One of those idiot newbie questions.....
Quoted: 5 Post(s)
Liked 7 Times
So... Hoping somebody could help me out with an idiots guide to wheels. I've had a search on Google but I just keep going round in circles.
Basically, I've ordered a new bike (caad optimo tiagra, the not a disc one) - but I need to change the wheels to a higher spoke count as I'm 15lbs over the weight limit. Just going to order a cheap set off ebay that will be fine for a month and get them trued etc locally.
I'm trying to figure out what to order, and as stupid as it sounds I'm getting confused about how wheels work (I know they go round). What exactly is a rear hub? I see plenty of wheels for sale that are for 7/8/9 speed - I need 10? So does an 8 speed one include a rear hub that accommodates 8 speed and I can just buy a tiagra compatible hub? Or is the hub what the spokes attach to?
The bike comes with 32 rear 31 front hubs, so would I need to buy new hubs anyway as I'm looking at some 34h rims. Do wheels have specific hubs you have to buy for them?
Cheers for any advice.
Likes For Hanky1984:
Quoted: 2953 Post(s)
Liked 3,106 Times
Tiagra is 10-speed made by Shimano.
You need need a wheelset that accepts a 10-speed Shimano cassette. This shouldn't be difficult, it's practically the default.
I have never heard of 34h rims. Hub and rim drillings are usually in multiples of 4. (Although there could be some obscure boutique wheels out there that have this, I've never seen any).
Don't Bug Me
Not saying manufacturers guidelines should be ignored at all, but if it were me, I would just ride it as is. If the wheels get out of true or you get a spoke problem address it then but I would bet you will be fine. Heck, odds are, if you like the bike you will be hitting the road so often you’ll be in weight spec in no time.
Likes For mantis:
As @caloso noted, the spoke numbers you mention (34h, e.g.) don't make sense but yes the number of spokes holes in the rim need to match the hub. But if you are buying a prebuilt set of wheels, that will be accounted for. At your size, I would recommend getting 36h wheels with good mid range rims and hubs. You can usually find good deals on sites like velomine...for example H Plus Son Archetype Wheelset Shimano7000 105 Hubs 36h DT Comp [741899] - $219.00 Velomine.com : Worldwide Bicycle Shop, fixed gear track bike wheelsets campagnolo super record vintage bike
Should Be More Popular
Quoted: 22715 Post(s)
Liked 9,079 Times
Quoted: 7687 Post(s)
Liked 3,591 Times
In this and the related thread, several people have recommended just riding the thing .... it may be that spending a lot of money for new wheels simply isn't necessary.
As I noted, I ride 28/24-spoke wheels, and am bigger than an elephant, and have broken three spokes in three or four years. You might get by just fine by just riding.
Quoted: 3261 Post(s)
Liked 2,577 Times
If you are worried about weight limits, you should post your question in the Clyde forum. You probably will get better answers there. That being said, I would ride it as is. The current wheels will either hold up or not. If they don't, then you can think about a new set.
Likes For seypat:
1. Ride it as is + 1
2. Don't descend >10% x >0.5 mi segments, until you meet the wheel weight requirement.
