Rack user error -- got SO lucky
Keepin it Wheel
Liked 3,751 Times
mcours2006 just had a close call, I had my own last night. I leave my car at work as much as possible, where it can get free shade in the parking deck. I leave a bike rack on the back (saris bones). Last night I needed to use the car, so I drove down to the bike parking area, and tossed my bike on.
When I got on the freeway and started to pick up speed, at about 60 I see in the mirror my bike fly off!!! I'm such an idiot I put the bike in the cradles and forgot to close the buckle straps! (got distracted by bungeeing the front wheel in place so it wouldn't flop)
In the mirror while I'm slowing down (or probably mostly before I have time to react) I saw the bike take a bunch of tumbles.
FORTUNATELY (I'm so relieved and grateful)
I made it to the bike and grabbed it out of the road as quick as I could (felt like a car made a rudely close pass towards my head!), got the bike back up on the rack, WITH THE STRAPS BUCKLED, and went on my way.
All things considered, the bike is in great shape, I haven't had time for a full, close inspection yet.
Everybody feel free to berate me in the comments, and I'll give updates about getting it fixed back up.
Stay safe out there everybody, double-check your racks!
- Nobody was directly behind me
- The bike stayed in the right side of the right lane
- In that section of freeway, the vast majority of traffic is in the left lanes
- The frame (CrossCheck) is I'm sure totally fine. I guess there's a possibility the fork could be bent, but it looks ok
- The carbon seatpost seems fine, with a good bit of force I twisted it back mostly straight, so it seemed solid.
- The Selle Anatomica Titanico X sustained deep scrapes on the nose and the rear. Doesn't seem anything like about to tear apart. Not sure if I should soak with sno.seal, or apply wax, or what, to try to protect the exposed raw leather, or just ride it.
- The tires (new Schwalbe Hurricane, 700x50 in the back, 700x42 in the front) are fine and the tubes didn't pop.
- The rear wheel (32-spoke Velocity Dyad) is definitely bent, but not completely taco'd. I might be able to curb-stomp it back to where I can make it good enough with a spoke wrench.
- The front wheel looks straight, but I can't spin it yet because the handlbars and brake levers all shifted around which caused the canti brakes to lock.
- The shift cable housing coming out of the Retroshift (Gevenalle) levers got sheared open, but the shifters and brake levers are fine (no need to take advantage of Gevenalle's $18 repair/rebuild/replace for any reason policy)
- The cygolite hotshot is broken. I got it for free because my wife found it, and I have said many times if I ever lost it I would pay to replace it, so I will definitely do that. The headlight (flashlight hoseclamped to the handlebars) is loose but seems ok. Didn't actually test turning it on.
- The flimsy plastic water bottle cage is intact, and I recovered my beloved Sriracha water bottle on the side of the road.
Keepin it Wheel
Liked 3,751 Times
I was paranoid about driving with the bike even with the straps buckled after that, and I probably will be for life! (which is a good thing)
Liked 3,680 Times
oh man! glad you didn't perish on the highway! yikes!
one time I did something similar, mine didn't fly off the rack but it was lifting in the wind & sliding to the rear. I was able to pull over & correct my mistake
Keepin it Wheel
Liked 3,751 Times
A friend told me once his entire rack slid off his roof with a bike. Before he got to it he heard 'thumpthump', and the bike was totaled. Although I guess whoever drove over it was ok
Bikes: 1996 Trek 970 ZX Single Track 2x11
Liked 638 Times
Did that once with a kayak.
Nothing quite compares, at least in my experience, to seeing a 13ft kayak slide off the roof and over the hood into the intersection. Never struck a thing. Just skittered across, into the yard on the other side. Embarrassing.
But, other than a few scratches on the underside, no problems. Had failed to tighten the straps. Never did that again.
Bikes: ...a few.
Liked 410 Times
A friend of mine forgot he had his expensive carbon bike on the roof of his car and went through one of these parking garages with a maximum clearance. Needless to say he didn't clear.
Liked 1,760 Times
I had a trailer hitch bike rack on my Mustang in the 80s & 90s. I had a trunk-muont rack on my Subaru in the 2000s and early 2010s. I now have a Nissan Rogue and lay the bike in the back (drive side up).
No more rack anxiety. No more worrying about leaving the bike locked on the rack.
With the use of old blankets and pillows I can even put both my bike an my wife's bike in the back together.
When it was time to get a new car I specifically looked at an SUV/Wagon for this reason.
Disco Infiltrator
Liked 2,150 Times
Oh man.
For a moment I thought maybe your rack on your bike had come apart and you had eaten it. Surly published a recall on their front racks this morning.
Genesis 49:16-17
Genesis 49:16-17
always rides with luggage
My Motobecane Fantom CX took a flying leap off the back of a buddy's Prius at 80+mph on the way home from a metric. The frame clamp was on a bottle and not the frame. He ran into traffic to get it. Needed a new seat (he gave me one of his spares), new rack, new handlebar. Everything was awesome. Still have the bike.
--Ben
2006 Trek SU100, 2009 Motobecane Fantom CX, 2011 Motobecane Fantom Cross Uno, and a Bakfiets
Previously: 2000 Trek 4500 (2000-2003), 2003 Novara Randonee (2003-2006), 2003 Giant Rainier (2003-2008), 2005 Xootr Swift (2005-2007), 2007 Nashbar 1x9 (2007-2011), 2011 Windsor Shetland (2011-2014), 2008 Citizen Folder (2015)
Non-Bike hardware: MX Linux / BunsenLabs Linux / Raspbian / Mac OS 10.6 / Android 7
--Ben
Keepin it Wheel
Liked 3,751 Times
So, update:
The rear rim was bent, I couldn't straighten it, so I swapped in a spare wheel I had laying around. It is laterally true but has a radial hop that has me bouncing in resonance at about 9mph. Eventually I'll buy a replacement rim and lace up the old hub and spokes.
After a little touch up with the spoke wrench, the front wheel seems fine. Fork too.
Brake levers and stem all came loose from the impact, I tightened them back up, and patched torn bar tape with a wrap of electrical.
My interlocked hose clamps for my headlight were loosened, and the body of the light ovalized. I rounded it a little better with vise grips and put it back on with new hose clamps.
Seat is scraped at the back and the nose, but leather seems not about to tear. Also the rails are bent, but they each seem to be bent the same (not slanted) and it's still holding my weight, so I'll keep riding it.
I've been riding it for about a week now, and except for that annoying hop, it seems as good as 'new'.
Left the fork mount QR unsecured, and watched in slow terror as my Bridgestone MB-2 leaned over to the horizontal plane. Stopped the car and found my bike still on my rack, but the left fork dropout bent at a 90 degree angle. Bike never came off the car thanks to a rear wheel strap holding it on. Straightened the dropout (steel rigid fork) with a large adjustable wrench and went on my way. Never had a problem with it, and ride that bike for several years afterward.
Keepin it Wheel
Liked 3,751 Times
Got a rim for xmas, and a buddy who has a nice truing stand and tensiometer let me build my wheel up under his supervision yesterday. Rode it into work today -- it's nice to get off my backup wheel which had a terrible hop!
Likes For RubeRad:
Keepin it Wheel
Liked 3,751 Times
I've done it once (except it was a balcony and it was (excruciatingly!) low speed, and my wife will never let me put a bike on a roof rack again. (that bike was a mongoose mtb, $50 from CL, so no great loss)
BITD, I started with a rear rack. When I got rear-ended, it destroyed the rack, bent the bumper to the point where I couldn't add fuel, bent the seat stays and top tube, and did some damage to nearly every component of the bike. It hit the rims so hard, the tension of the spokes bent the high-flange hubs. I had ZERO option to avoid it.
So I got a roof rack. I hit the garage once. Bent the rack, dented the roof, creased the siding on my stepmother's garage, no damage to the bike. And it was my fault.
Next motor vehicle was a hatchback, I started putting all bikes inside, and never looked back. I haven't owned a car with a trunk since, in close to 40 years.
At least with a roof rack, any low-clearance damage done is done by me, and can be avoided by me. With a rear rack, I'm not driving the car behind me that can rear-end me.
Keepin it Wheel
Liked 3,751 Times
I have an idea in my head for a roof rack system where the bikes lean over diagonally as much as possible, with a strut coming up to grasp the top tube. The strut should be extendible/adjustable so you can lean the bike at multiple angles, depending on how many bikes and other roof cargo you're working with.
I don't have any good ideas how to DIY something like that.
(Although many years ago I did this -- that was the system holding the mongoose that I drove into a balcony. I can't even remember whether that wooden mount survived the incident, but the rectangular cross-bars were bent)
Trunk is better
Bicycle in the trunk of 2004 Scion xB
If something doesn't ache, I could be trying harder.
Likes For striegel:
Disco Infiltrator
Liked 2,150 Times
Years ago I was on my motorcycle and spied a guy with bikes flopping around on top of his car. I tried to chase him down - he either thought I was malicious or wanted to race, because he went faster and faster... I finally pulled alongside about 100 mph and got his attention on me and not my bike, and pointed to his roof. 100 on that particular bike was not a fun place to be, and in long hindsight I should have let him go.
My present situation is minivan / pickup truck / travel trailer so this doesn't really come up that much
Genesis 49:16-17
Genesis 49:16-17
I wasn't as lucky as most OP here. My rack was on the back of the pickup, went about 15 miles. When we got to where we were going, we got out and there was no bike in the rack anymore. I drove back through the same route. Never did find it or even a trace of where it happened. Somebody somewhere may be enjoying that bike yet today.
Liked 446 Times
I've been considering the same thing. Did you actually bring your bike to the test drives and did a fit check? Did the owner/dealer ever have an issue with that?
Tried it and made sure
Yes, I took the bike along to several car dealers for actual field checks of the fit. Most of the other candidate cars at that time failed, but the local dealers were very helpful in letting me try. When I attended the Cleveland auto show in 2004, I just brought along the measurements when I confirmed the xB would work.
