650b conversion drop and tire clearance?
Quoted: 129 Post(s)
question on 650b conversions
How much lower to the ground would BB get going from 700x28 to 650x28?
Is there a general rule that going 700 to 650b adds about 10mm in tire clearance? eg a frame rated for 28mm in 700 would fit a 38.
I saw that somewhere, don't know how accurate it is
thanks!
thanks!
Quoted: 4233 Post(s)
Liked 3,945 Times
And labeled width is not the measured width. Additionally rim width effects tire profile, But the differences are usually in mms, not a lot unless you are crazy in pedaling through turns. Andy
AndrewRStewart
AndrewRStewart
To determine the approx. clearance for a 650b wheel measure 320mm from the axle (front and back) and then determine the available width at this point. An additional 10mm is not a bad guess, but it truly depends upon how the fork and the chain stays/seat stays/brake bridge are built.
Here are some additional guidelines re: 650b conversion from 'Bikeman' - I found them useful: 650B Conversion Guidlines
On Holiday
Bikes: A bunch of old steel bikes
Quoted: 394 Post(s)
Liked 14 Times
The point of converting a 700c bike to 650b is that the smaller wheels allow wider tires, which generally have a higher profile. I converted a 90s Bianchi road bike a few years ago and went from 25mm tires to 38mm. The difference in the wheel/tire diameter was about 1/2 inch (smaller for the 650b) so the BB height was about 1/4 less. Not all that significant.
Re: BB height after conversion - looks like the consensus is that it's no big deal - just pay attention if you really lean the bike over in a high-speed curve while pedaling.
I converted a bike from 27" wheels to 650b and have not yet had a pedal strike - although I am generally not hammering down hill on curves.
I am a believer in 650b for certain bikes. I have only converted 1 bike but it is now my favorite because of the plush ride (38mm Panaracer Gravel Kings) that I get on a 'sport' frame.
If you buy or build a decent set of 650b wheels you can always keep them to try on other bikes if you do not like the results on your current bike. However, there is not a huge selection of rim-brake rims available for 650b. Fortunately, there are 2 or 3 good choices to try.
Liked 3,945 Times
Here's a recent thread on some of the same topic. https://www.bikeforums.net/bicycle-m...questions.html Andy
AndrewRStewart
AndrewRStewart
Nigel
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Quoted: 384 Post(s)
Liked 6 Times
First of all, use ETRTO standards, and the math is then easy. 700c is 622mm BSD, 650b is 584mm BSD; (622-584)/2= 19mm about 3/4 inch for non-technical folks. Then take into account the tire size difference.
It would have to be a very special situation to convert from 622 to 584, and keep the same tire width.
sweetspot
35
10-11-18 11:19 AM
Soundtallica
5
02-11-17 11:16 PM
