Help 😆
L-man
Bikes: Co Op cty 1.3 -light touring ~1972 Peugeot OU 8 / 1992? Specialized Allez Shimankestien
Quoted: 26 Post(s)
Liked 34 Times
Help 😆
My Co op cty1.3 has attachment points. Can anyone tell me the bolt thread size I would need ?
Quoted: 4239 Post(s)
Liked 3,975 Times
Attachment points for what and where on the bike are they?
(My house is painted, what do you think of the color) Andy
AndrewRStewart
AndrewRStewart
Really Old Senior Member
Buy a 5mm bolt and see if it fits.
If it doesn't, buy larger/smaller.
Likes For Bill Kapaun:
Liked 3,975 Times
As Bill said. Most all the typical mounting bosses, eyes, are M5 thread (5mm diameter by .8mm per thread). If the bike has a bottle boss set with bolts they are likely M5. Some drop out eyes are M6 (6x1), was popular in the 1980s on Asian made moderate cost bikes.
BTW most fender struts have a strut mounting hole big enough for M6, with a M5 bolt the bolt head can begin to sink into the strut's hole/loop. The strut will never get really tight and tend to loosen. I suggest considering sandwiching the strut loop with a couple of washers. This will allow the bolt to be better tightened and the strut's hole/loop not open up because of the bolt head. Andy
AndrewRStewart
AndrewRStewart
Likes For Andrew R Stewart:
Old fart
Quoted: 3617 Post(s)
Liked 3,454 Times
5mm x 0.8mm is the most common for those mounts. 6mm x 1mm is also possible. Others may be unthreaded to use a bolt that passes all the way through the fitting. Older USA-built bikes may have SAE spec fittings. And older British bikes may have Whitworth spec fittings.
Likes For JohnDThompson:
Quoted: 6356 Post(s)
Liked 4,958 Times
If the old clunker is old enough, it might be ANSI and not metric.
But I guess someone already said that, but in other terms. <grin>
Likes For Iride01:
Quoted: 863 Post(s)
Liked 1,108 Times
Looks like this is an REI branded bike. Call up the REI you bought it from. As you can see from the other posts there are no definite answers from your limited info.
Likes For Crankycrank:
Quoted: 2643 Post(s)
Liked 1,995 Times
Ride the bike down to your local hardware store, and ask if you can try an M5 bolt. It'll probably fit.
Likes For pdlamb:
Quoted: 2026 Post(s)
Liked 1,097 Times
Check the eyelets for paint overspray before trying the bolts (yes, M5 is most likely). I've built up several frames with racks and/or fenders and the attachment point have often required clearing before the bolts would thread in.
Likes For HillRider:
Mad bike riding scientist
Quoted: 6286 Post(s)
Liked 4,328 Times
Stuart Black
Stuart Black
Likes For cyccommute:
