2002 Litespeed Ghisallo -- 9mm diam BB hole normal?
Bikes: Litespeed (9); Slingshot (9); Specialized (3); Kestrel (2); Cervelo (1); FELT (1); Trek (2)
Quoted: 440 Post(s)
Liked 3,506 Times
Here's a shot of the BB shell drain hole on a 2002 Litespeed Ghisallo. It measures ~9mm diameter.
I'm used to seeing a typical ~3mm diameter BB shell drain hole on late 90s - early 2000s Litespeed road bikes, or at least typical of the ones I have.
Photo below is a 2001 Litespeed Vortex.
Concerning the Ghisallo, is this a big deal, little deal, or no deal at all?
Why the abnormally large opening on this frame? Or maybe a previous owner did it for some reason and the frame wasn't designed this way?
WTB: Slingshot bicycle promotional documents (catalog, pamphlets, etc).
WTB: Bicycle Guide issues 1984 (any); Jun 1987; Jul, Nov/Dec 1992; Apr 1994; 1996 -1998 (any)
Bikes: old clunker
Quoted: 684 Post(s)
Liked 105 Times
After about twenty-four hours of continuous navel contemplation, I usually feel the need to pore over a bike to question the diameter of each hole. Unfortunately I never seem to get past the urge no matter how many good answers are offered.
Of course you can have it welded up and re-drilled to any size you might like.
Quoted: 440 Post(s)
Liked 3,506 Times
Thanks. It's curiosity, not worry. I've seen larger total area openings on steel frames, but this was unusual for Litespeed frames and wondered whether there might be a reason for it.
I recall Litespeed marketed this frame at the time as the lightest production frame on the planet. Maybe it was the larger diameter hole that made the difference between lightest and second lightest. ;-)
Quoted: 440 Post(s)
Liked 3,506 Times
Update: Here's a photo of another 2002 Ghisallo sent to me by its owner. BB drain hole is in the same place and the same size as the one in my frame.
Apparently this was standard for that frame.
Quoted: 440 Post(s)
Liked 3,506 Times
Ha! Maybe one of those gangstas from Seven or Merlin?
Quoted: 2026 Post(s)
Liked 1,096 Times
That's odd. None of my three Litespeeds (1996 Catalyst, 2005 Firenza, 2006 Tuscany) have anything but a small (~5mm) drain hole in the bb shell just in front of the cable guide.
