Are Garmin and Wahoo Mounts Compatible?
2-Wheeled Fool
Bikes: Surly Ogre, Brompton
Quoted: 1385 Post(s)
Liked 677 Times
Easy question, but I'm unsure just by looking at them. I only have a Wahoo Elemnt, but no Garmin. If I decided to get an Edge someday, would the mounts be interchangeable? They are expensive in my opinion.
Bikes: Trek CrossRipComp / Trek Domane SLR 6 Disc
I have an Element and had to buy an adapter so that I could use a Garmin mount. Got it from Shapeways.
Ride it like you stole it
@Tom_T, I hope you got one of mine
@NoControl There are a number of ways to mount a Wahoo on a Garmin Mount, some Garmin mounts (such as K-Edge) even have plastic inserts that can be replaced to convert from a Garmin compatible mount to a Wahoo compatible mount.
"Never use your face as a brake pad" - Jake Watson
The Reloutionaries @ Shapeways
Mount fit
U can modify a garmin mount by slightly shaving two sides and the the Wahoo fits and can have the right orientation, check the Wahoo google group site for more detail
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
As a point of interest, Barfly mounts come with the parts to make it work with just about every GPS made today.
-Tim-
-Tim-
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
You can replace the KEdge insert. Just need the right disc in there orientated the right way. No need for entire new mounts.
