11-50t cassette from my 1x11 Jamis Renegade help
Bikes: 2021 Salsa Fargo 1x12, 2019 Jamis Renegade Exploit 1x11. Motobacne NX Fat Tire
Quoted: 198 Post(s)
Liked 332 Times
Got a 2019 Renegade Exploit last year and it’s been a dream for me to ride. It has the 1x11 gearing with the 40t chainring and 11-42t cassette. For me it's geared too high for gravel and hills, I almost never use the 11t cog.
I do lots of hills and want to get some lower gearing than 40/42. Lots of internet searching yielded no smaller SRAM Apex 1 chainrings . Looks like I can put a Sunrace 11-50t cassette on however and I might try it out this spring. Want to make sure it’s compatible with my wheel hub first.
will this work? SunRace CSMX80 11-50T 11-Speed Wide Range Mountain Bike Cassette Black https://www.amazon.com/dp/B071Y5QHNW/ref=cm_sw_r_cp_tai_Ub1tEbSP7S6T8
Pic for fun.
I'm s Clydesdale too thus lower gearing will he lp this 6'4" 260# mass with the hills
Pic for fun.
Likes For Toadmeister:
Quoted: 630 Post(s)
Liked 369 Times
Probably will need an RD that has the chain wrap capacity of 40T x 50T. Not sure if that exists. I would switch to a front double 46/30T or lower or switch to a direct mount crankset with 32T
Occam's Rotor
Quoted: 2366 Post(s)
Liked 2,331 Times
A Box Two derailleur X-wide would do what you want. I have one, and it works fine with an 11-speed SLX shifter, and probably would work fine with the SRAM version.
But I would just get a smaller chainring/crank, rather than a new cassette and new derailleur.
Currently, your lowest gear ratio is pretty close to 1:1. That isn't very low. My all-road/gravel bike has a low 46/30T in the front and a 11-36T in the back, and I am about 60 lb lighter.
You can get a Shimano GRX 46/30T for about $150.
Get some low gearing on that thing, and don't let people give you any crap about it.
Likes For Cyclist0108:
2x would require new shifters (front one at least) which can be expensive. I'd agree about changing the chainrings vs the cassette though.
Sell bike and buy new bike with front crank, brakes, and cassette more in line with your needs as upgrading will likely cost as much as a new bike.
Bikes: Velo Orange Piolet
Quoted: 2228 Post(s)
Liked 2,011 Times
A smaller chainring might be an easier way to get the lower gearing you need. A 34t chainring would be like trading your current top gear (which you almost never use) for gear similar to what a 50t cog would give you with 40t chainring.
Likes For tyrion:
Quoted: 198 Post(s)
Liked 332 Times
Wish I could find a smaller Apex 1 chainring but they don't exist
Quoted: 198 Post(s)
Liked 332 Times
Occam's Rotor
Liked 2,331 Times
What the OP needs could be accomplished with just changing the current chainring for a smaller one, or at worst, getting a new crank. $100.
Quoted: 198 Post(s)
Liked 332 Times
Want to stay with 1x up front, love that. Can't find a smaller SRAM Apex 1 chainring than 40t however. Might have to swap the entire crankset
Quoted: 198 Post(s)
Liked 332 Times
any reccemendations on crankset? I currently have
SRAM Apex, XSYNC 40T, 175mm with a BB Set SRAM GXP
Quoted: 630 Post(s)
Liked 369 Times
The SRAM Apex 1x crankset has a weird asymmetric bolt pattern so there are very few options. The smallest I've seen is a 38T chainring but it is still like $80 and will give you minimal change.
Likes For Elvo:
Liked 2,011 Times
Probably need a mountain crank. I'd first examine your BB - if it's ok then you can keep it and get a crank that fits GXP BBs. If the BB is rough and needs replacement then you have more options for cranks.
Likes For tyrion:
Disco Infiltrator
Quoted: 3133 Post(s)
Liked 2,116 Times
Your RD will handle an 11-46 cassette.
look at Wolf Tooth, they have SRAM direct mount rings in a variety of sizes and offsets. If the size you want isn’t listed, it couldn’t hurt to email them and ask what to do. There’s leeway in the front chain line, it doesn’t need to be perfect.
Genesis 49:16-17
Genesis 49:16-17
Quoted: 198 Post(s)
Liked 332 Times
Occam's Rotor
Liked 2,331 Times
I think any 11-speed compatible 1X for mountain (or road or gravel) would probably work fine. Just make sure you don't go too low (it is possible, ask me how I know).
Bottom brackets can be had cheap, and are disposable wear items, so don't let that constrain you.
Disco Infiltrator
Liked 2,116 Times
Quoted: 198 Post(s)
Liked 332 Times
My old road bike I recall had such a low gearing on its 3x9 extreme that I could barely spin fast enough to keep from falling over going up a big hill! Sometimes the chain being so far crossed could fall off too. One reason I like me a 1x11 on my Gravel bike.
I should mention I also have a 1x11 on my fat bike with a 34t chainring and 11-42 cassette. Great for those 17% grades!
Randomhead
Liked 3,792 Times
does one of the North Shore Billet spiders fit on an Apex? https://northshorebillet.com/collect...ain-components
they have chain rings too
I have a sram force road crank with Shimano mtb chain rings on one of their rings.
Quoted: 716 Post(s)
Liked 807 Times
The SRAM Rival 1 has a direct mount spider that can be replaced with any GXP direct mount chainring. I opted for the Rival 1 group over the Apex1 on a recent build for just that reason.
Likes For dsaul:
Quoted: 198 Post(s)
Liked 332 Times
EDIT, I can’t find a 1x11 SRAM Rival with a 34t chainring....
Disco Infiltrator
Liked 2,116 Times
I see now. Sorry I thought it was in the direct mount family like the NX and GX cranks. Sorry for sending you on a wild goose chase.
Removing the spider on the Rival 1 crank would have the result I was imagining
Genesis 49:16-17
Genesis 49:16-17
