Self-Centering Guide Pulley
Zip tie Karen
Liked 1,543 Times
I have a friend's Trek 520 with an indexed Deore 7-speed rear. The derailleur pulleys were so worn, that I searched for replacements, finding the TY05/15/20/22/30 CT92/MJ05 pulley set. It arrived today, and the pulleys are identical, both being the non-self-centering tension type. So, what do I do to modify one of the pulleys to "thin" the distance between the circular plates, thereby giving it room to slide on its mounting bolt.
Am I thinking about this wrong? Is there a replacement for the guide pulley that I'm missing? Should I just take a sanding wheel to the plastic pulley to take off a few mills?
What say you?
What say you?
A wider bushing sleeve around the bolt, than the bushing in the pulley.
But Why not just get a Proper 'Center On' Guide Pulley ?
Liked 3,992 Times
One could machine out a new bushing (yah, right) or thin down the pulley's surfaces that the end caps almost sit on. But really just get the correct pulley. If the pulley is a narrower one thin washers on on or both sides will respace it. Andy
AndrewRStewart
AndrewRStewart
Some aftermarket pulleys are designed to have no float and work just as well as the Shimano OEM's. Possibly Shimano decided to follow suit with some of their pulleys since yours sound the same as what's described on the "TY05/15/20/22/30 CT92/MJ05" package. Install and enjoy.
Liked 725 Times
Aftermarket guide pulleys with no float usually have thinner teeth.
But it's a pretty subtle feature; I think the point of it isn't to make up for bad adjustment so much, as to allow a shift to delay slightly so the chain hooks up on the right spot in the cassette for a smoother shift. You may not notice a difference without float or thinner teeth.
Not that I've done a huge amount of experimentation, but IMO the overall condition of the drivetrain, derailer and shifter is more important than if the guide pulley has float or not.
Zip tie Karen
Liked 1,543 Times
Thank you for the feedback. The weakest part of this setup is the 7 speed indexed downtube shifter. Once the inner parts of the shifter become worn, there's a bit of sloppiness in the pull for each "click".
The shifting is okay on the 520, as I had previously updated it from uniglide to hyperglide.
I wound up shaving just a bit off of each side of the pulley. It has some float now, but that's not really needed unless at the extremes of chain deflection, where a bit of self adjustment makes the drivetrain quieter somewhat. Anyway, I appreciate the comments. Phil
Senior member
Shimano has abandoned the Centeron pulley at least on it's higher end road groups. Check a newer Ultegra or Dura Ace derailleur, and you will find there is no float on the guide pulley.That may have filtered down to the lower tier groups by now as well.
Liked 644 Times
A bike old enough to have worn out the derailleur pulleys. I wouldn't feel right spending very much money on parts.
My typical solution would be to pick a derailleur off of a donor bike.
OK, makes some sense, gaps, by 10 & 11 get so narrow,
no tolerance for any float, +/- but, has to be spot on under that cog..
I've been friction shifting for decades (touring,JRA ) and personally got off the industry bandwagon
at 7 speeds ..
JRA, ..
OP want old parts , ask @ bike shops , not online discounters.
wholesale distributors to shops stocked up to keep bikes running..
at 7 speeds ..
JRA, ..
Liked 3,992 Times
One more reason why shifting issues are so common with this current stuff. No ability to accept the designs that widen the tolerance window. Andy
AndrewRStewart
AndrewRStewart
Zip tie Karen
Liked 1,543 Times
This is my fifth year doing annual maintenance and repair on my friend's 1989 520. I keep it running, but he puts a lot of miles on it. I have a good handle on where the needed maintenance items are, and try to keep him just slightly ahead of things. He won't bring it to anyone else, because I'll take the time to fix what's wrong and not try to sell him something new.
I run Shimano 5700 and swapped my jockey wheels out for some aftermarket Tacx wheels, as they were a good price and also have stainless steel bearings. There is no float in these wheels, and my indexing is slighty off, always. Also, I have found that Tacx wheels make a lot more noise than the OEM Shimano ones. Now, that may be down to wear and the teeth of the jockey wheels and the chain meshing nicely. It may just be a little bad luck on my behalf, but I'll be buying Shimano jockey wheels next time. That float definitely makes a difference, albeit very minor.
Blamester
Liked 3,992 Times
Fast forward a decade and that lesson was lost and metal pulleys (while with balled bearings not adjustable) became the "new kid" and were thought to be the cool upgrade (that they came in colors other then silver or black was their marketing coup). But once again we found them to be rough and noisy when in actual use. Fast forward another couple of decades and guess what? Funny how this business is so cyclic
![Smilie](images/smilies/smile.gif)
AndrewRStewart
AndrewRStewart
Decades ago I got some Carmichael Pulleys , (Metal; Ti)
they included flanged machined aluminum bushings ,
for float the 2 bushings butted together and combined,
were wider than the bearing between them..
My Tacx pulleys are nylon, (stock, In R'off chain tensioner )
and I substituted the stock plastic Brompton (3 speed) ones ,
with Tacx, nylon, and they're quieter than the harder plastic..
Generally bewildered
Liked 342 Times
Aren't the plastic wheels supposed to float on the bushing, and not the whole assembly on the bolt? The thing I'm having a problem with is that if the bushing slides from side to side on the bolt, it can also rotate on the bolt, and bolts are not good axles.
It would seem to me that you could sand a little material off the sides of the wheel and it would move from side to side. Or, find a little bit longer bushing that allows the wheel to move from side to side.
Or am I completely misunderstanding this?
