Campagnolo Gran Sport Rear Derailleur
Im cleaning up a Campy Gran Sport rear derailleur froma 1960 Carolton Franco Suisse. I have it all dissasembled except for the bolt holding the rear assembly together. See my photos. Should the bolt with my allen wrench inserted simply unscrew? Ive had it soaking in solvent and it wont budge. I am afraid to apply much more pressure until I know what is what.
Here is where I am at. This bolt wont budge!
Photo of the back.
before dissasembly
Photo of the back.
before dissasembly
Bikes: 1963? Anquetil , 1973 PX10,1979 PX10,1984 PX10, VITUS 979 PX10DU,1970S ALAN,1985 PSV10,1980s PY10FC,1978 bERTIN,ALAN carbon
Quoted: 283 Post(s)
Liked 641 Times
Photo of the back.
before dissasembly
Photo of the back.
before dissasembly
Got any any pics of the Carlton ?
https://www.flickr.com/photos/70488435@N03/
Quoted: 3038 Post(s)
Liked 3,934 Times
Yes. It should unscrew.
See the 3 concentric holes on the backside? Those are for adjusting the jockey arm spring. You get access to it and adjustments by removing said bolt.
Likes For iab:
incazzare.
Dang, that is awesome, Piff!
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
Likes For lostarchitect:
Quoted: 4573 Post(s)
Liked 6,558 Times
Likes For merziac:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3949 Post(s)
Liked 6,639 Times
On this Nuovo Record schematic, you're trying to free part 811/A, the tension spring bolt.
For NR derailleurs, the grub screw (812/1A) is removed first before any disassembly. And, when assembling, the cage is wound before the grub screw is replaced. Makes it so much easier. It's a little more difficult with Gran Sport and Record. When putting it back together, you have to thread the spring bolt a little bit, wind the cage (working it around the fixed grub screw) and then finish tightening down the bolt.
So, when you do free that stuck bolt, you may wish to loosen it short of all the way and unwind the cage before completely removing the bolt. If you don't, be ready for the spring and cage to snap on you.
Likes For SurferRosa:
Bikes: A few too many
Quoted: 1367 Post(s)
Liked 2,190 Times
Ben
Bikes: '68 Masi Special road, Grail bike
Quoted: 108 Post(s)
Liked 70 Times
the main bolt won't unscrew until you've taken the tension off it by removing the
stop screw that lets the spring unwind.
señor miembro
Liked 6,639 Times
Liked 2,190 Times
Quoted: 1871 Post(s)
Liked 670 Times
I would say, yes it should unscrew, and I have one that I recall I did unscrew many moons ago. But is there a reason you need to? The parts are 70 years old. If it turns freely and reasonably smooth, the spring wind up and springs, and ... there isn't a lot of wiggle or play, let it stay as it is.
This was a fun little project. The diagrams really helped. Truly the best advice I received was to leave the back bolt in place.
Likes For SB_Greg:
Bikes: 1951 Gillott L'Atlantique, 19?? Ephgrave
I am using a Gran Sport on a 5-speed Regina freewheel on my newly restored 1951 Gillott but am having trouble with the Campag as it keeps jumping out of gear and always climbs down to the smallest sprocket as soon as I start pedaling. I am using a lever with a high-friction return but that hasn’t helped. It seems like the return spring is applying too much force for the lever to hold against but I can’t see any way to adjust that. Can anyone out there offer any advice or tell me whether it is possible to adjust the rear mech somehow?
feros ferio
Quoted: 1409 Post(s)
Liked 1,366 Times
Many thanks, John. I can't comment on the assembly of the shifter as it was done by someone else who restored the bike but he's quite experienced so I would trust him to have done it correctly. Certainly I can't tighten the screw any further without damaging it. I had rebuilt the bike myself approx. 40 years ago and used a then-current Shimano rear mech with the original Simplex lever and that worked perfectly. For the recent restoration, we have tried to return it to near-original spec. hence the Campag and used that same Simplex lever but the latter didn't appear to be strong enough this time around. So we swapped it for the retrofriction type lever which looks pretty much identical although not an actual Simplex: no branding is marked on it. It worked at first but only for a short while. I'll look into ratcheting types as that sounds like an excellent suggestion but I'll discuss with the restorer before changing anything.
Quoted: 3652 Post(s)
Liked 3,089 Times
Quoted: 3470 Post(s)
Liked 2,844 Times
Bikes: old ones
Quoted: 26482 Post(s)
Liked 10,449 Times
