Crack in saddle’s base — should I be worried?
I recently switched over from a Fabric Scoop Race Flat to a Scoop Race Shallow. The Shallow might very well be the most comfortable saddle I’ve ever ridden (don’t let my beloved Brooks Pro hear me say that). I bought this used for very cheap knowing it has this small crack in the base. Is this something I should be worried about? I am 163lbs if that makes any difference.
Thanks,
Doug
Thanks,
Doug
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
I own three Fabric Scoop saddles.
The entire base is one piece and what the photo shows above is a saddle that is failing, or has already failed.
The base should not be cracked. I would not have purchased it, nor would I ride it.
-Tim-
-Tim-
Super Moderator
Quoted: 1175 Post(s)
Liked 937 Times
If it's comfortable, ride it, watch for it cracking more.
I never finish anyth
Bikes: 2008 Merckx LXM, 2003 Giant XTC mtb, 2001 Lemond Alpe d'Huez, 1997 Lemond Zurich, 1989 Cannondale ST, 1988 Masi Nuovo Strada, 1983 Pinarello Turismo
Quoted: 294 Post(s)
Liked 137 Times
Mark the ends of the crack with a sharpie - that will make it obvious if the crack is expanding.
Dale, NL4T
Dale, NL4T
my Nylon base saddles have been fine for decades
selle San Marco, Italia, & Royalle/Fizik..
But covering over the foam gets damaged with use..
Quoted: 18451 Post(s)
Liked 4,562 Times
Maybe some more photos of the saddle. That looks like an odd way for a crack to propagate. You're sure it isn't a scratch? How much wear on the saddle?
I had a cheap Chinese Carbon Fiber saddle break. It wasn't a big deal. Just started feeling loose one day. Rode it home, and removed it when I got home.
In this case, the CF seat was put together with a non-structural glob of epoxy/resin without reinforcement.
Of course, I'm also not riding the Tour de France.
So far, I've never had regular plastic rail attachments fail.
I couldn’t get anything in this crack if I wanted to. Honestly it looks more like someone scratched it with a razor blade (meaning there is no depth to it).
Liked 4,562 Times
Capillary action may pull Super Glue in a bit, but probably not more than 1/8 to 1/4" or so.
Perhaps it is a molding defect. You might have gotten an excellent deal on a good saddle.
Liked 3,134 Times
was going to suggest the crack being natural in design, butttt that's a different type of crack that's being shown. I'd smear some clear epoxy over it, nothing with color; especially nothing containing brown..
Figured I'd take a crack at it either way.
-Oh Hey!
-Oh Hey!
- Soli Deo Gloria -
Liked 736 Times
Lots of bad advice in this thread, likely from people who don't own Fabric Scoop saddles.
The rails are supported by the base right behind that crack.
Everyone is free to ride whatever they want but that saddle is garbage.
-Tim-
-Tim-
Generally bewildered
Quoted: 1152 Post(s)
Liked 342 Times
Do you agree with the OP that these are very comfortable saddles?
Here's the response I received from Fabric:
Thank you for reaching out to us. If your saddle has a crack in it, we do not advise riding the saddle. It could fail and cause injury to yourself, I would be wise to purchase a new saddle.No surprise as they have to play it safe. But so do I! I have another Scoop Shallow coming.
