Maillard Helicomatic
I’m a little Surly
Quoted: 699 Post(s)
Liked 1,301 Times
Good evening folks
My Mercier has what looks like a 5 speed Helicomatic, I'm looking for a larger granny but most seem to be 6/7 speed. Will a 7 speed fit on the 5 speed hub and do I need a new lock ring to make it all work?
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3926 Post(s)
Liked 6,574 Times
Doubt it.
6- and 7-speeds are usually interchangeable for bikes with 126mm rear spacing and hubs to match. Bikes with 5-speed rears are usually spaced at 120mm with similar hubs.
In order to move from 5- to 6- or 7-speed, you may need to cold set the frame, and source a longer axle, axle spacers, and possibly a longer skewer.
This may be a good time to move away from the Helicomatic entirely.
Freewheel Medic
Quoted: 1467 Post(s)
Liked 2,231 Times
The larger sprockets from a 6 speed Helicomatic will fit on a 5 speed Helicomatic body. The smallest sprocket threads off (use two chainwhips) and the remaining sprockets are splined with spacers and slip off the body. Therefore if you find a 6 speed with the tooth counts you want, they can be interchanged.
Bob
Bob
Likes For pastorbobnlnh:
Quoted: 2367 Post(s)
Liked 1,759 Times
Was there ever a 7-speed Helicomatic?
Extraordinary Magnitude
Quoted: 2610 Post(s)
Liked 1,718 Times
The photos are gone, but according to the Helicomatic Museum, yes.
https://www.borgercompagnie.com/heli...galleries.html
Also in the words of the Helicomatic Museum:
"I would suggest to all but the most fanatic about originality to stay away from Helicomatic or replace any Helicomatic hub with a model for which it is easier to source spare parts."
Commence to jigglin’ huh?!?!
Quoted: 1652 Post(s)
Liked 852 Times
I didn't know that Maillard made a 5 speed cassette for the Helicomatic hub. I thought they were only 6 and 7 speeds.
72 Line Seeker
83 Davidson Signature
84 Peugeot PSV
84 Peugeot PY10FC
84 Gitane Tour de France.
85 Vitus Plus Carbone 7
86 ALAN Record Carbonio
86 Medici Aerodynamic (Project)
88 Pinarello Montello
89 Bottecchia Professional Chorus SL
95 Trek 5500 OCLV (Project)
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Liked 1,718 Times
Here’s a silly question- I know the hubs have different quality levels- (400/500/600/700)- Do the freewheel/cassette thingys have different levels as well? Was there a “Maillard 700 Team Issue” Helicomatic freewheel cassette thingy- and how did it differ from, say, a 500 level unit?
Liked 852 Times
I believe there was a "700" version of the Helicomatic as I think I've seen Heli hubs with the 700 decals on it.
I know that there were later/improved versions of the hubs with contact seals on them to keep the bearings "happy", but not sure if there was an upgrade of races and bearing quality and size to improve reliability.
I was surprised about to hear about the 5 speed cassette as if I remember correctly, the Helicomatic was introduced in the early 80's when most bikes already moved on to have 6 speed hubs.
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
72 Line Seeker
84 Peugeot PSV
84 Peugeot PY10FC
Quoted: 1618 Post(s)
Liked 2,233 Times
I have a very good condition 13-21 6V 700 series cassette from a 1984 Trek 610. I am interested in selling.
Liked 1,718 Times
The Helicomatics I've had have all been from Trek tourers- hence the 5 speeds in conjunction with the 'half step and a granny.'
