Can’t remove drive side pedal seems stuck
so bassically I’ve got to replace my pedals since the ends have cracked I’ve taken non drive side off using pedal spanner 🔧 but I’ve tried this on drive side and the pedal just doesn’t want to come off. So its stuck. Is there way of getting a stuck pedal off?
ps I’ve had to turn my bike upside down to do this since I don’t have a stand
Non omnino gravis
Quoted: 143 Post(s)
Liked 164 Times
Just in case: make sure you are trying to turn it in the correct direction to loosen it. Drive side pedal is right hand thread, so turn it to the left to loosen it. NDS pedal is left hand thread (sounds like you know that already). Both pedals will turn towards the rear of the bike to loosen, towards the front of the bike to tighten.
Other than that, increased leverage is your friend. Penetrating oil can't hurt. Impact on the wrench might help if no more levarage is possible.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4377 Post(s)
Liked 3,034 Times
Teamwork is also helpful - one guy holds the bike steady and still while the other applies the torque to the cheater bar.
dont have anyone else to hold hence why I put my bike upside down and no hammer. All I have is a pedal wrench and Allen keys etc..
Pedal trying to take off. Is this a cap to access (Allen hole? If so how do you take it off
This is the one I fixed notice
Bad example
Quoted: 881 Post(s)
Liked 372 Times
That Allen hole is in the end of the pedal spindle. It is not a separate bolt. With the right size Allen wrench, you can take that pedal off as explained by the other posters.
Quoted: 863 Post(s)
Liked 1,105 Times
Pour some boiling water over the end of the crank and try to remove the spindle while the aluminum is still hot. The heat may help to break the spindle free. Also just make sure you're turning it the right way since you're turning the spindle from the inside of the crank you would turn it counterclockwise for this reverse thread to loosen. Just sayin'.
Quoted: 1021 Post(s)
Liked 464 Times
There are very helpful videos on YouTube.
Also be sure to put the chain on the big chain ring. If your hand slips and hit the chain ring, your fingers will thank you.
I know the offending pedal is on the NDS, but when you use force crazy things can happen.
Good luck.
Good luck.
# 1 turning it the proper direction ?
@ bike shop we have a very long (8mm? ) wrench to remove them , with a handle .. willing to seek shop help ?
LBS on the western end of a long tour route, stuck pedals happen .. we ship bikes back.. so pedal has to come off *
Bike on the ground with tires pumped up , is usually better than in the air. on the stand ..
once I break the pedals loose (Yes, a 2 person job, some times) then the bike goes in the stand for the rest of the knock down..
* if its too stuck the crank is removed, .. because the job was box and ship, so the really stuck pedal solution is a can kicked down the road..
Usually shipped to another bike shop in their hometown..
Quoted: 2622 Post(s)
Liked 3,160 Times
As someone else mentioned, put the chain on the big chain ring before you do anything else (and drape a folded rag over the chain for good measure; I can show you the 40-year-old scar that taught me to do that).
Then, remove your seat post (having first marked it so that you can reinstall it at the correct height), slip the open end over the allen wrench, and use the seat post as a cheater bar.
Get an 18" or 24" long 3/8" ratchet wrench and an 8mm hex bit to fit it.
Old fart
Quoted: 3617 Post(s)
Liked 3,454 Times
I remove problem pedals by removing the arm(s) from the bike, clamping in a bench-mounted vise, and using a pedal wrench and cheapter bar to get the necessary leverage.
Bikes: 630 Beach Bike Schwinn Hurricane ATB
Quoted: 35 Post(s)
Spray some Liquid Wrench on it and tap it.
Keep trying to loosen the bolt normally.
If it still hasn't come off by the next day then place a 2x4 underneath the pedal and put the hex wrench in the bolt hole and against the 2x4. Then mash on the pedal with your foot as much as you would dare. Probably be a good idea to cover it with a towel to keep flying tools and particles down to a minimum.
The hot water thing or a heat gun is a good idea too.
Bikes: 2020 Pivot Vault, 1983 Rossin Record, Garneau R1, Mesamods home built gravel/rain commuter bike, 1995 Barracuda A2V modified with Surley single speed dropouts, 1969 Bottecchia junkyard special fixed gear, Cervelo P4, Mesamods 650b klunker
Quoted: 96 Post(s)
Liked 72 Times
It's all about getting the best mechanical advantage and making sure you're turning the tool in the correct direction. I made a video a few years back with some tips on removing tight pedals. It might be helpful...
When pedals with hex sockets in their butts get stuck, with too much force it is possible to crack the sides of the hex socket. Once this happens, the pedal becomes absolutely unremovable. You will have to throw out the crank and the pedal. (Unless you drill out the pedal spindle and somehow repair the thread, which is typically not worth it.)
This is something you have to keep in mind. There are lots of bad and inexperienced advice in this thread stating that all you supposedly need is "greater mechanical advantage". Ignore this advice at all costs. If your pedal is really stuck, the only thing you will achieve by applying excessive force to such hex socket is six cracks in six corners of the socket. This will be a total loss.
If you feel that the force becomes excessive (and the hex socket is stil intact), try warming up the crank and applying some penetrating oil. If this does not help, you will have to sacrifice the pedal: cut the outside portion off, leaving enough of the spindle sticking out. File the sticking out portion into something that will engage with a different kind of wrench (like open wrench). Some people use a saw to cut a slit for a hefty screwdriver. (And so on: use your imagination.) By using the outer end of the spindle you will be able to apply massive amount of force without the danger of cracking the hex socket.
If this does not work, throw out the crank. Next time apply anti-seize compound to the threads and unmount-remount your pedals periodically (re-applying the compound).
I had to completely disassemble a pedal, cut the shaft shorter and hit it with an impact gun one time.....it was STUCK!
Quoted: 2639 Post(s)
Liked 1,989 Times
LBS can be your friend -- if the wrench knows what he/she is doing.
Otherwise, soak it with penetrating oil for a night or two. Use a toe strap to hold the other crank against the left chainstay. 8mm hex key in a 12" socket driver, add a pipe for extra oomph. If that doesn't work or you don't have appropriate tools...
Go ask your LBS what they can do for you. It'll probably be cheaper than the socket key plus pile (my LBS did it for a smile!).
Quoted: 6348 Post(s)
Liked 4,948 Times
Twelve days later....... have you fixed this or hopelessly screwed up the crank arm? It'll suck not to have something to ride this weekend.
Quoted: 1814 Post(s)
Liked 923 Times
A bike shop will do it for maybe $5.
While visiting my daughter, I took her bike out. It had mis-matched pedals since they had never been able to get one of them off.
He had to pull out the big guns, but the wrench got it loose while I waited.
Bikes: A Few
Quoted: 156 Post(s)
Liked 63 Times
I had a pedal stuck so bad once, that I had to strip it down to the shank, drop a 1/2" nut over it, and tack weld it -
Whether it was just that I was then able to get extra leverage on it with a box end wrench, or the heat from welding helped break it loose, I don't know, but it came out then without harming the crank arm.
On the right side you can take advantage of your body weight and, standing aside the bike on that side, step onto the handle of the wrench, placed pointing toward the rear axle (i.e., unscrewing it in the usual left-to-loosen manner).
