New BB for French thread
Hi!
I just had my old bike painted and in hindsight, with too little research, bought a 105 Shimano groupset. The BB shell is right-threaded on both sides so that's why I got the Italian BB. It now turns out that it's a French thread that I'm dealing with. Now it's impossible to find a new BB that works with a new 105 crank and that fits in the old BB shell (68mm long, 34mm in diameter). Since I really want to avoid sending those 105 parts back and to buy new/old stock, I'm quite stuck now. The only possibility I see is to ream and redo the orginal threads in the BB shell, and then try to get the 70mm BB to fit the 68mm shell.
If there is any suggestion, I would gladly hear it.
Thanks in advance and greetings from Belgium
Mechanic/Tourist
Check threadless bottom brackets.
Quoted: 4553 Post(s)
Liked 1,695 Times
Italian is only .5mm larger in radius, so that might not be enough when the threads are deeper than 1mm. They are both 24TPI, so that might be possible. That's a machine ship job, not a bike shop.
You could also have your 105 bb turned down to French thread, which might be a lot easier since they are small and aluminum.
Phil Wood makes Shimano style external BBs with French thread:
Phil Wood & Co.
Pricey, but you can probably service the bearings on the PW BB.
Phil Wood & Co.
Liked 1,695 Times
yes Phil is a good square taper BB , made in California..
they make separate mounting rings
to use their cartridge assembly in any bike ,
with the appropriate mounting ring choice..
French held out for their own metric standard,
eventually had to fall in with the rest ..
You might look for loose ball BB from earlier years ..
a 1/4" ball is common to all those types.
so you may be able to source french thread cups and a japan BB spindle....
You have to send the external bearing crankset and bearings , back.
they only make the bearings in British or Italian thread , not french
and go back to older components .. sorry, time has moved on.
now to export the French bike biz have to use other standards,
to sell abroad.
good luck with the 3rd place match with England..
to sell abroad.
Liked 1,695 Times
yes Phil is a good square taper BB , made in California.. they make separate mounting rings
to use their cartridge assembly in any bike , with the appropriate mounting ring choice..
French held out for their own metric standard, eventually had to fall in with the rest ..
You might look for loose ball BB ftom earlier years .. a 1/4" ball is common to all those types.
Phil Wood makes external French thread BBs so he can use his external BB crank.
dear sisyphus, rather than pushing that boulder uphill forever,
buy an italian or british threaded frame ..
(in Belgium I expect those Phil parts cost a whole pile of Euros)
SE Wis
Quoted: 2752 Post(s)
Liked 3,412 Times
Mechanic/Tourist
Senior member
Quoted: 946 Post(s)
Liked 663 Times
I once heard of someone who executed a successful hack by running right hand English taps in both sides of a French BB shell and using two adjustable cups. The diameter and threading should be close enough to work, but I have not tried this myself to confirm.
I would think the right cup would need to be loctited in place. Sounds plausible enough to try.
Quoted: 2364 Post(s)
Liked 2,887 Times
maybe velo orange french bottom bracket? 103 to 122 mm spindle length? https://velo-orange.com/collections/...e-alloy-cups-1
Senior member
Quoted: 946 Post(s)
Liked 663 Times
Liked 1,695 Times
Liked 2,887 Times
ahh read it that OP had 105 italian bb.......wans was thinking square taper... not that OP had a 105 group...... reading comprehension
The OP does not mention if he has a stem and seatpost, if not that will be another bit of fun if they are French size
OP: IMHO you will go crazy trying to cludge this.... either new frame or if this frame is really special, send the group back and put something together to fit the frame
SE Wis
Liked 3,412 Times
In people's defense the OP never really stated what generation of 105 he bought or that he needed an external bearing BB other than saying "new" regarding the group.
realistically his only options are Phil or a different crank that uses a square taper in a length available.
Engineer
Bikes: 1989 Krapf (with Dura-ace) road bike, 1973 Sputnik (made by XB3) road bike , 1961 Peugeot fixed gear, 2010 Trek 4400
Quoted: 38 Post(s)
Phil Wood & Co.
Phil Wood & Co.
Italian thread 36mm x 24tpi (1.05833mm spacing pitch)
French is 35mm x 1mm spacing pitch.
While they are pretty close it's really not compatible. French thread can (in theory) be rethreaded for Italian but it will mess up the threads because of the pitch difference and those 0.06mm difference add at every thread. So after 10mm of threads is 0.6mm difference, which is halfway the original pitch so the tap will effectively strip that thread at about 10mm depth. There will be only a few good-decent threads left - don't do it) - also the shell width is not enough.
Thread-less BB's need a larger hole and there is not enough metal on the BB shell to do so. But there are some that require 35mm hole which is the best bet since it will only cut out the threads not weakening the BB shell.
Find FRENCH BB. There are plenty on square taper and there are some decent square taper cranks. Nothing wrong with that. You are not expecting a light racing bike, right?
Liked 1,695 Times
NO!
I don't see how having to add two 1mm spacers under the cups could possibly be an impediment.
Bikes: old ones
Quoted: 26476 Post(s)
Liked 10,440 Times
...If I understand the OP correctly, you bought a new 105, outboard bearing Hollowtech crankset, and your newly painted frame is French threaded in the shell.
While it's certainly possible to ream and re-thread the shell to fit your Italian cups, I think you're going to run into additional issues when you need to space the cups out wider with the 68 mm shell width to accommodate your Italian specced crank shaft in your new crank set. If nothing else, it will move your crank arms out by either a skosh on both sides, or on the outboard side if you elect to try maintaining the current chainline by installing the drive side bearing with no spacer. I can't imagine you'll end up being able to do this cheaper and easier than just getting a different crank that fits the French standard frame. One of the unfortunate downsides of outboard bearing cranks is they are more resistant to adaptation for unique situations like yours.
If, OTOH, you're talking about an earlier version of 105, with a square taper BB, I think you've already got plenty of good recommendations.
Engineer
Quoted: 38 Post(s)
Well from the looks of it, tapping to italian thread looks to be a suitable solution after-all (apart from finding the right French BB for your cranks).
I've did a sketch and the threads don't look that mangled. They interfere just a bit from time to time.
The real resulting thread profile is in green in model2, while in model 1 with red is french thread and blue is italian thread.
FWIW VO is the Importer, in Maryland USA
Maybe there is another source in Europe for what is undoubtedly made by a Taiwan company..
yea not the latest external bearing hollowtech cranks.. sorry..
with a repaint .. one can lay in molten brass filling the thread , then the rethread pitch mismatch can be cured
with good metal when done .. carefully..
Administrator
Quoted: 12003 Post(s)
Liked 6,746 Times
Please pardon the disruption. Carry on.
