Magnesium bike frames?
Bikes: Priority 600, Priority Continuum, Devinci Dexter
Quoted: 685 Post(s)
Liked 55 Times
I haven't seen much Interbike news on these boards. The most interesting bit for me is probably this new, magnesium alloy:
https://www.bicycleretailer.com/prod...s#.W6Yxo2hKjb0
I'm not fond of carbon, so a metal that is lighter in weight than aluminum is appealing.
I think magnesium is really prone to corrosion. I think the trick is to find a good durable surface treatment to prevent that. I'm sure they must have something worked out. Wonder what it is.
Quoted: 3352 Post(s)
Liked 1,056 Times
Sounds good. Everyone should always welcome advance. And IMO any type of metal for a bike frame is better than a plastic CF frame.
With a mighty wind
Quoted: 1120 Post(s)
Liked 916 Times
I had a pair of hubs with magnesium flanges, like 20 years ago. Of course there was the Rock Shox mag 21, it had magnesium lowers and brake arch.
I used to see magnesium bikes 10 years ago when racing. I'm sure they're still around but I'm out of the loop.
Fun story. A friend switched from cantis to V brakes way back when. We ground off the cable hanger on the brake arch. Of course we attempted to burn the filings. It was a strong white flame if I remember correctly.
Pennylane Splitter
Bikes: Yes
Quoted: 1854 Post(s)
Liked 1,509 Times
It should work, just get the alloying and engineering correct for magnesium's peculiar properties. A lot of aftermarket car wheels are made from magnesium. Remember the old air-cooled 4-cylinder Volkswagen engines? The blocks of those were magnesium.
Generally bewildered
Quoted: 1152 Post(s)
Liked 342 Times
On the other hand, my Dad owned a manufacturing company that made lawnmowers. REALLY industrial mowers. Like 24" mowers with an 18 HP Wisconsin engine and quarter-inch plate steel decks. Anyway, his small 21 (or 19"??? Can't recall) was made from a Mg casting. With paint, that lasted pretty well. I'll see if I can dig up a pic of the wood pattern that was used to cast the mower decks.
Sounds impressive, guess we'll see how widely adopted this stuff becomes in the next few years. If it truly is lighter and stronger than aluminum but costs the same, it should see widespread use on consumer bicycles.
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
Bike Snob NYC reviewed one in 2009:
Bike Snob NYC: BSNYC Product Review: Segal Magnesium Road Bicycle
mentioned this, and the OP subject, in the most recent post:
Bike Snob NYC: Timeless Design Is Timeless
Quoted: 741 Post(s)
Liked 819 Times
Saw this at the Eroica California Concours.
Quoted: 32 Post(s)
Magnesium isnt anywhere near as easy to cold form as aluminum. And since it has properties close to aluminum, this becomes a major con.
Casting, like the white bike shown, is more likely.
Personally i think Ti is the better of metals since corrosion is zero and its closer to the properties of steel, just lighter and harder to work.
Pickett made slide rules of magnesium back in the day, and it does corrode pretty badly.
Bikes: Fitz randonneuse, Trek Superfly/AL, Tsunami SS, Bacchetta, HPV Speed Machine, Rans Screamer
Quoted: 100 Post(s)
This isn’t your dad’s magnesium. It can be readily formed and welded. Two properties that are game changers.
On Holiday
Bikes: A bunch of old steel bikes
Quoted: 394 Post(s)
Liked 14 Times
And when you had an engine fire, these things burned spectacularly.
rebmeM roineS
Quoted: 653 Post(s)
Liked 348 Times
Paketa has made some very light magnesium tandem and single bikes. Reported that they are out of business - website doesn't indicate any current production or sales: Paketa Custom Magnesium Bicycles :: Tandem bicycles colorado::Road Racing Bicycles :: Mountain Bikes:: Tandem bicycles denver colorado :: paketa cycles website
I have magnesium pedals from Nashbar on one of my bikes. Don't know who they were made by. No signs of oxidation.
Liked 342 Times
https://photos.app.goo.gl/zSAn622L6NvrSnLk8
Liked 342 Times
For those interested, here is a pic of the wooden pattern used to make the cast magnesium mower decks:
My Dad's company was named DeVere-Locke. I can't find pics of any of the really beefy rotary mowers they made, but here's a reel-type from about 1961 (before my Dad purchased the company). This was not the magnesium-deck model, but is old school (cast iron, and the paint job has pin stripes!
Cool. Thanks for posting those photos. Sensation made commercial 21" push mowers with magnesium decks in the '70's and '80's. They were originally out of Nebraska, I believe. I didn't realize there were other manufacturers using magnesium.
Quoted: 609 Post(s)
Liked 795 Times
AELLE IS A CHROME MANGANESE (NOT CHROMOLY) ALLOY THAT LENDS ITSELF TO AUTOMATED
WELDING PROCESSES. THERE IS A BUTTED VERSION.
Some years after the original Aelle
introduction Columbus began making the butted manganese moly tubes, but
soon after their introduction they introduced the Cromor set which cut
into the marketability of the former. Our local shop sold the Torpados as
a budget racer.
a budget racer.
Shaft roller
Bikes: Brik Brut, Dynamic Tempo 8
I wonder if it's really "normally" weldable as they advertise, I'm guessing it needs a special type of welding to make the welds strong enough for high torsion use on a lightweight frame.
Sierra
And dangerously. Attending fire fighting school in the Navy, I learned burning Mg is impossible to extinguish. Jets are/were constructed with magnesium. Burning Mg explodes when doused with water, CO2 is broken down and the fire burns the oxygen for more flame. Our instruction was to coat nearby fuel for fire sources with foam and push it overboard.
