Worn pulleys on Shimano 105?
Bikes: 4
Quoted: 11 Post(s)
I have this derailer on my bike: VeloBase.com - Component: Shimano RD-1050, 105
it works fairly well with the biopace rings that i got on the bike, but it seems that there is a fair bit of noise and it feels slightly clunky. I looked at it closely after lubricating the drivetrain and it seems like the two pulleys have some play/can move side to side. Is this a sign of wear or need of repair? The drivetrain feels good other than that.
Not a sign of wear, that's the way there supposed to operate.
I had the same issue with my 105 rear derailleur. Even after I lubed it. I finally completely removed it and cleaned and lubed before it stopped squeaking/squealing.
If you decide to take them apart and disassemble, remember they are not identical. One is a guide pulley and the other a tension.
working on my sandal tan
Quoted: 3873 Post(s)
Liked 2,575 Times
Bikes: '87 Centurion Ironman Expert, '88 Basso Loto, '89 Panasonic MC-5500, '92 Vitus 992
Quoted: 60 Post(s)
Liked 10 Times
Well, the guide pulley (top one, closest to the cassette/freewheel) should be a Centeron, which has lots of play, as that helps to put it in the right position. The lower one isn't Centeron.
