Cannondale Power Meter Options
Quoted: 15 Post(s)
Been cycling for about 7 years now and would like to purchase my first power meter by next spring. I'm riding a 2016 CAAD12 Ultegra that has the pretty spider ring seen here:
Spider
After seeing what's out there and reading reviews on different meters it seems like the only way to keep the factory Cannondale chain rings is to go with the following meters I have listed below. Wanted to check with you all to see what you're running and if I might have missed something. If I am correct, and limited to what is below, I'd love to hear your opinions and recommendations.
Crank Arm
Stages (left leg only )
Pedals
Garmin Vector
Power Tap P1
Favero Assioma
Hub
Power Tap G3
Spider
Crank Arm
Pedals
Garmin Vector
Power Tap P1
Favero Assioma
Hub
Power Tap G3
I am going to purchase the Favero Assioma Duo pedals. I have wanted a power meter for years but the Powertap hub route seemed too much trouble. Being able to put pedals on and go ( essentialy ), is much easier. A friend bought the Assiomas and loves them.
Quoted: 20810 Post(s)
Liked 9,456 Times
Watteam Powerbeat G3 (Dual-sided, DIY pods that attach to the arms) - $399. They under-report <5sec efforts over ~800w or so, but seem pretty sold otherwise. Read up on DCR.
SRM has a new set of power pedals.
Liked 9,456 Times
Though, personally, I wouldn't plan a power meter purchase just to be able to continue to use a wear item that goes for $250 a pop.
Blast from the Past
Powertap wheels are a very solid product with a history of solid repeatable data. The only potential down side is one wheel set. I've ended up crank based (SRM) but would not hesitate to put a G3 wheel on a training bike.
Quoted: 15 Post(s)
If I went the hub route I would go for their prebuilt DT Swiss R460 or AMP 35 wheelsets
Bikes: Salsa Fargo Ti, Cannondale CAAD9, Carbonello Fixed Gear, Specialized Epic Disc
Quoted: 39 Post(s)
Liked 16 Times
I love my G3 Powertap hub. I got when the price dropped from a ridiculous $800 to a reasonable -$400. I built it up with a Farsports carbon rim and got nice setup for a total of less than $650. I didn't want to change out my Speedplay pedals to use a pedal based system and I never really looked at a crank based system.
Heft On Wheels
Quoted: 887 Post(s)
Liked 560 Times
fyi you you can change the chain rings when they do wear out for not a crazy cost. They will even factory overhaul it too when you do get the rings. The actual pm and rings are a separate units on the crank assembly It’s a pretty good deal. Turn around does suck though I guess. Weeks I am told.
Liked 9,456 Times
moth -----> flame
Bikes: 11 CAAD 10-4, 07 Specialized Roubaix Comp, 98 Peugeot Horizon
I ran a powertap SL+ hub built into a Williams 30 rim on my CAAD10 for several years - no fuss, very reliable, solid. Recently, prompted by a desire to upgrade wheels or get a new bike, I bought a set of Favero Assiomo Duo pedals and have been very happy. Power readings seem comparable, love getting the left/right readout and metrics around the efficiency of my pedal stroke and of course, they're very light. Battery life seems excellent too.
BF, in a nutshell
BF, in a nutshell
Bikes: 2017 Ridley Noah SL - Candy Apple DA9000, 2011 CAAD10 Berzerker Ult6800, 2013 FOCUS Mares CX Ult6800
Quoted: 26 Post(s)
Both SRM and Power2Max make Hollowgram compatible powermeters and they are good kit. If you're keen on retaining the Spider-ring and want dual power, then pedal-based would be the go
cheers
cheers
Bikes: Spooky Mulholland
Quoted: 52 Post(s)
Liked 17 Times
even quarq made a pwoermeter for cannonade cranks a few years back you can find used, but I would say go to best bargain is the power2max ng eco, its like 450 shipped to your door for the spider, I am currently using a Rotor 3D+ crank with a power2max PM, love the set up
I went with pedals myself. it just seems like such an easy solution that requires no fuss. I have the Assioma Duo. And now that I've had them for one season, I would buy the Uno if I'd known how little benefit the Duos give me. Yes, I have L/R readings, but so what? I have no idea how to use it. I'm just a stronger road rider, not a racer, and all that data is meaningless. I just wanted the basics, what am I putting out, what was the average, and what were the peaks.
Thread Killer
Quoted: 3215 Post(s)
Liked 1,755 Times
I just saw yesterday that CleverTraining is selling P1 pedals for $399, which seems a pretty good price for those not wed to their current pedals (or who are already using compatible cleats).
I got a pair of Assioma Duo this past Spring, and think they're awesome. I've had both wired and wireless Powertap wheels over the years, and always disliked the limitations, specifically in that I have multiple bikes and wheels sets, and invariably something wouldn't match up when selecting the bike, like the wrong tire on the Powertap for the ride, wrong cassette or whatever.
These Assioma swap bikes effortlessly, so for my needs, there's no better power meter solution (power meters, plural, yes, that'd work!).
Liked 9,456 Times
The problem with the Ptap P1 is that, unlike Garmin and Favero, they're not offering any upgrade path from the single-sided to the dual-sided - that kinda blows.
Bikes: Cannondale Supersix Evo Hi-MOD
Quoted: 19 Post(s)
I'm probably going to get the Assioma Duo pedals for my Evo when Clevertraining has their 20% off sale around Black Friday (I think?). Looks to be the best dual-sided solution while keeping the Spidering.
Quoted: 1853 Post(s)
Liked 680 Times
OP, what do you want the power meter for? Your intended use should be factored in to which PM you go with.
For example, if you plan to do very specific and intense training, I'd encourage you to go for an SRM. You can find used Cannondale SRM spiders for about $500, though you would not be able to use your current spiderring.
If you plan to race on race wheels, PT Hubs are not a good option.
If all you want is power numbers for minor training/curiousity, then Favero, SRM or PT pedals or Stages crank arm are good options.
Regardless, do not buy Wattbeam or Garmin.
Bikes: 2018 Fuji Cross // 2014 Scott Addict 10
Quoted: 25 Post(s)
+1 for Favero Asseoma. I recently purchased a Stages Ultegra r8000 dual-sided crankset and it works great but after having a professional bike fit, I'm beginning to think I would be better served by shorter cranks (oh well!). Not to mention, I still have to buy additional power meters for my other bikes.
Check out DCRainmaker & Shane Miller's reviews on the Asseoma duo's... pretty impressive and I love the fact that they're rechargeable and require no torque wrench to move from bike to bike. (why create more trash burning through disposable batteries when you can just recharge?) You can always start with the L and then upgrade if/when you desire.
Only "downside" is that I do prefer Shimano pedals/cleats over Look style.
Quoted: 15 Post(s)
Ya i agree with you there
Thread Killer
Liked 1,755 Times
Yes, you'd probably want to avoid the PowerTap pedals for crits, as they restrict lean angle when pedaling through turns. The Assioma are as good as most any standard clipless pedal in that regard.
I have had experiences with the following power meters:
1. Favero Assioma Duo pedals: great PM at its price range, if you're OK with Look-style pedals.
2. Stages: left only or dual side. Make sure you get the generation 3 models. Gen 1& 2 have connection issues with Garmin.
Look at the pedals. Look at the crank. Use your imagination. Pretty much just pedals that are hard to get out of! But I love them.
