$1270 to save 1/2 lb at the rim?
Old 06-11-19, 11:20 AM
TimothyH
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times in 469 Posts
Would you spend $1270 for new wheels to save 223 grams (7.87 oz) if all the weight savings were at the rim?
The new wheels would be exactly the same as the existing wheels except for much lighter rims. Assume for now that the hubs, spokes, nipples, tires and tubes are already as light as they can go.
The bike flies and I've no need for new wheels. This would be a luxury purchase.
Wheels would be built by ProWheelBuilder and come with 2 year warranty and lifetime 25% off crash replacement. I could probably sell the existing wheels for a couple hundred.
This is on a sub 16 lb bike.
-Tim-
TimothyH is offline
Old 06-11-19, 11:21 AM
Skaughtto
Commuter
Bikes: Domane 2.0, CrossRip LTD
Quoted: 19 Post(s)
Liked 3 Times in 3 Posts
Nope.
Skaughtto is offline
Old 06-11-19, 11:23 AM
dalava
Bikes: Moots Vamoots, Colnago C60, Santa Cruz Stigmata CC, and too many other bikes I don't ride
Quoted: 152 Post(s)
Liked 7 Times in 6 Posts
shallow or deep aero wheels?
dalava is offline
Old 06-11-19, 11:28 AM
TimothyH
- Soli Deo Gloria -
Shallow. Boyd 28 clinchers.
They would replace H+Son Archetypes.
The bike has an Enve flat top aero bar if only for comfort and looks, and I supposed the Enve 2.0 fork is aero enough but tubes are round and the bike isn't designed with aero in mind. Increasing aerodynamics would not be a benefit. All the benefit would be weight. I'm not a particularly powerful rider.
If anyone knows of a lighter/cheaper rim brake carbon clincher then I'm all ears.
-Tim-
TimothyH is offline
Old 06-11-19, 11:31 AM
Seattle Forrest
Seattle Forrest's Avatar
Quoted: 18883 Post(s)
Liked 10,646 Times in 6,054 Posts
Personally I would not.
Unless I really wanted them.
Seattle Forrest is offline
Likes For Seattle Forrest:
Old 06-11-19, 11:36 AM
Litespud
Quoted: 645 Post(s)
Liked 797 Times in 446 Posts
My rule of thumb used to be, when making the weight vs cost trade-off was, that I would spend up to a dollar per gram saved for static weight, or up to a dollar per 1/2 gram saved for rotating weight. I'm less concerned about weight nowadays - I need to lose 15 lb off my arse before I start obsessing about bike weight. But, my comfort levels are not yours, and if you have the cash and the wheels make you feel good, go for it.
Litespud is offline
Old 06-11-19, 11:40 AM
dalava
Quoted: 152 Post(s)
The money would be much better spent with something deeper, e.g. 40-50mm, while keep the weight the same or a bit less than your current wheelset. Personally, I would just get a set of used but great condition Zipp 303's for about $1k, or ENVE SES3.4 for $1.5k.
dalava is offline
Old 06-11-19, 11:46 AM
PepeM
PepeM's Avatar
Quoted: 2739 Post(s)
Liked 119 Times in 59 Posts
If I would, I already would have. Since I have not, then no.
You do whatever you want.
PepeM is offline
Old 06-11-19, 11:56 AM
tagaproject6
tagaproject6's Avatar
Quoted: 551 Post(s)
Liked 277 Times in 145 Posts
If it's a luxury purchase and you can afford to be luxurious...go for it!
tagaproject6 is offline
Old 06-11-19, 12:13 PM
noodle soup
noodle soup's Avatar
Quoted: 4717 Post(s)
Liked 1,882 Times in 998 Posts
I don’t have that kind of money to burn, but if $1300 was pocket change, sure.
is your annual income over $338k ?
noodle soup is offline
Old 06-11-19, 12:51 PM
rubiksoval
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times in 711 Posts
No. But I'd probably spend about half that money on some wide-rimmed, 50+ mm carbon wheels if my intentions were maximizing speed.
rubiksoval is offline
Old 06-11-19, 12:55 PM
noodle soup
$800 will get you that from Light Bicycle
Old 06-11-19, 12:57 PM
bikebreak
Quoted: 129 Post(s)
-Tim-
If you want to save grams and $ go carbon tubular.
Tubular rims are less popular than clincher, so resale prices are lower, you can pick up zipp 303 or nice Reynolds rims for $500ish on ebay. I've done it. The zipp 303 tubular rims are around 380g for 45mm deep, that beats any alloy clincher by far
My regular wheels now are tubular Bontrager Aeolus, I got used and got tires on them for less than half of your $1270 budget.
The other day I saw ax lightness tubular 24mm for around $1200, those are 215g rims...with good tubular tires you save 500+ grams rotating mass vs alloy clinchers. your bike will be under UCI weight
bikebreak is offline
Old 06-11-19, 01:55 PM
Rides4Beer
Bikes: SuperSix Evo | Revolt
Quoted: 733 Post(s)
Liked 815 Times in 414 Posts
-Tim-
My 46mm Light Bicycle wheels are lighter and only a lil more than half the price. Catch is you have to wait about a month to get them, but the quality is great, and customer service is good too. They have a North American operation as well, if you don't want to buy direct, it's a lil more expensive tho.
They have a similar spec wheel to what you're looking at, just under 1300g with Bitex hubs, 1450g with DT240s.
https://www.lightbicycle.com/U-shape...ompatible.html
Rides4Beer is offline
Likes For Rides4Beer:
Old 06-11-19, 02:32 PM
datlas
Should Be More Popular
datlas's Avatar
Quoted: 22598 Post(s)
Liked 8,925 Times in 4,158 Posts
Aero trumps weight, right?
So no.
Originally Posted by rjones28
Addiction is all about class.
datlas is offline
Old 06-11-19, 02:55 PM
Carbonfiberboy
just another gosling
Carbonfiberboy's Avatar
Quoted: 3889 Post(s)
Liked 1,938 Times in 1,383 Posts
No. How much would you pay a dietitian to help you lose 1/2 lb? Think of it that way. You can spend $6,000 to get a bike that's 3 lbs. lighter, or you can lose 3 lbs. OTOH if your fat % is below say 7, maybe spend the money . . .
Results matter
Carbonfiberboy is offline
Old 06-11-19, 04:52 PM
Sy Reene
Advocatus Diaboli
Sy Reene's Avatar
Quoted: 4733 Post(s)
Liked 1,532 Times in 1,003 Posts
Is the weight savings for the wheelset or per wheel?
Sy Reene is offline
Old 06-11-19, 05:08 PM
TimothyH
- Soli Deo Gloria -
I'm 5' 10" and went from 198 lb to 170 lb last winter, so I feel like I'm good.
Thanks. I'm going to email them but here is the rub...
The bike is fixed gear and the hubs use 15 mm track nuts. To be clear, it isn't a track bike and will never be ridden on the velodrome. It is used exclusively for road riding.
As a general rule, track hubs are not light but the ones on the bike now are about the lightest available - 176 g front/224 g rear - and go for about $150/pair. ProWheelBuilder would build the wheels around them with whatever rim, spoke and nipple I choose.
The front could use a traditional road quick release but I'm not going to save much weight and it would drive up cost. I want matchy-matchy hubs for the sake of pride anyway.
If a company like Light would build a wheelset around my hubs with their rims at $700 and they came close to 1300 grams then I'd go for it.
-Tim-
TimothyH is offline
Old 06-11-19, 05:10 PM
TimothyH
- Soli Deo Gloria -
Sorry, total, not per wheel.
Ha ha, I'd love to save 14 oz per wheel!
-Tim-
TimothyH is offline
Old 06-11-19, 05:34 PM
Marcus_Ti
FLIR Kitten to 0.05C
Marcus_Ti's Avatar
Quoted: 2349 Post(s)
Liked 406 Times in 254 Posts
-Tim-
Carbon clincher and rim brake...I wouldn't do it. Saving weight or not.
Marcus_Ti is offline
Old 06-11-19, 08:06 PM
noodle soup
Oh Nose! It'll assplode.
Old 06-11-19, 09:15 PM
Jon T
Bikes: '84 Peugeot PH10LE
Quoted: 397 Post(s)
Liked 55 Times in 39 Posts
You could probably lose more body weight and it wouldn't cost a dime.
Jon
Jon T is offline
Old 06-11-19, 09:25 PM
eflayer
Quoted: 33 Post(s)
Liked 21 Times in 15 Posts
current wheel weight
compare for us the current wheels with the prospective wheels.
eflayer is offline
Old 06-11-19, 09:27 PM
Seattle Forrest
Body weight and bike weight aren't really connected except when you're riding up a hill. You can be twice Timothy's (healthy) weight and still enjoy having a light bike - check The Rules, nothing prohibits it.
I personally wouldn't buy the wheels we're talking about because I have wheels I love ... but it's easy to understand the appeal of a 14 pound bike. Especially for someone who has other bikes.
Old 06-11-19, 09:44 PM
Dr.Lou
Dr.Lou's Avatar
Quoted: 47 Post(s)
Liked 97 Times in 61 Posts
For me it’s not worth it to save 1/2 a pound, but I’d gladly pay it if I thought the wheels were cool and they put a smile on my face.
Dr.Lou is offline
