Rotor 3DF crankset compatibility question
Bikes: VeloBuild VB-R-022 // '89 Specialized Allez Full Dura-Ace 7400 // Santa Cruz Stigmata CC // Bridgestone MB-3 BoxTwo 1x Conversion // Bridgestone MB-6 // Santa Cruz Highball C // Ibis Spanky
Quoted: 68 Post(s)
Liked 20 Times
Hey guys -
So one of my good friends offered to sell me his Rotor 3DF Crankset for a friggin steal since I was eyeing replacing my crappy triple on my VeloBuild VB-R-022. He told me he could also sell me his Cannondale Hollowgram Crankset for the same price (a great deal) but I prefer the Rotors because they are 52/36 while the Hollowgrams are 53/39. I do quite a bit of climbing and I prefer the lower gearing.
My question is - what would I need to run the Rotors on my bike? It currently has a SRAM GXP BB in BSA. I believe the Rotors are 30mm spindle instead of the 24mm Shimano standard. Is just simply a matter of getting a new BB? Would you guys recommend going this route? Or should I go with the Hollowgrams and just getting a 12-30 cassette or something?
Thanks!
Thanks!
Quoted: 850 Post(s)
Liked 344 Times
https://www.thebikelist.co.uk/review...act-110mm-bcd/
Looks like you’ll need BSA 30.
https://www.backcountry.com/rotor-bsa-30-bottom-bracket
Rotor does make a BSA 30 BB, but any BSA 30 (68mm) BB should work. And yeah that should be the extent of the mods necessary.
The hollowgram, however, may not be a good fit. If it was designed for BB/PF30 or BB/PF30A, the spindle will be too short for BSA.
Bikes: Spooky Mulholland
Quoted: 52 Post(s)
Liked 17 Times
I run a Rotor 3D+ crank on my Spooky which is a standard BSA BB, I went with a Rotor BSA30 BB and its been great, cost me 50 bucks and havent had any issues.
Non omnino gravis
Quoted: 68 Post(s)
Liked 20 Times
Did your Rotor BB come with a BB wrench? The photo on Backcountry shows it with the wrench but it does not mention it.
Also, did you need any sort of spacers to make the crank fit?
Quoted: 68 Post(s)
Liked 20 Times
Did you order from Rotor directly or Backcountry? I want to make sure I get the tool too.
Non omnino gravis
Quoted: 68 Post(s)
Liked 20 Times
Quoted: 52 Post(s)
Liked 17 Times
I got it from my local shop, they ordered from Rotor, the one from Rotor comes with the tool needed. Its a attachment for a wrench. I am not running any spacers. All I did was install and then use the tension nut on the non-drive side to tighten any play which was about half a turn and its been great.
Quoted: 68 Post(s)
Liked 20 Times
Awesome - thanks, man. Bought the new BB and my friend gave me the cranks. Can't wait to get them installed!
Likes For speedyspaghetti:
There's the 3d24 and about 19 versions of the 3d 30mm. The 3D24 (shimano fit) has the spindle connected to the DS, the 30mm has it on the NDS.
30mm - https://i5.walmartimages.com/asr/ed7...d&odnBg=ffffff
24mm - https://www.picclickimg.com/d/l400/p...5-Arm-with.jpg
If the 3d24 172.5, check for chainring wobble. If you spin it mounted on the like and the chainring wobbles a few MM in/out, this is a defect. Probably OK for 1x, but not 2x.
