Problem with a thumb shifter on a miyata mtn. bike
Bikes: 1983 Univega Super Strada, 1986 Panasonic DX5000, 1984 Fuji Team 85 Univega Gran Turismo, 1984 Lotus Unique, 1987 Centurion Expert, 1987 Centurion Ironman Master,
Quoted: 679 Post(s)
Liked 471 Times
I have an old Miyata Valley Runner Mtn. bike I'm having trouble with the thumb shifter
to the rear derailleur. It shifts but has a lot more clicks than the 6 cogs on the rear derailleur.
The derailleur is a Shimano SIS but I'm not sure of the shifter. Here's a couple photos of
the shifter
the shifter
Insane Bicycle Mechanic
Quoted: 821 Post(s)
Liked 771 Times
The shifter is a "friction" shifter. It does not index on any particular cog- just shift until the chain is on the correct cog then nudge the shifter until it stops making noise.
This is how old farts like myself learned to shift. It works fine with a little practice.
Jeff Wills
Jeff Wills
Likes For Jeff Wills:
Quoted: 679 Post(s)
Liked 471 Times
For a detailed explanation you can reference this thread: https://www.bikeforums.net/classic-v...d-shifter.html
There are no indexed derailleurs (except positron?). The indexing happens at the shifter. There are only index compatible derailleurs. Means they have a compatible pull ratio to a particular indexed shifter.
Old fart
Quoted: 3618 Post(s)
Liked 3,458 Times
Some friction shifters have a ratchet mechanism to reduce effort when moving the lever. SunTour "Power" shifters and Shimano "Light Action" shifters, for example.
Quoted: 679 Post(s)
Liked 471 Times
The bike may have originally been spec'ed with friction shifters and derailleurs. The derailleur may have subsequently been replaced.
Old fart
Liked 3,458 Times
If you're certain the derailleur is original, then perhaps a previous owner replaced the indexed shift lever with a friction one because the indexed shifter failed. I see this fairly often when indexed grip-shifters fail, for example. Does the other lever match?
Quoted: 679 Post(s)
Liked 471 Times
Both levers match but I can't find any markings of brand. I can't find in the bikes specs what shifter it came with, just the derailleur
Droid on a mission
Quoted: 320 Post(s)
Liked 288 Times
Another reason to change the index shifter to a friction is some people find it hard to deal with twist type shifters and the friction-thumb type is just easier for them to operate.
Still puzzles me why those were called light action though since the levers are quite stiff IMO. They take so much effort to press I actually dislocated my left thumb one time while shifting. Popped right back in place but holy heck did that hurt.
Old fart
Liked 3,458 Times
Friction shifters don't get speed designations. I know some Shimano SIS thumb shifters could be toggled between friction mode and indexed mode, but the friction mode was pure friction, no ratchet.
Quoted: 581 Post(s)
Liked 921 Times
Deetox There is a common error when routing front derailleur cables to the front derailleur that causes excessive cable tension and, by extension, excessive force at the lever.
