650 wheels
Liked 353 Times
650 wheels
Will smaller wheels mean gearing difference riding compact cranks currently.
i heard that small wheels require larger gearing
Bikes: 1973 Raleigh Super Course - 1981 Velo Sport Criterium - c.1988 Colnago Master Piu - 1991 Merlin Road - 1991 Eddy Merckx Corsa Extra - 1995 Pinarello Cromovan - c.1999 Lemond Maillot Jaune Team Saturn - 2002 Colnago C-40 - Also modern stuff
Liked 38 Times
Since the circumference of a 650 wheel is smaller, it would make sense. For the same gear ratio, you would be a bit slower on 650. Not sure this requires changing your chainrings. Unless you are already overspinning your 50x11
![Speedy](images/smilies/speedy.gif)
which 650? (A,B, C ) popular now 650 B is a smaller rim but a wider tire ..
650 A is bigger rim skinnier tire.
Sutherlands lists a 650 with a ETRTO bead seat diameter of 597 mm....
what do you have?
what do you have?
working on my sandal tan
Liked 2,579 Times
![Wink](images/smilies/wink.gif)
Use a handy gear calculator to express the various combinations of wheel size, tire size, chain-rings and cogs as Gear Inches for direct comparison.
https://sheldonbrown.com/gear-calc.html
My two cents - I ride 650s on my tri bike and 700s on my road bike. I find I can use the same components on both and really do not notice that much of a difference. Gear for 650s is just becoming harder and harder to find.
instaant
Singlespeed & Fixed Gear
23
11-27-15 11:26 AM
dwellman
2
10-16-11 01:56 AM
