Put an old 11 speed Shimano cassette on a new wheel?
longtime noob
Bikes: 2018 Trek Domane SL 6 // 1999 Trek 5000 // Burley Encore X
Quoted: 46 Post(s)
Liked 63 Times
I have an old bike with a circa-1999 Shimano 9 speed cassette on the rear wheel (the whole drivetrain is 105 triple). I'd like to upgrade my wheelset... will I be able to put my 9 speed cassette on a "modern" 11 speed wheel? Seems like I should, as the 9 should take the same/less space, but wanted to check with the experts here...
Thanks in advance!
Thanks in advance!
Mechanic/Tourist
Yes, you can do it. I believe you need a 1.85mm and 1mm spacer.
Bikes: Felt Z5, Look 675 Light, Specialized Diverge
Quoted: 48 Post(s)
7, 8, 9, and 10 speed cassettes are all the same width and all fit on the same freehub. 11 speed, however, is slightly wider. So to put your 9 speed cassette on an 11 speed freehub, you need a 1.85mm spacer. Like this one:
SPACER
SPACER
It's worth noting that because of the extra cassette width to pack another gear in (the extra width you'll be spending on that nice spacer), 11-speed wheels have slightly more dish than Shimano 8/9/10 speed wheels. This is more of a theoretical problem than a practical one, though.
