Trek Domane SLR, what size to choose?
Quoted: 5 Post(s)
Hi
Is it possible that someone can share their experience in regards of size for a Trek Domane SLR,2020?!
I am 193 cm tall and maybe you can share your inside measurement and tell me if you feel that you can stretch out enough?!?
Thanks and have a nice weekend
They are perfect.
Quoted: 5 Post(s)
My true cycling inseam in 36.75".
I have the long seat post and there is plenty left. I have both posts too; the 20mm and the 5mm setback. The 20 is on the bike in the pictures.
I can answer any other questions you may have regarding dimensions and maybe some others too.
![](https://cimg2.ibsrv.net/gimg/bikeforums.net-vbulletin/1343x1007/20200214_162849_85510d8899e62591d8d12665c616142f97a3cd97.jpg)
![](https://cimg3.ibsrv.net/gimg/bikeforums.net-vbulletin/718x958/20200214_162717_790dd761cfd328f593a08d1e654384c0f5c0ae3d.jpg)
Bikes: 50/34, 11-40, 11 Speed
Quoted: 142 Post(s)
Liked 73 Times
I'm exactly the same height and my main bike is a five-year-old Domane, 62cm frame. My torso is a bit longer than average for my height and my legs a bit shorter. The stock stem on the bike was 110mm and I switched to a 120mm to accommodate the professional measurement and fit. The bike fits me perfectly.
Your bike shop or fitter can tell you all that you need to know. Unless your legs are longer than ninety-plus percent of men that are 193cm you have no worries.
Quoted: 5 Post(s)
Hi
thanks for your input!
Do you think that if I would Go for a size 58 then it would be become too small? If a looking at size 58 Vs 60 then there is a 4cm difference when looking at S"rail height maximum". (82.5 Vs 78.5cm) do you have on the maximum top level?
My concern is that if I go for the 58 then those 4 cm will result in that I can't stretch the leg straight enough or how much is your legs bend..
Hi
The reach and stack will likely be to short for your height on the 58.
Bikes: SL8 Pro, TCR beater
Quoted: 1027 Post(s)
Liked 595 Times
Hi
Bikes: Salsa Fargo - Focus O1E
Hi, I am also close to decided on a Domane.
But I am not sure about the size.
I am 184 cm tall and my inseam is 92 cm. (The bike fitter told me I have long legs :-)
I am not flexible (hamstrings and back) and I never had a road bike. I own a Salsa Fargo with Jones handlebar a and a Focus O1E mtb.
My bike fitter believes 62 because I need a high stack. But the 62 looks huge. Reach for a 60 and 62 are almost the same. I would put a shorter stem on (70 or 80 mm)
Any advise on this? I was used to always test a bicycle before buying but this is not possible now.
I found out that there are not a lot of road bikes / gravel bikes with a combination of a hight stack and short reach. If you have other recommendations. Also welcome.
Quoted: 5 Post(s)
After I did the bike fit then I actually went for 58 which suits me very good! See if there is a possibility to set up the Domane on a bike fit that will clarify!
But I did a bikefitting one year ago. My mtb setup changed a bit and we also did a fit for a gravel bike.
I never rode a dropbar bicycle so I was not sure if the fit was 100%. Difficult to say when you switch from a mtb setup straight to a gravel setup and with no experience dropbars.
The estimate reach was 385 and the stack was 660 for a dropbar bicycle.
So thats why he recommends a 62. But on the Trek website a 62 is recommended for (189 - 198)
And I am only 184 ....
Quoted: 850 Post(s)
Liked 344 Times
True, but the problem is that it is difficult now as almost everything is closed and we can only make necessary movements.
https://mikesbikes.com/products/serv...gaArRjEALw_wcB
Imo road/gravel bikes are not really meant to be ridden super upright. Even mtbers are pretty low, they just expend their reach on ultra-wide bars. One of my friends hypothesizes that the main reason people feel so confident with wide bars is because they “crucify” you into a forward position, which is better for control.
Domanes also have Trek’s seatpost sleeve system, which means you can’t lower the seatpost very much. You wouldn’t want to end up with a bike that you can’t get low enough on (but with long legs, that is unlikely to be an issue).
Sorry I don’t have much better information. It’s hard to say without meeting you in person, or at least seeing some photos. I’d also take your fitter’s word with a grain of salt. There are a LOT of “fitters” out there whose only qualification is that they showed up to a 3 day course.
Upon further research: it seems like the only real difference between 60 and 62 is that the 62 has a 2cm higher stack and a 2cm taller seat tube. If you truly need that extra stack, it’s not a wildly different fit. Plus, you can always lower the stem a bit if you think the 62 was too tall.
Likes For smashndash:
The bike fitter gave me this recommendation based on a fit where he put me on a Shimano fitting bike and adjusted until I felt well on it (one year ago). But with no experience on a dropbar this is difficult.
He told me a 60 would also be possible and that a hover handlebar (e.g. Specialized Hover Alloy Handlebars – 15mm -> I cannot post links yet :-)) could help if the stack would not be high enough.
When I bought my mtb I also was not sure but I could test ride it before ... If I would decide to buy a Domane now, I need to wait 10 weeks and make the right choice :-)
Quoted: 167 Post(s)
Liked 291 Times
I would highly recommend a proper bike fit - it isn't just about inseam and height but reach, shoulder width etc too. We can all tinker but my riding experience was immeasurably improved after I went to my LBS and had a pro bike fit involving accurate measurements matched to the bike of choice. With Trek, you can do the Project One customisation whereby you can then input not just the frame size you need but stem length, crank length etc. Makes a difference!
