Carbon seat post?
Bikes: Had an old Columbia in the 80's, here a used Schwinn hybrid, now a Cannondale Quick 3 and a Topstone 105..
Quoted: 249 Post(s)
Liked 306 Times
Carbon seat post?
Has anyone here used a carbon seat post on a aluminum frame bike? My question is, does it have any effect on felt vibration? I realize it would not be the same as a carbon frame but I noticed a real improvement between my bike with a steel fork to carbon fork bike of the same make and model, so is there an improvement with the seatpost? Also, if you would recommend a brand it would be appreciated. Thanks in advance.
Frank.
Frank.
Although I had a steel frame, not aluminum, I was unable to detect any appreciable difference between a carbon post and aluminum post.
Likes For TiHabanero:
Quoted: 2953 Post(s)
Liked 3,106 Times
I have a carbon seat post on my Al crossbike. I don't think I could notice an appreciable difference in vibrations. That's mostly about tires in my case.
One thing to keep in mind with CF-Al interfaces is that you need to make sure you pull it out every once in awhile.
Likes For caloso:
Quoted: 249 Post(s)
Liked 306 Times
Thank you both for your responses.
Frank.
Frank.
Seat Sniffer
Quoted: 947 Post(s)
Liked 2,034 Times
I have a carbon seat post on an Al bike with carbon seat and chainstays.
Zero difference with the carbon seat post.
Likes For Biker395:
Quoted: 1814 Post(s)
Liked 923 Times
I find it makes a difference, but only a select few carbon posts have much flex.
My favorite is an older Specialized two-bolt w/ "zert" insert. A bit hard to find now.
The more current Specialized with one bolt is good as well, but the pivot mechanism is a PIA.
Velonews did a test in 2012 that was useful:
The FSA one is also hard to find- many (some at least) broke.
Likes For woodcraft:
Quoted: 1514 Post(s)
Liked 735 Times
You'd want to grease the interface and periodically remove and clean in any case of dissimilar materials. With a carbon seatpost, you'd use use carbon assembly paste instead of grease.
Likes For BlazingPedals:
Quoted: 18427 Post(s)
Liked 4,544 Times
Likes For CliffordK:
Quoted: 1108 Post(s)
Liked 1,827 Times
I have a carbon seat post in an aluminum frame. I concur with above opinions, I can't feel any difference between the carbon post and an aluminum one.
Likes For nomadmax:
Liked 3,106 Times
Yes, I discovered this with my first CF bike, a Trek 5200 that came stock with an Al seatpost. It had galvanically welded itself in there and the bike shop had to put it in a bench vise to get it out. Replaced it with a Specialized CF post which I've used for many years. Still should use assembly paste and take it out every once in awhile.
Likes For caloso:
Hump, what hump?
Bikes: See signature
Quoted: 337 Post(s)
Liked 227 Times
The carbon post seemed to help on my Specialized Secteur.
Likes For horatio:
Quoted: 7680 Post(s)
Liked 3,570 Times
I swapped an Al seatpost for carbon on a my Dawes. I felt a very strong dampening of Placebo vibrations, which justified the cost of the post.
Likes For Maelochs:
Quoted: 249 Post(s)
Liked 306 Times
Much appreciated,
Thank you all for the input, Frank.
Bikes: trek 720 multitrack hybred, 92 trek 2300, 2010 specialized roubaix, 2014 specialized roubaix
Quoted: 14 Post(s)
Liked 17 Times
if you get a $$$$ specialized CG-R seat post they make a big difference.
https://www.ebay.com/itm/Specialized...IAAOSwxbNdo96P
Likes For mrt2you:
Quoted: 1172 Post(s)
Liked 447 Times
I’ve written about my Ritchey Superlogic “Flexlogic” post in another thread where I talked about my tiny (for me) titanium road bike that I made work for me. By having my 330mm post maxed out at the limit line.
I can’t validate the flex with an instrument but I suspect the fact that this setup has some flex is not a placebo.
A guy on our group ride the other night had an Ergon leaf spring type carbon post on it. I actually could see the flex while riding from the rear. He was having slippage issues and we got to rest and watch on the roadside while he slid the post out and played around with the 2 opposing carbon fiber half cylinders which he said adjusted the flex level.
Likes For masi61:
Quoted: 249 Post(s)
Liked 306 Times
masi61 "I made work for me my having my 330mm post maxed out at the limit line".
This was my next question, is there more of an "effect" of vibration dampening when more of the post is exposed? My logic tells me that would be the case but having no personal experience for me it is just a guess? Thanks again for the feedback.
Frank.
Frank.
Liked 447 Times
Frank.
Frank.
Likes For masi61:
Let's do a Century
Quoted: 651 Post(s)
Liked 879 Times
After doing some research I put one of the Specialized Zertz carbon posts on my titanium gravel bike when I was building it. I think I got it off eBay. Just make sure you get one long enough to insert far enough into the seat tube if you make a change.
Ride your Ride!!
Ride your Ride!!
Likes For jppe:
Liked 3,570 Times
Yes but also more load on the end of the post where it inserts. I eventually went back to Al because I broke two CF posts (very long posts at max exposure.) Depends on your body weight i'd guess.
Likes For Maelochs:
Quoted: 249 Post(s)
Liked 306 Times
Thanks all for your input, Frank.
Liked 447 Times
Frank.
Frank.
Yes! There is. For Sure. Now this is not the straight one, it does have like 25mm of setback.
Likes For masi61:
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
Frank.
Frank.
Likes For wphamilton:
Bikes: Specialized Diverge E5 Comp, Specialized AWOL Comp, Scott Solace 10
Quoted: 137 Post(s)
Liked 27 Times
Likes For winston63:
Seat Sniffer
Quoted: 947 Post(s)
Liked 2,034 Times
Whoa ... that is interesting. I prefer zero-offset seatposts, and my CF bike has that Thomson seat post. Ooof.
Likes For Biker395:
