Go Back  Bike Forums > Bike Forums > Fatbikes
High Quality Pump & Co2 set-up. What Are You Using?
Fatbikes Designed for use in sand, mud or snow, Fat bikes are the right choice for true all-terrain riding. Check here for the latest on these fun, adventurous two-wheeled machines.
Old 04-21-19, 09:35 AM
venturi95
Firm but gentle
venturi95's Avatar
Bikes: 2005 Litespeed Tuscany, Soma Pescadero, Pure Cycles disc road, Jamis hybrid
Quoted: 159 Post(s)
Liked 104 Times in 60 Posts
New Fatbike owner, I need to be prepared. So what can you recommend? I'm looking for something super reliable as I plan to get out there.
venturi95 is offline
Old 04-21-19, 12:10 PM
wbrazell
CO2 with two 20gram cartridges.
wbrazell is offline
Old 04-21-19, 10:57 PM
venturi95
Firm but gentle
venturi95's Avatar
Quoted: 159 Post(s)
Thanks. I was thinking the Co2 is just to finish off the job once there is some small amount of pressure in the tube. I have been really pleased with the Leyzene pumps and will get their Co2 adapter too. I had a Topeak road morph that was excellent for my touring bike use, but it seems like carrying a small floor pump.
Old 04-22-19, 10:58 PM
MarcusT
MarcusT's Avatar
Quoted: 766 Post(s)
Liked 617 Times in 344 Posts
I bring the tire sealant repair aerosol (still using tubes). I get quite a few flats and the sealant helps quite a bit for future punctures. It does make the tire heavier
MarcusT is offline
Old 04-24-19, 12:03 PM
5teve
Quoted: 69 Post(s)
Liked 65 Times in 29 Posts
Blackburn mini pumps have always been great for me. Lifetime warranty as well. When I'm going "out there," I also carry a tubeless repair kit and often a tube just in case. Might consider a small bottle of sealant too.
5teve is offline
Old 04-25-19, 08:20 AM
prj71
Quoted: 2976 Post(s)
Liked 1,182 Times in 771 Posts
For fat bikes...Topeak Race Rocket MT...
https://www.topeak.com/global/en/pro...-racerocket-mt
prj71 is offline
Old 04-25-19, 07:44 PM
Howard70
Quoted: 8 Post(s)
Liked 11 Times in 10 Posts
I carry a Lezyne Micro Floor Drive XL. 100 strokes to fill a 5 x 26" tire. I used a couple of others that wore me out before setting on the Lezyne. I'm set up tubeless with Caffelatex sealant and strips - that reduces weight a lot compared to a tube and then trying to seal with an aerosol set up.
Howard
Howard70 is offline
Old 04-29-19, 09:08 AM
prj71
Howard
Topeak Race Rocket MT is about half the amount of strokes to fill that size tire.
prj71 is offline
Old 05-23-19, 06:08 AM
darwink1
Liked 13 Times in 6 Posts
I was just thinking, a co2 pump would be so freaking fast for fb tires... Gotta snag one.
D
darwink1 is offline
Old 05-30-19, 10:48 PM
Dr.Lou
Dr.Lou's Avatar
Quoted: 47 Post(s)
Liked 97 Times in 61 Posts
How many 16 gr cartridges needed for 10 lbs in 26x4.8?
Thanks
Dr.Lou is offline
TromboneAl
Fifty Plus (50+)
58
06-07-13 05:08 PM
JimF22003
Fifty Plus (50+)
36
03-15-13 02:09 PM
Scorpion King
Road Cycling
15
03-08-11 02:27 PM
Palomar01
Road Cycling
62
09-08-10 07:28 PM
NABRXX
Commuting
111
08-08-10 01:47 PM
