Simple question .....
Quoted: 176 Post(s)
Liked 25 Times
What constitutes a gravel bike ? What does it have to have to be a gravel bike ? I bought a old 80's trek antelope and want to convert to this gravel bike ,,, the frame has front suspend and thumb shifters,,,,,,, thanks for any info....
Quoted: 696 Post(s)
Liked 910 Times
I’d say it has to have tires wider than road bike tires and smaller than mountain bike tires. Typically with drop bars, it can even look like a cross bike but would have mounts for cages, fenders and possibly even a rack if that’s your thing.
Likes For Ghazmh:
Dirty Heathen
Quoted: 893 Post(s)
Liked 936 Times
Gravel bike is a genre of drop-bar 'road' bike. Think a road bike on top, mountianbike (sort of) on the bottom. Looks like a 'normal' road bike, but usually has 40-50mm tires, with lots of clearance, sometimes a 1x drivetrain, but always a wide-range rear cassette. Think about riding fast (-ish) on long unpaved routes like fire roads or the Katy or C&O trails. (not paved, but you wouldn't need 4WD, either)
Old MTBs like your Antelope can be good base to start from, since they have a more 'neutral' stance than modern MTBs and already have a wide-range drivetrain, and room for big tires. It's mostly the handlebar / control setup and tire choice.
The Drop-bar MTB Conversions thread in the C&V forum has lots of good examples
Likes For Ironfish653:
Quoted: 4227 Post(s)
Liked 2,489 Times
Drop bars, frame clearance for bigger tires, preferably 700cc wheels but I think wheel size needs to be based on personal preference ....I converted two of my mountain bikes to gravel bikes. I put drop bars on them, one has 700x45mm tires the other has 26x2.35 tires and both of them are singlespeed.
Quoted: 1843 Post(s)
Liked 1,716 Times
What size tires does it take? Do you want to convert it to drop bars? The term "gravel bike" is a loose marketing term for a bike that is comfortable to ride on unpaved roads and smoothish trails. Most so called gravel bikes are simply bicycles with fairly relaxed frame angles for stability and clearance for tires almost as wide as mountain bikes. A Trek Antelope could probably do yeoman service as a gravel bike with minimal modification if your goal is to be able to ride unpaved roads. However, a 30-40 year old suspension fork is probably not going to provide much suspension after all those years
Likes For alcjphil:
WALSTIB
Don't try to put my bike in a box man. When I ride on gravel it's a Gravel Eating Machine
Likes For hillyman:
Quoted: 71 Post(s)
Liked 30 Times
The Trek will do an adequate job of riding the gravel. I have an Antelope 800. Have ridden it on 2 so called "gravel rides" here in N. Fl. It is mostly sand and the tires were too narrow for the sandier stretches. Saying that, I was able to ride through areas that had the larger shod tires on the newer bikes walking. A lot depends on the rider.
I have flat bars, not droppers and did not see where that hindered my efforts. Perhaps riding into the wind on a hard packed surface might make a diff, but for dirt, I do not see the need for drop bars.
You might want to check out the forks and make sure they are still operative and will give you a softer ride.
Try it on a couple of rides and you might be surprised.
Likes For Baldy1953:
Mad bike riding scientist
Quoted: 6255 Post(s)
Liked 4,280 Times
P9270080 by Stuart Black, on Flickr
a road oriented gravel bike might be faster. (Caveat: that road had very deep gravel in places that would swallow narrow tires whole.) But on a road like this
Untitled by Stuart Black, on Flickr
or this
your "slower" mountain bike is going to be much faster.
Your Trek is built for riding on rough terrain and rough roads. Just ride it and don't worry about labels.
Stuart Black
Stuart Black
Likes For cyccommute:
This.
Likes For Flip Flop Rider:
Señor Member
Quoted: 649 Post(s)
Liked 293 Times
Most have drop bars and room for wider tires. The factory built ones come with 700c wheels, and the frames and forks generally have room for 40mm tires or wider.
The suspension fork on your Trek (which probably means it is an early '90s and not an '80s model) will, as mentioned above, probably not add much besides weight. But it's not likely to hold you back at all. Replacement forks are available to convert it to full rigid, if you like.
Switching to drop bars is popular but there are some compromises when working with a bike designed for flat bars, and the end result is not always 100% worth the effort, in my opinion.
My advice: Tune up the Trek and ride it as-is, and if you want to do longer distances or find the Trek to be unsatisfactory, start saving up and checking for a used touring, cyclocross or gravel specific bike that fits you - these bike categories are al closely related to the modern 'gravel' bike.
Quoted: 18517 Post(s)
Liked 15,841 Times
Likes For indyfabz:
Happy banana slug
Quoted: 1539 Post(s)
Liked 1,540 Times
Happy banana slug
Liked 1,540 Times
Please show us pics of your bike! Bike pr0n for the win!
I like riding, so I'm in no rush to finish my rides. Also don't see the need for drop bars; of course, YMMV. Your Cantalope should make a fine off-pavement bike; get some big squishy tires and go for it! My Zoe has Kenda Small Block 8's; good grip on loose stuff, not too noisy on pavement.
Zoe (Washburn), my badass off-pavement ride.
Likes For Korina:
Liked 4,280 Times
Mine’s a YBB. In winter
And doing what I built it for
Stuart Black
Stuart Black
Likes For BirdsBikeBinocs:
Happy banana slug
Liked 1,540 Times
Likes For Korina:
