What is the center pole for?
On wooden bridges I always see these posts sticking up in the middle of the path. What purpose do they serve?Seems to me to be hazardous.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,099 Times
Also, a monument to Marcel Bolard, inventor of the structural impediment.
Troublemaker
Bikes: Yes. The more the better.
Quoted: 46 Post(s)
Liked 44 Times
If you don't put those up then you might get this:
https://www.bicycling.com/news/a2361...-on-bike-path/
Interocitor Command
They put those up because people are a lot dumber than they look.
Tragically Ignorant
Liked 9,099 Times
Because sometimes the middle finger isn't enough.
Been Around Awhile
Bikes: Vaterland and Ragazzi
Quoted: 12 Post(s)
Liked 1,590 Times
Maybe so, but when hitting a pretty good clip going downhill they are dangerous. If they are installed to keep cars off of them then why arent they on the other parts of the path.
Bikes: 2021 S-Works Turbo Creo SL, 2020 Specialized Roubaix Expert
Quoted: 768 Post(s)
Liked 4,094 Times
Tragically Ignorant
Liked 9,099 Times
The worst placement of these things is in a shady spot at the end of a curve. You can be almost on top of them before they become visible.
Old fart
Quoted: 3617 Post(s)
Liked 3,454 Times
Quoted: 1002 Post(s)
Liked 237 Times
If you hit a 4 foot tall non moving object with your bike, that's no one's fault but your own.
You are responsible for where you steer your bike.
If you hit the pole because you were looking down at the ground, that could have just as easily been a person you didn't see.
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
I don't mind the poles so much. Some of ours have giant boulders instead. Those get scary at the bottom of a hill or when one is trying to ride with a trailer.
Quoted: 18459 Post(s)
Liked 4,563 Times
Blame it on the city for not posting a low bridge warning.
Liked 4,563 Times
The posts are called Bollards. And they can be a major pain for people pulling trailers.
I don't think I've bumped many, but I find them terrifying to go between.
There was a photo in another thread where a cyclist hit a poorly marked one in the middle of a shady patch on the bike path.
There are some up the McKenzie that are set narrow enough that a bike carrying panniers might have troubles. And, if one was pulling a trailer, it would have to be disconnected and lifted over the top.
Tragically Ignorant
Liked 9,099 Times
I've never hit one, but I've sure seen ones where you could be going a reasonable speed and not see it before it was too late. One of the things people don't take into account is the tendency of other traffic to screen upcoming obstacles from view. You combine that with going from bright sun to shade, going around curves, and bollards that aren't painted to stand out from the background, these things can be dangerous at 10-15 mph.
I know I'm ultimately responsible for keeping myself safe from the effects of bad design, but that doesn't mean people shouldn't be warned about it.
Liked 3,160 Times
at least they use identifiers on the objects rather than leave it natural wood color...
-Oh Hey!
-Oh Hey!
Liked 4,563 Times
Depending on the bike, trailer, and bollards, I may only have a couple of inches of clearance, and hitting the bollard could mean stopping the bike cold (again depending on the trailer).
I usually take the bollards slow.
I did have a temporary barricade that reached out and grabbed the quick release on my trailer, I think. Bang... STOPPED.
I've flipped my trailer at least 3 times.
Once hiting a really bad curb cut.
Once hitting a curb dividing a turn lane.
Once hitting a pothole.
Bollards / poles on bike and multi-use paths usually allow enough room for bikes pulling trailers, trikes and tandems to pass without risk. Chicanes, such as the ones on the bike/pedestrian paths alongside some bridges practically force tandems, trikes and bikes pulling trailers to stop and walk through the obstacle. I understand that there are more than a few cyclists that will fly down paths like endangering anything slower on the path. We were able to navigate the chicanes in Montreal without dismounting our tandem. In France, we encountered a couple of gates put in place to prohibit vehicles but allow pedestrians and cyclists where the opening was barely as wide as our handlebars. I might have tried to ride through on a single but I deemed the risk too high to pilot a tandem through the opening.
This site at the link below has examples of UK obstacles.
https://www.cyclinguk.org/article/cy...on-cycle-paths
Picture below is a chicane on one of the bridges in Montreal
SE Wis
Quoted: 2756 Post(s)
Liked 3,427 Times
Quoted: 915 Post(s)
Liked 516 Times
The paths in my town have removable bollards similar to this so police/rescue/parks dept maintenance trucks can unlock and drive down them. If I ever hit one on a bicycle and didn't get badly hurt I don't think I would ever admit it.
Palmer
Quoted: 1706 Post(s)
Liked 1,899 Times
We have one on a tiny bridge that is after a downhill curve. In addition it has gravel in front of the bridge. Only a matter of time before an accident. It also is sketchy to ride around ice patches when such bollard is added. I imagine trailers, tandems etc. will have even harder times.
That bollard is just a square 1.5" steel type less than 3' high. It would be safer if it was taller and wider and in warning color to see it better. I never measured that bridge, but may be only 5' wide, maximum 6'. So no reasonable car could cross it anyway. But less than 3' on each side creates a challenge.
