Galvanic corrosion when using copper anti-seize on alu?
Quoted: 915 Post(s)
Liked 516 Times
I use whatever is at hand but I'm no machinist.
https://www.practicalmachinist.com/v...mpound-184595/
This is a good all purpose choice:
Permatex
Permatex
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
The copper reduction potential is +0.34 V. The oxidation potential for aluminum is +1.66 V. The net standard-state galvanic potential is thus +2.00 V. So you will have a pretty good battery.
I'm sure Hope Hicks has the definitive opinion.
is this just another case where theory and reality are out of touch.
"best" galvanic combination is carbon and zinc... Stacked, alternating , is a dry cell battery..
steel frames with aluminum seat posts and stems left in too long ,
is a popular theme for 'how do i get it out?', request thread topics..
aluminum in aluminum should not be an issue
add some silicone caulk to seal the top edge, if really worried..
Quoted: 1441 Post(s)
Liked 1,095 Times
I use Tef-Gel on all dissimilar metal joints such as BBs, pedal threads, etc. Itcontains 40% PTFE powder and is specifically intended to resist electrolytic corrosion under marine conditions: https://www.tefgel.com/contain.php?param=tefgel_infor A little goes a long way.
Quoted: 4884 Post(s)
Liked 4,049 Times
So I just recently heard about something called galvanic corrosion. Supposedly, this can occur between copper and aluminium when a catalyst (salt water) is present.
I am planning to use copper grease in my current build between aluminum components, some of which will experience salty conditions on the road.
Have any of you experienced any corrosion of this kind or is this just another case where theory and reality are out of touch.
Should I consider alu/graphite anti-seize, or is there nothing to worry about?
Thanks in advance.
Kret
Thanks in advance.
Kret
Ben
Im not intimately familiar with these products, but several manufacturers specifically recommends zinc based anti seize for aluminium joints.
https://www.henkel-adhesives.com/jp/...e_lb_8044.html
I just use grease and it has been perfectly adequate.
My question for you:
Why use something that you know can accelerate a galvanic reaction, when you can use tin anti-seize that is meant for that exact case.
Why use copper grease? For what purpose?
Bikes: Homebuilt steel
Quoted: 2214 Post(s)
Liked 429 Times
OP is asking a question, not challenging the masses.
As mentioned by others, zinc anti-seize would be a better choice than copper. Grease would also work. Any kind.
Bikes: Felt Z5, Look 675 Light, Specialized Diverge
Quoted: 48 Post(s)
I've switched to using this for all my anti-seize applications and have been very happy with it. It has no metal or conductive content so you get no galvanic action at all:
https://www.amazon.com/Permatex-2412...JGTV8XRPSXE1Q0
