it was out of convenience or laziness or what that they did it they way they did.
Dirty Heathen
Quoted: 895 Post(s)
Liked 946 Times
Incremental Gains is where it's at now, all those fractional percentage points can add up, if you take advantage of them. This is supposed to be something like 0.5% less friction than (optimal) Dura-Ace 11sp, which is like 99.0%
I saw it on GCN's Eurobike'18 video, and when he gave the crank a spin, it seemed like it went forever.
Calamari Marionette Ph.D
Manufacturing cost = $2,000,000.00
R&D cost = Guzillions$$
Honda's deep pockets = genius engineers
Chain driven
Chain driven
