Rear Hub went out after 350 mles
Soooo, got a bike from BikeShopWarehouse (BSW). To meet the $1000 price point. They, of course, have to cut corners. Therefore the bike came with a nice carbon frame and low end wheels. I expected these wheels to last me at least a few thousand miles, but the rear hub went out after less than 2 months of riding.
My mechanic looked at the hub and the races are damaged, meaning the hub must be replaced. With labor that would be about $140. The cheap rim is only about $120 to replace.
Is it unreasonable for me to expect BSW to fix this?
Quoted: 18574 Post(s)
Liked 16,025 Times
No.
BTW...A few thouand miles on a hub is nothing. Tbe orginal set of wheels that came with my LHT logged many thousands of fully loaded touring miles between 2011 and 2018, including about 1,500 in one year alone, not to mention all the other miles of commuting, etc., Why would you expect so few? What make and model are they?
No.
They are Joytech.
Liked 16,025 Times
Well that sucks of them.
Why are you replacing the rim? Is it damaged?
Personally, I would consider it lesson learned and get a quality set of wheels built by someone who knows what they are doing. IMO, wheels are not the place to save money.
Likes For indyfabz:
I would simply buy a new rear wheel. There is no sense in paying to replace the hub of a cheap wheel. It's a labor intensive process that will probably cost more in labor than would be the cost to replace the entire wheel.
Likes For mihlbach:
Quoted: 2639 Post(s)
Liked 1,989 Times
I'm not sure how you could get BD's attention. File a small claims suit, maybe? I can't imagine anything you could do to kill a hub in that short a distance, other than get run over by a train or something.
Not a newbie to cycling
Bikes: Omnium Cargo Ti with Rohloff, Bullitt Milk Plus, Dahon Smooth Hound
Quoted: 356 Post(s)
Liked 323 Times
You can't make a warranty claim as having hubs go bust after 350 miles seems like it was not "fit for purpose"? I'd even go as far as take it with my bank/creditcard company if it was me.
Anyway, I'm also in the camp of buying a completely new wheel rather than try to repair parts of the old one. Get a reasonably good and rugged one made up.
Liked 1,989 Times
Forgot about the credit card. Dispute the charge (pay it anyway), and let the CC company argue for you.
Thanks guys....a couple of things: First, yes, it is not worth it to replace the hub, since the rim is only worth that much, in fact I can get a pair for $200.
To be clear, I did not get this bike from Bikes Direct (BD) I got it from BikeShopWarehouse (BSW). The bike has been plagued with problems. I think what happens is bikes are returned to BD, and then they are farmed out to BSW.
I purchased an inexpensive Motobecane Strada from BD, assembled it myself, and it has been FLAWLESS. The Immortal Spirit I got from BSW was nearly twice the price of the Strada and it has been in and out of the shop. BSW refuses to do anything so I am filing a complaint with the BBB.
In regards to the wheels....yes they are cheap and heavy. It is better to simply replace them. The game plan was to ride them during the winter while I saved up for a new set of wheels. I expected to get at least 2000 miles from them, not 350. Corona hurt my business, so I needed a little time to save up.
Quoted: 356 Post(s)
Liked 323 Times
Likes For CargoDane:
This will raise the price a bit, but after you buy an inexpensive new wheel, have a good wheel mechanic make sure they're tensioned and stress-relieved correctly.
Here is what I am going with for replacement: https://bicyclewheelwarehouse.com/Ro...Carbon-50.html
These are a pretty standard aluminum rim with 32 spokes for my fat 220 behind. This time I am serious about hubs, they are Dura Ace. Rims are an acceptable 1620 grams and non aero. My primary concern is durability.
Quoted: 356 Post(s)
Liked 323 Times
Randomhead
Liked 3,792 Times
It's typical for adjustable hubs to be over-tightened because it's easier than adjusting them properly. Most bike shops would have checked that and adjusted them. I suggest checking every adjustment if you know how.
Likes For unterhausen:
I wouldn't think it would be prudent to buy replacement wheels from the same shop who basically sold you a lemon (constantly in and out to be repaired as you say) that now refuses to fix your hub which broke after a mere 350 miles. Especially not at those prices. Cheapest one is $800? For a $1000 bike?
Quoted: 7126 Post(s)
Liked 11,293 Times
Regardless of whether BSW repairs or replaces the wheel, it seems like it is junk -- and a replacement will be junk, too. Wheels are not the place to economize. Work with your shop to get a decent wheelset, grit your teeth and pay for 'em -- and if BSW sends a new wheel, you'll have a spare wheelset.
Likes For Koyote:
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 250 Times
Did you check the hubs after receiving the bike to see if they were adjusted properly ? I go through and check evrything on a new bike purchase. Invariably there is stuff out of adjustment sometimes substantially. Typically the wheel hubs are loose. My guess is the hubs were badly out of adjustment and led to the premature failure.
Likes For frogman:
Liked 11,293 Times
We've seen a few of these threads lately -- about bikes bought over the 'net that came with problems, and sellers who are not interested in CS.
Gosh, you'd almost wonder whether buying from an LBS may actually be cheaper in the long-run.
Quoted: 668 Post(s)
Liked 529 Times
I think you should quit whining and learn how to lace up your own hub. That way you will experience the zen of fixing your own stuff and forever leave behind the anxiety of worrying about worthless warranties
Don't understand people's obsession with warranties. I think it is more of a control issue, feeling like you are somehow being violated rather than just having a bad part on an inexpensive bike.
Like someone else said even if they replace it under warranty, they are going to replace it with the same piece of crap that was on there originally. Broken stuff is an opportunity to upgrade.
So you have a couple of options. Listen to the sandbox lawyers and spend months pursuing small claims court, file a complaint with the BBB (which will do absolutely nothing for you) or get on with it and get a decent wheel, preferably one you build yourself.
Life is too short.
Life is too short.
Life is too short.
Life is too short.
Likes For RadDog:
I actually tried buying from my LBS first.
A man has to know his limitations. I am a very good all around cyclist, but I am totally lacking in mechanical talent. I do my own basic maintenance but have my bike professionally tuned every 6 months or so. I can of course replace tubes and tires, clean and lubricate chains etc....but I don't have the cassette tool (I will be getting one...cassette is the sort of thing I can do). I have tried truing rims and I can get a small bend out but beyond that I suck. I have more than $2k in this bike now, and I don't mind paying my guy to come out to the house and do some work, his prices are fair.
