Thinking about pickup truck conversion for tandem
Old 10-28-20, 01:42 PM
preventec47
Quoted: 97 Post(s)
Liked 40 Times in 28 Posts
I was looking at some cargo bike examples and I felt like I could design a bed carrier that would mount into the stoker seatpost after removing the seat and
on the sides connect somehow to the chain stays. BAsically two large compartments on either side of the bike that could be added or removed very easily
and swapped with the normal stoker seat.
Getting some ideas from these photos.....
preventec47 is offline
Old 11-05-20, 08:45 AM
sdodd
Quoted: 18 Post(s)
Liked 39 Times in 24 Posts
Are you looking to convert the tandem from a 2 person bike to a 1 person bike + cargo or are you trying to make a 2 person bike + cargo?
The former seems reasonable.
Extending the wheelbase on a tandem to add cargo capacity would need to be carefully thought out. There is significantly more stress on a bike carrying two people compared to one person.
sdodd is offline
Old 11-05-20, 08:49 PM
preventec47
Quoted: 97 Post(s)
No I am not thinking of expanding the wheelbase of a tandem, I am just recognizing that the second seat is already a cargo position of sorts in that the cargo is a passenger. If I can change the seat into a couple of buckets on each side or a platform like a truck bed then I can convert the tandem from a cargo bike back to a 2 seater by removing the carry bed by pulling it out of the seat post hole and reinserting the stoker seat.
Old 11-06-20, 05:36 PM
sdodd
Quoted: 18 Post(s)
Yeah - If you don't have a need for 2 people AND cargo then your suggested idea of using the stoker position as a cargo position would give you the safest and easiest conversion. You could start with the seatpost - build something that mounts on a rear rack mount or attaches to the rear drop outs - then extend to a reasonable point in the front. Perhaps some type of quick release clamp to the stoker handlebars? There isn't any other 'standard' robust mount between the stoker and the captain.
sdodd is offline
Old 11-06-20, 05:42 PM
CargoDane
Not a newbie to cycling
Bikes: Omnium Cargo Ti with Rohloff, Bullitt Milk Plus, Dahon Smooth Hound
Quoted: 356 Post(s)
Liked 323 Times in 199 Posts
If you don't need to ever have a stoker back there (so you can remove the pedals), you can have the cargo lower - regardless of them being buckets or panniers. But if that is what you want, let me recommend you buy a good cargo bike instead: Buy a two wheeled one, and with the cargo platform in front of you (makes it easier to steer than you sitting at the front of a tandem with a load at the back).
Edit:
If you need it to sometimes carry a stoker instead of cargo, you have to take the pedals into account, meaning the weight will suddenly be pretty far back and/or up high.
CargoDane is offline
Old 11-08-20, 03:52 AM
bazil4696
Bike Doctor
bazil4696's Avatar
Bikes: Norco Cape Cod tandem, KHS Tandemania Cross, 1952 Claud Butler ladyback tandem, 1971 & '73 Raleigh Suberbes, 1985 Gazelle Sport Solide, 1985 Rossi professional
Quoted: 58 Post(s)
Liked 52 Times in 24 Posts
Conversion kit for sale near me
bazil4696 is offline
Old 11-08-20, 06:54 AM
preventec47
Quoted: 97 Post(s)
Edit:
I plan to continue to ride with stokers most of the time but if I had an occasion to need to haul cargo then being able to "convert" my bike would be pretty cool.
Getting two for one so to speak in functionality.
Likes For preventec47:
Old 11-11-20, 03:03 PM
tgot
Bikes: 1986 Centurion Ironman, 1997 Trek 2120, Trek T1000
Quoted: 138 Post(s)
Liked 208 Times in 119 Posts
Depending on how much cargo, something like this:
Rack on a seatpost.
Might be enough. Unfortunately, I got it as part of the fairly expensive kid seat option here:https://www.amazon.com/gp/aw/d/B0027P9CX2#Ask
But I've also put it in the rear position of my tandem, and hooked panniers on it.
Depending on the tandem that surface and pannier hang might be just as low as a regular rear rack.
I haven't done it, but I could put three pair of panniers on my tandem and have three racktop surfaces to anchor to also.
tgot is offline
Old 10-12-22, 06:04 PM
Daveysprockets1
Liked 16 Times in 7 Posts
Check out "Ultimate cargo bike converted tandem" on youtube...amazing !!
Daveysprockets1 is offline
Old 10-21-22, 10:49 PM
jccaclimber
Bikes: n, I would like n+1
Quoted: 127 Post(s)
Liked 133 Times in 108 Posts
I was going to say to just find/make a Xtracycle type device for a single, but then you mentioned wanting a stoker occasionally.
Is this as simple as removing the stoker pedals (assuming not a DaVinci, in which case you could leave them on) and putting mount bars for paniers along the stoker's top tube and at the sides of their seat?
jccaclimber is offline
Old 10-22-22, 04:24 AM
Daveysprockets1
check out on youtube "Ultimate Cargo Bike.? Converted tandem"
