Unequal spacing of cogs in 7-speed Dura Ace cassette
On my Dura Ace 7-speed cassette, I noticed that the width of the (1st position) threaded cog with spacer is slightly less than the width of the (2nd position) cog with spacer which is equal to the width of a spacer plus a regular cog. So the spacing between the first and second cogs is slightly less than the spacing between each of the other adjacent pairs of cogs. Why might that be so?
Bikes: '8? Ciocc Mockba 80, '82 Ron Cooper, '84 Allez, '86 Tommasini Racing, '86? Klein Quantum, '87 Ciocc Designer 84, '95 Trek 5500, '98 Litespeed Classic, '98 S-Works Mtb
Quoted: 228 Post(s)
Liked 312 Times
'Need to know which Dura Ace free hub are you working with.
Dean
Dean
Roll Me Up and Smoke Me When I Die
Quoted: 1439 Post(s)
Liked 1,094 Times
Are you perhaps missing a thin spacer from behind the threaded cog? A slight difference is not too relevant, since the first cog's position is set by the low limit and you set the indexing (if used) to make the shifting line up anyway.
Quoted: 6321 Post(s)
Liked 4,910 Times
Is it causing you problems shifting? If not, don't worry. I think that on some they do space them slightly different to optimize shifting.
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
I'll be ordering a digital calipers and will post precise measurements regarding the spacing once it arrives.
There's no thin spacer between the threaded cog and the second cog.
Quoted: 228 Post(s)
Liked 312 Times
I just measured a 7-speed cassette for a 7400 Dura Ace freehub.....that was conveniently removed from the hub for another issue. I have good quality digital calipers and here is what I found:
1st position cog with integral spacer (threads on to the 32 mm portion of the hub body) is 4.98 mm.
2nd position cog with integral spacer (splined on inside diameter) is 5.16 mm.
The cog plus separate spacer combination for the 3rd through 7th positions varied from 4.95 to 4.99 mm.
I run this cassette in friction mode, since my index shifter for the rear derailleur is a 6-speed model.
'Hope this is helpful.
Dean
Dean
Engineer
Bikes: 1989 Krapf (with Dura-ace) road bike, 1973 Sputnik (made by XB3) road bike , 1961 Peugeot fixed gear, 2010 Trek 4400
Quoted: 38 Post(s)
I have the 1989 8speed DA-7400. Be aware that dura-ace from that period is different cable pull ratio, different thread on the last cog (is smaller than standard uniglide. so they could fit 11T .. while normal non-duraace uniglide had 13T or 12T)
RD and shifter must be both dura-ace or both non-duraace to work on 8speed indexing (or a weird combo of standard 9speed shifter with dura-ace RD will work ok for 8speed but using only 8 out of the 9clicks the shifter has). Might be true for 7speed as well.
https://www.sheldonbrown.com/dura-ace.html
Quoted: 4553 Post(s)
Liked 1,695 Times
The reduced size locking cog is only partially true. Later DA hubs had the larger threading for standard threaded sprockets:
https://www.velobase.com/CompImages/H...65FF7FC9C.jpeg
vs the earlier:
https://www.velobase.com/CompImages/H...4A67CD046.jpeg
agentmulder
Bicycle Mechanics
7
01-22-18 02:21 PM
LeicaLad
Classic and Vintage Sales
1
03-24-15 09:10 PM
